038 AV Wanting to change to 038 Magnum
Started by waddodiggs, November 10, 2010, 08:18:01 AM
waddodiggs
I have purchased a 038 AV that is in good shape for $65.00.  I want to change it to a 038 Magnum I have a 038 Magnum and I love it. Mine 038 AV has a magniesum tank and handle. i read Mad Professor's line that with a new piston and cylinder and a little creative work with a dremel it was possiable. I have also noticed that the carbs are different. If anyone has done it I would appericiate your experience. I have read that the AV can be modified to run as good or better than the stock 038 Magnum. Would be interested in that also if it is cheaper. Sincerely, Waddodiggs
Al_Smith
Well you would have to slot the cylinder bolt holes and try to keep everything in alignment which would be a good trick if you could do it .Some say they have and I won't dispute that but it would be simpler to get a mag to begin with .
As far as an AV running with a mag most likely I was the one that said that .I have one that will .
You have to jack the compression and re-port the thing .I won't go into how to because everyone who reworks one  thinks they are the only ones that know how and that's the farthest thing from the truth there is .Fact being I just don't feel like arguing about it .My suggestion is to research it a tad bit by surfing the net .Sites like MacDizzy and others pretty well cover reworking two cycles .
The AV used an HK-42 carb Walbro  whereas the mag used some model of Bing but they interchange .
The Bing is supposed to be the better of the two from what they say .I own both and with the exception of rebuilding both really have had no trouble with either .
Mad Professor
Get a 038 shop manual.  It mentions potential problems going from 038 to 038 super (might have to grind cyl mating surface on crankcase).  Not Rocket science here, stuff a rag in the case and get the dremel out....
The conversions I have done did not require this, but I started with  super bottom ends.
Regardless you will have to slot the Mag Cyl mounting holes to match the case.  Then may have to grind where there the cyl bolts seat on the cyl and/or turn the bolt heads down.  Finally you need to open up the access holes in the cyl fins so your T-27 long torx will get to the bolts.
DO NOT slot the cly too far or you will get close to the bore, you also need to slot a Mag base gasket ) if using one).  Using a super base gasket will work, bit the gasket will hang ~ 1mm into the bore area and hamper gas flow.
Be careful when slotting the cyl base mounting holes, keep the bore centered, a 038 base gasket is a good template to locate the holes.
For carbs the Tilly from a 038S  or the Bing have the same venturi size, I've tuned the same saw with both carbs, and the settings (Hi/Lo)  were identical, but I might have gotten lucky....
The Stihl manual suggests upgrading to the 038S Tilly carb, when they go from 038 to 038S.  I've not played with a 038 carb to Mag conversion.  Might flow enough?  Don't know for sure.
Finally, open up the exhaust or go to a 3-port optional 038 Mag muffler.  The dual port opened up to the limit of being able to retain the spark screens seems to work well.  The ex port will be bigger on the mag cyl , match the muffler intake to the same size, then remove or open up the baffle with a 5/16" drill. Chamfer filings/drillings on the muffler so loose crap does not get sucked into your new P/C assy.
Muffler mods are a whole other topic.  I just posted what has worked for me, I always leave spark screens in, or add a screen, to a "new" port.  A piece of pipe welded into a new hole works well, if you size it right a Stihl blower muffler screen will clamp on.
P.S. Listen to Al too, he has been inside a whole lot of 038 saws.
P.P.S. Use OEM Stihl parts (gasket seal set, etc...) , if the P/C assy is too pricey, I can recommend TECOMEC, quality italian parts, a suppiler for Ducati bikes.  Also on a saw that old, fuel line, impulse line, crank seals, check intake  manifold very well.
HolmenTree
The best simple  advice to make that 038 AV cut better then a stock 038 Mag is take the cylinder to a machinist, have them take .020'' off the base. File .040'' off the piston intake side skirt [straight across]. Round off edge of piston at exact 3 points where the floor of the exhaust port and the ceilings of the transfer ports meet piston top edge at bottom dead centre. This compensates for the .020'' cylinder lowering. With the machined cylinder and base gasket installed the exhaust port can be easily scribed with a felt marker. After removing piston, round off the marked exhaust edge, then slide piston into cylinder at point where exhaust edges meet. Then mark transfers edges on piston with a sharp curved dental pick. File marked piston edges. Clean up piston, install new rings and base gasket. Reset carb.
