splitting posts on a lucas mill.
Started by weisyboy, January 30, 2011, 07:19:03 AM
weisyboy
you'v seen how we do them with a chainsaw thought id show you how we do it on the lucas.
being a sunday, and i have an order of posts to cut tommorow i thaught id take the time today to take a few pics.
I made up a frame with castor wheels on it, they are spaced so there is about a 3" gap between the 6" wheels, the wheels have breaks on them to hold the log in the right place.
Line the blade up with the center of the log in horizontal this will only need to be done once on each log.
Make a scoring cut along the edge to make sure its lined up. Then cut to about 1" of the center of the log.
Release the breaks, roll the log bout 6",
Make a scoring cut, to make sure the post will be big enough, then cut to within about 1" of the center.
Continue this process until your all the way round.
I then pick the log up with the bobcat, take it away from the mill, rais it up high and drop it,
You end up with a nice lot of posts, almost no labor, and its fast.
before i made the rollers we jsut used a couple of logs with V cut in them, the log would roll around in it ok, but it wasnt as good as the rollers.
this is fast and easy, you barely raise a sweat, each cut only takes about 20 seconds about 5 seconds to roll the log, a bloke working the bobcat feedin billets and removing /splitting posts, is kept buisy all day.
god bless america god save the queen god defend new zealand and thank christ for Australia
www.weisssawmilling.com.au
http://www.youtube.com/user/weisyboy?feature=mhee
http://www.facebook.com/profile.php?id=100000696669814&sk=photos
Meadows Miller
Gday
Carl your loving that bobcat aint you and your wondering how you did without it hey Mate  :D  ;) ;D ;D 8) 8)
Regards Chris
4TH Generation Timbergetter
terrifictimbersllc
Cool.  Looks like what the seagulls do here to crabs in the parking lot by the beach.  8)
weisyboy
yes im lovin the bobcat. would love sompthin bigger, would only lift one end of the 650 dimiter 8m long log i had allan mill for me on friday.
i know how i got on without it, i spent half the day welding up the loader frame after i broke it.
sgschwend
Very ingenuous!!!  This method would also make columns or D logs.
I can see making caster for my mill frame, just slide them on the rail tops.
Steve Gschwend
sjgschwend@gmail.com
weisyboy
only problem with this method with the peterson type mills where you cant move each end individualy,  as it lines up with the bottom of the log not the center.
the best way to do it on one of them mills would be to have a splike to attach it to the center of the log like a wood lathe.
Captain
Always have dreamed of a lathe type log "chucking" device for cutting rift sawn siding.
Captain
terrifictimbersllc
Quote from: weisyboy on January 30, 2011, 07:49:56 AM
Dig in an automotive floor jack underneath one of the caster ends and shim up that end.
captain_crunch
Wished I had pics of a turner I seen years back under a Mobile Demention mill They had two rollers with 1/2" spiles in them about 18"long Set up like above but with a shaft conecting two rollers on one side with a hyd motor turning shaft. They were rolling 4 and 5 ft logs 18 ft long with it.This way they got all the clear wood off outside then chipped cant
M-14 Belsaw circle mill,HD-11 Log Loader,TD-14 Crawler,TD-9 Crawler and Ford 2910 Loader Tractor
r.man
Thats a neat trick Weisy. My dad used to split cedars into what he called stakes using wedges. He would have been impressed with your way of doing it.
Life is too short or my list is too long, not sure which. Dec 2014
weisyboy
we used to split these posts with wedges, most are done now with a chainsaw. this is less labour intensive.
WildDog
Thanks mate that caster idea is a ripper, I've already marked it down on the 2 do list, Supa-Cheap-Auto's got cheap casters.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
weisyboy
make sure the castors can withstand a 150kg log being droped on them, and a machine bashing tehm around.
brdmkr
weisyboy, that contraption is as cool as the other side of a pillow.  You have given me something to think about 8)
Lucas 618  Mahindra 4110, FEL and pallet forks, some cant hooks, and a dose of want-to
sandhills
You guys were talking about a lathe style turner, my friend built a rotisserrie deal to roll over a car he is restoring.  He used an old gearbox off a pivot wheel on the end and you can flip the car round and round with one finger on a 1/2" ratchet, I would think the same would work for big logs.  I also told him I was going to hook up an orbit motor to it, put a couple racing seats/harnesses in it and sell rides :D :D
woodsteach
Ok it looks like a great idea and all, but why do you use pie shaped posts?  And more importantly where do you get a pie shaped hole drill??? ;D
Which side of the post do you typically attach the wire or boards to?
woodsteach
Brand X Swing Mill, JD 317 Skidloader, MS460 & 290, the best family a guy could ever dream of...all provided by God up above.  (with help from our banker ; ) )
Busy Beaver Lumber
Weisyboy
Very cool device and cleaver way to make split posts. Go to hand it to you, you are quite the metal fabricator
Woodmizer LT-10 10hp
Epilog Mini 18 Laser Engraver with rotary axis
Digital Wood Carver CNC Machine
6 x 10 dump trailer
Grizzly 15in Spiral Cut Surface Planer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
sgschwend
My buddy Jeff is picking me up some casters tomorrow.  I am going to slide them on my bunks just like the way the manual log dogs work.  I will setup two of the caster to have variable height to account for log tapper (just simple pins, or a stop bolt).
