5.9 cummings preheater switch unhooked
Started by muellerlogging, February 04, 2011, 06:16:37 PM
muellerlogging
just bought the 490 prentice and the preheater switch is unhooked. it is a 5.9 cummings, should i just wire a new one in cause the wires r all gone to the old one.
snowstorm
is the relay there??how much is missing? would think it would have one maybe like a ford starter selionoid switch to big cable from batt thru selionoid to grid heater. a little toggle switch with 14ga wire batt to heater will not work.......well it mite for a min till it catachs fire
It might depend on where you are. ???  The pre-heater on my ol' '93 Dodge truck started killing the battery, so I just disconnected the whole mess.  Of course, I'm in Florida.  If you're up in the cold country, you may really need it.
muellerlogging
the relay is still there. they just unhooked everthing to the switch. i imagine there is a reason for that. maybe i would be better off to put in one of those webasto diesel heaters. i have never messed with them before. anyone have any advice on these?
snowstorm
a can of 'happy gas' either is the cheapest. think youll find a fuel fired heater is close to a grand. how cold dose it get where you are? i have a 4cyl. cummins in a valmet it will start down to zero without either. it dosent have a either injector on it? mine dose
muellerlogging
we dont go in the woods if it gets to far below 0. r one 5.9 cummings we have starts perfect and the one in the prentice is starting hard i better check my fuel filters.
snowstorm
the grid heater manifold heater whatever you wanta call it. it heats the air going into the engine. fools it into thinking its warm out. my cat excavator has one works well