If you don't want the machinist expense, leave out the base gasket and use a thin layer of YamaBond sealent. But I prefer the machining for ease of cylinder removal later and the spot on marking of piston edges .
Willard.
HolmenTree
Something I should have mentioned in my last post is there will be a ridge of carbon at the very top of the cylinder wall. Remove this carbon before running the saw after these mods. A folded piece of fine emery cloth will do the job
Willard.
Mad Professor
Quote from: HolmenTree on November 11, 2010, 03:46:01 PM
Willard.
You should check the squish with the above mentioned mods.
You can do the same type of mods. with a magnum cly assy: there is no substitute for displacement!
P.S. I'll run my super to mag conversion (decribed above) , against your 038 AV hot rod with the above mentioned mods.
Al_Smith
Quote from: Mad Professor on November 11, 2010, 07:55:18 PM
P.S. to the P.S. I'll top that one. Hows about an 38 Mag that started out life as  an 038 mag  to begin with ,with enough guts to outcut a stock 066 over the blocks . 8)--It's kind of slow though,only runs at 14,600 . ;)
HolmenTree
Willard.
I was just giving the author of this thread simple basic information how to make his 038 Av cut faster then a "stock" 038 Mag.
I know the squish on these older 038 AVs. You're good to go with .020 lowering and have room to spare.
I own [ 3 ] 038s since brand new. 038AV, 038 Super II, 038 Mag. Only my SuperII is modded with my above description plus 4 deep finger ports and a 056 Mag carb on it. I did these mods in 1983, I bought my 038 Mag a few years later , didn't bother modding it because my Super II was fast enough.
If we ever cross paths....... sure I'll run my Super II against your Mag, hell my 038 mods are 27 years old.
Willard :D
Al_Smith
You've got lots of room to lower the jug  like Willard said .An 038 has something like 45 thou clearance stock and 101 degree opening on the exhaust  stock .The base gasket is 20 thou thick .
waddodiggs
I sincerely thank you gentleman for your responce. You have given me some really good ideas on what can be done. No one has mentioned a longer piston rod or a modifyed piston rod. I don't know if this is possiable. It just came to mind while reading your solutions to my desires. I like all your ideas. I have decided to completly rebuild the saw and use the stock parts modified to increase compression and performance. I see levels of testostrone rising here.he he he. My wife thinks I have better things to do with my time,but nothing like undertaking something new and bring it to completion with success.
Now do any of you have pictures or manuals of 038 AV. Links to such. Sincerely Waddodiggs
Al_Smith
A longer connecting rod wouldn't do anything but jamb the piston through the head deck .Besides that the thing is a pressed together crankshaft and even if you could or would put a longer rod on it for whatever reason how pray tell would you get the job done . ???
Now granted they do knock apart 3120 Husqvarnas ,stroke them and use an 084 Stihl rod but you are talking 5,000 dollar race saws not a hundred dollar used 038 Stihl firewood cutter .You've got to be a little practical  here now .It isn't like souping up a 350 Chevy .
weimedog
Bump...HolmenTree reference in the "Those wonderfull old Husqvarna's...model 61 Ranchers thru 272XP's" post I believe
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
HolmenTree
Quote from: weimedog on December 29, 2010, 10:39:54 PM
You got it. :P
Willard.