Steve Gschwend
weisyboy
split posts have always been used in australia for fural fencing, origionaly it would have been cos, tehy would cut a tree down split the posts out and carry them along the line, dig the holes and put them in, all by hand. long before sawmills.
i know of places that have 1000s of meters of split post with split rail fencing, that was put up over 100 years ago, the land needed clearing and wire was  to dear. time was worth nothing.
we drill a 12" hole, put the post in and ram around it, some blokes cut a point on them, drill a 4" hole and knock them in with a gizmo on a tractor.
tehy are normaly use for wire fences, the posts are put in so the backs (barked edge) is accross the fence so the wire goes threw the back and out the pointy end. when putting rails on you screw them to the back, so the posts go in the other way round.
if you have a mill that you cant adjust eh height on you could make one end adjustable sideways, so the log sits down lower whn the wheels are moved apart.
Meadows Miller
Quote from: weisyboy on January 30, 2011, 07:29:24 AM
thats not much fun  :( :( did you have Allan down cutting afew 10x10s or something Mate?
You Young Blokes ALWAYS seem to break bloody equipment  :o :) ??? ::) It would have nothing to do with asking alot of it would it Mate  ;) :D :D :D  I think we all would like a bigger loader I can get a Cat licensed 936 loader with 3 ton lift out of china for about $30k landed with a/c cab quick hitch log forks with clamp and bucket (take about $3k of for an open rops ) .out of china with full 1 year warranty direct from the factory Dad n I are thinking of importing a couple later this year ( as they retail here from the dealer/importer for $80k what a rip off some lowsy barstards making more than his fare share  :o :( >:( )   if you want to suss out getting one give us a yell and ill put you in touch with the company the good thing is you can get finance for them as they are a new machine  ;)
I also have some other good news for you too  look in your scragg thread Mate  ;)
Regards Chris
weisyboy
me hard on things, nevver.
had to taek 140 split posts, and 20 7m lengths of 6x2 down to boonah today.
tunred out it was at the end of some goat track, tel ya what going on washed out steep as [I have typed a profane word that is automatically changed by the forum censored words program I should know better] gravel roads with atleaste 4 tons worth of trailer aint fun at 7 am.
had to use low range 4wd 1st gear for most of it. and we where skiddin all over the joint.
nothin broke good old rodeos tehy are frigin good wev been flogen them foreven and never had one give up. if i cant beak it its pretty good.
allan came down to cut me some 7.5m 10 x 2.5s for a patio roof wer doing, i dont have the extra extentions and allan dose,
he also dressed up some slabs with his planner blade for me to.
sigidi
Yeah those beams ended up looking sweet hey Carl? thanks for the days playing mate  ;)
As for the castor idea, that is great, really easy way to bust out ya splits too ;D I like it, gotta get me one of those bobcat gizmos...one day ::)
Always willing to help - Allan
weisyboy
make sure you get one that runs on a deisel motor not a heart.
the second type might not be so easy to controll. :D
weisyboy
ill put up some photos of the beams once there up mate, probly on tuesday.
gota lift the buggers up onto 3.5m high posts.
texican
I'm thinking with huge logs, you lift one side of the Lucas frame out of the way, and center the log, and put the side back on... Or do you unload the log, and assemble the frame around it, and then start cutting.
With your bobcat, are you able to lower the logs into the 'cradle'? without having to move the frame around?  Figure it is...
My grandpa split thousands of post oak logs by hand over the years.  Part of my place was on his land, and I've got half a mile of his original fence alongside the road.  Those posts are still hard enough to bend staples.  (Learned quick to hold em with pliers before hammering).  All of the nails are in the flat sides... the small amount of sapwood on the round side would rot off, the heart wouldn't.
weisyboy
the bobcat will reach streight over the rail and place the log in the cradle, and pick it back up agin no trouble.
with big logs (ones the bobcat cant lift) over 1 ton or so, we wouldnt be splitting so i have my bolsters in, we just wind the rails up ad poke it in underneath.
easy as that.
