broken band teeth
Started by bandmiller2, December 08, 2010, 09:00:32 PM
How many broken tips in a row before you junk a band?? please give your thoughts. Frank C.
Three in a row can be used if you have some rough sawing to do.  If you've lost 4 or more in a row, It's my opinion that you should junk the band.  The reason is that the gap of missing teeth is too tough on the guides. They get hammered every time the gap passes through the cant.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
paul case
half is too many.
i hit some serious metal with that dand0. the next pic is what it oughta look like.
pc
pc
Banjo picker
I hit a sheetrock screw and knocked off 26 I think...sharpened it  and cut ties with it..Had to go slower....I didn't think about what Tom said about the beating the roller guides took...Oh well it survivied... :(  Tim
Chuck White
I don't know as I've ever broken a band tooth, but I've bent and rounded enough of them to where the band was declared scrap metal!
I set my bands at .025 +/-.001!  Probably if they were set at .030, they'd be more likely to crack and break.
I ended up junking this one.
terrifictimbersllc
How'd you do that? Aren't you supposed to be looking in the general direction of the blade, hands on the machine, and the radio turned down just enough so you can still hear the mill a little?   :D :D :D
terrifictimbersllc
If most of such a blade is an easy resharp, but a only a few teeth are missing (I'd draw the line at about 5), I view the blade as of no value, but still sharpen and keep it on the side to offer the customer after we hit metal and he wants to make some suspect cuts.  Then if it's trashed I might only charge him about $10 sometimes less , just the value of a sharpening.
laffs
i had one that had 6 knocked off had it sharpened and i couldnt tell the difference when i got it back.
i  got 2 with 26 teeth knocked off and the guy said he could file them so i may give thata shot
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
barbender
Tom could've revived that blade :D