Al_Smith
Back to the guys original question .You can make a 60 cc 038 Av run as well or better than a stock  mag with a little massaging . I've done it and I'm no wizard of chainsawdom .
sawforheat
Hi, I am new to this forum but have been reading post for a while now.I have a stihl 038 super and was wanting to ask HolmenTree a question about how to put a 056 mag carb on my saw.If any help with this would be highly thankful.Thank you
Al_Smith
It's got enough carb on it already .Unless you get to opening the ports up gigantic a larger carb won't do you much good .
sawforheat
I see what you are saying.I am wanting to get the 038 mag cylinder kit and put on it and shave the head and port the piston to the head as stated in the eariler post.I can't afford a real big saw so thought I would mod my saw to cut some 2 and 3 foot logs pretty fast.I have a husqvarna 272xp stock that does good and want to get my stihl up to cut faster than it.Thank you for your info on this. :christmas:
sawforheat
Hi it took me a while but I got an 038 mag cylinder kit cut .020 off the base and .040 off the piston intake side and polished the exhaust and intake ports and ported the muffler.I have a 056 mag Carb I want to put on it but it don't fit.Can you tell me how to mount it on my saw.Thanks
Al_Smith
You're kind of spinning your wheels if you don't have a large enough intake tract to accomidate a larger carb .It's kind of like stuffing 5 pounds of potatoes in a 3 pound sack .
rj
I have been watching this post with interest as I have a stock 38 super that I would like rework to better than a stock magnum,
I was thinking of a mag cylinder/pot & skimming.
This leads me to my questioning in order to do this right.
I Can take the .508mm/.020" off the base no problem but I don't understand the following.
Quote"File .040'' off the piston intake side skirt [straight across]. Round off edge of piston at exact 3 points where the floor of the exhaust port and the ceilings of the transfer ports meet piston top edge at bottom dead centre.
or.
With the machined cylinder and base gasket installed the exhaust port can be easily scribed with a felt marker. After removing piston, round off the marked exhaust edge, then slide piston into cylinder at point where exhaust edges meet. Then mark transfers edges on piston with a sharp curved dental pick. File marked piston edges. Clean up piston, install new rings and base gasket. Reset carb."unquote.
If someone could help me understand I would be most appreciated.
Al_Smith
You don't need to shave the bottom off the piston for one thing .If you drop the cylinder say 20 thou you've effectively not only increased the compression but also have changed the intake by 20 thou.At the same time though you've increased the degrees the exhaust opens if you don't raise it . That by the way is 101 degrees after top dead center on a stock 038 series .If want any more speed you have to raise it a few degrees .If you don't leave it alone .
HolmenTree
Quote from: rj on October 14, 2013, 06:20:47 PM
or.
I think I gave a little too much information here :D
HolmenTree
Quote from: Al_Smith on October 14, 2013, 07:20:01 PM
.040 off the 038's intake skirt plus the .020 with the cylinder lowered works fine Al. Simple tricks Madsens first did to my 038s back in the early '80s . Mind you we were boring out the carbs venturies also or just swapping bigger carbs, plus for race GTG s 4 finger ports were also a good way to get even more air/ fuel mix through the unit..
On my 137cc 090AV 's we were taking 2 mm [.080] off their intake skirts. Experimenting on a piston only was a lot cheaper then ruining a good cylinder.
My advice is try .020 off the piston's intake skirt first, then go from there.
Al_Smith
Walkers made some good robust saws,I've ran a few .
There's several trains of thought on this cutting the skirt business .While it might cause it to take a bigger "gulp " on intake by lowering it the intake would happen lower in the cylinder regarding degrees past bottom dead center .Now this could be good or not so for several reasons .
For one if it where slightly delayed by only allowing say 20-23 thou you lowered the cylinder the piston would have created a lower pressure by virtue of the fact it had taveled farther up the cylinder .This is turn would create a higher differential of pressure between the crankcase and the atmospheric side of the carb and as such would be at a slightly higher velocity .--more--
Conversely though by opening the intake port sooner it could possible that during the transfer and exhaust there is some point where it's open clear back to the carb .If things were just right and if the carb was large enough to supply fuel it might be possible to get a suction clear through the thing .
Al_Smith
Now I'm not saying which is best but there are options and different trains of thought on this stuff .Some of the gurus say to get your port time open parameters by first  widening whatever port you are dealing with first before you raise or lower the respective one .Who is right or who is not so who is really to say if the end results are the same ?
As general conversation the same applies with regards to transfer ports .Some are gaga over finger ports .Some prefer externals some just redirecting  the uppers with a domed piston .Then again some prefer to use a flat top piston and achieve great results .--twenty ways to skin the same cat --- ;)
