tigercat loaders?
Started by treefarmer87, November 07, 2010, 05:46:02 PM
treefarmer87
i was watching swamp loggers and i noticed something, why are there loaders set up on tracks? are they smoother or more powerful? i also went on the tigercat site and found my dream loader, a 220.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Less ground pressure, so less likely to sink in the swamp?
Bobus2003
Low Ground Pressure, Stability (weight), traction, Power.. I had a chance to run an old Pro-Pac 6wd truck Chassis Mounted Stroke Delimber, Thing was very tippy Compared to a Denharco stroke Delimber mounted on a Tracked Carrier. A tracked Carrier has much larger Hydraulic set-up (Run the undercarrage, Swing)to be able to handle larger Grapple loads, and a bit more weight keeps them Glued to the ground better.  Watch When they run the "old" Loader that thing Jumps around alot when swinging logs
treefarmer87
yea i remember hearing dave say that in the last episode
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Buck
That LGP is sweet. After reading about some of you adventures I think you need mobility.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Maine372
also he can pick up his slasher and move without having to get pulled around by a skidder or hooked to a road tractor. and if need be he could unhook the slasher and go shovel logging with the same machine.
Exactly.  The flexibility of the tracked loader is huge.
treefarmer87
i might get 1 of them instead. i like the fact they are smoother :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
