Corley setworks question
Started by Dave_, December 20, 2010, 11:25:48 PM
Dave_
Hey Corley guys (and/or gals ;)), I'm trying to get my head wrapped around how the set works function on the 395 we are going to restore.  I got a great care package from Corley and one of the diagrams shows an exploded view of a standard single acting set works (the one we have).  The back of the set works has a rear foot trip (part #176101).  Is this trip for someone who rides the carriage or what?  The carriage seems very small to have a passenger ???
captain_crunch
Dave
Kinda wonder if they may have a stageing on off side for ratchet setter ???
Do you have a drawing or better yet, a pic?
or a link?
ibbob
You can trip the receder from the back but I doubt it was intended for a rider.  Should be a link and a bar under the carriage coming out the front side for the sawyer.
Bob
I used to ride a carriage and run the setworks while sawing. Also set the dogs and the taper depending on what the sawyer friend wanted to do next.
There was a foot pedal release that was available if/when needed. Don't recall the setworks brand name, so if a pic is available I might recognize it.
ibbob
Talking about the "T" lever sticking out from the carriage, correct?
Bob
ibbob
That setworks looks pretty familiar. :)
Dave_
Yeah, ibbob, that's the one.  Your set works is the heavy duty and mine is the standard, but the lever function is the same.  Thanks
captain_crunch
ibbob
Could you post a better pic of the Ruler type Gauge Looks LOTS better than the belsaw slide ruler for consistancy
Meadows Miller
Gday
Looking at the pic I think it looks like a foot trip to release all the prals from the gears to free float the headblocks when you have a block setter on the carriage to save time  ;)
Regards Chris
4TH Generation Timbergetter
ibbob
Captain
It is just a metal yard stick from the hardware.
Bob
Meadows Miller
Quote from: beenthere on December 22, 2010, 11:12:13 AM
Chris
You are right. :)
Bt Do I get a Prize Mate  ;) :D :D :D ;D
There should be some way you could rig a trip bar up so when your loading logs you could just put you foot down on a lever syst under the mill frame to free up the gears while you roll the log to where you want it then release it sorta like a power receder only your carriage aint moving when you use it Just thinkn  ;)
Regards Chris
Dave, do you have a receder on your Corley carriage??Most setworks have a lock and its released manually with the "D" handle or automatically with the receder foot pedal to move the headblocks back for a new log.Some sawyers use the receder to flip the log back to turn it and advance it quickly.The old mill manufacturers used many of the same parts on different sized mills,mayby that foot pedal is just not needed on your mill. Frank C.
Dave_
Yeah, Frank, it has a receder spring and there is a "C" shaped bar they call a pawl lifter bar attached to the foot trip.  There is also suppose to be a sawyers foot trip attached, but this one doesn't have one.  The previous owner just tied a cord to the pawl lifter bar so he could give it a yank when time to recede.  I think you are right about them using the same parts on different mills.  It's reasonable to assume that this set works would have also been used on larger carriages that employed the use of a block setter.
captain_crunch
Dave
I will get some pics of Duane's set works for you tomorrow
