When did dimension lumber start?
Started by Brad_bb, October 28, 2010, 12:24:56 AM
Brad_bb
I live in an old farm house that is framed with actual 2" lumber.  I'm trying to get an idea of when it could have been built.  It was not built from local trees.  The wood if very dark brown now.  I'm guessing it could be fir.  When did dimensioned lumber start or become prevalent?  My area would have used lumber brought in from elsewhere as there aren't much here for trees.  I'm sure there was oak at one time, long ago, but no pine or fir.  Joliet, IL.
kderby
I'll bet that the lumber is Douglas Fir also called "Oregon Pine."  The trains supplying the west coast could be loaded with lumber for the back haul to the midwest.  I am not much help on dates.  Is it circle sawn or band sawn?
Some one here can give a description of the beginnnings of balloon frame homes, that is another milestone.  I think balloon framing started in the midwest.  That led to the demise of timber frame dominance.  I do not know the period that occurred.
Kderby
tyb525
My family's house has full 2" framing, all of the ones I've seen during remodeling, etc., are oak or other hardwood. I know it was cut from our woodlot, most likely. The house is over 100 years old, but it is not balloon framed (as far as I know)
laffs
think there was  something on the history channel about that, thinking late 40s ,plywood has been around since mid 50s
Brent
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Bridgewright
Do you mean stick builidng ?
Hereabouts, it began to be peppered in in the mid 1840's, but did not gain dominance until a good twenty years later.
Of course, joined heavy timber continued to be the choice even after that, for barns, mills and public buildings. (Town halls and churches)
Brad_bb
Rooster
One of the Wisconsin Historical sites near Greenbush has a timber-framed, waterdriven saw mill that was re-created to replicate the one that was used in the mid to late 1800s. It is a muley saw with a single saw blade, but it's not a band saw.
http://wadehouse.wisconsinhistory.org/Explore/Sawmill/Riverview.aspx
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Yup, another system before bandsaws and circle mills they used sash sawmills. Basically like a manual pit saw, but in a frame like a sash window. Nothing high tech about it at all and it was usually all wooden. When it wore out, you sawed out another one... The saw marks would look similar to a bandsaw?
You powered it with this if there wasn't a river handy.
It was even portable so you could haul the mill to a new site.
Brad_bb
I cannot say the wood is band sawed, but it certainly is not circular sawn.  I think the house was built after 1925, lets say, but not after 1950.  It's just my guess.  It is red brick on the outside.  So I thought maybe the dimensioned lumber date could be pinned down perhaps.
Bridgewright
The Herrling Sawmill was replicated by Rondout Wooodworking of Saugerties NY, (a company that specializes in millwrighting and preservation work) together with a cadre of hired gun journeyman timberframers, (most of whom were hewers) myself included.
The small scantling sawn stock in the frame was to look like it came off a muley, this effect was created by using a Mizer with a consistent feed, and using sharp blades with one tooth intentionally bent over.
Mooseherder
Our first house was built with full dimensional lumber in 1953.
It was Dade County Pine.
laffs
theres a working sash saw in derry nh its powered by a water wheel.
its a museum they run it on weekends. jim may have seen it,its not far from him
jdtuttle
Have a great day
Carpenter
Thank you for posting that jdtuttle.  I found it quite interesting as well.
Mad Professor
O.K. I'll bite when did a 2 X 4 " become something "lesser" sort of 1 3/4" X 3 X 3/4"?
Is 5/4" 1.25".  If not WHAT is a 2 X 4 "  "  "   Note the quotes
jdtuttle
Yellow Pine Manufacturers Association Grading Rules adopted January 24, 1906:Sizes of Boards 1 inch S1S or S2S to 13/16 inch. Sizes. Dimension shall be worked
to the following: 2 x 4 S1S1E to 1-5/8 x 3-5/8 inches; 2 x 6 S1S1E to 1-5/8 x
5-5/8 inches; 2 x 8 S1S1E to 1-5/8 x 7-1/2 inches; 2 x 10 S1S1E to 1-5/8 x 9-1/2;
2 x 12 S1S1E to 1-5/8 x 11-1/2 inches. Dimension S4S 1/8 inch less than standard
(3)
(4)
size S1S1E.
jim
Have a great day
Jim_Rogers
Mad:
I do remember 2x4's being 1 5/8" x 3 5/8" but I don't remember when they went to 1 1/2" to 3 1/2".......
Quote from: Jim_Rogers on November 09, 2010, 08:20:22 AM
Mad:
Right after I built my house in 1968.  :) :)
Have had to put up with the larger size when adding on since that time.
Quote from: Mad Professor on November 08, 2010, 08:45:28 PM
That info is well documented in the link jdtuttle posted. It is a lengthy, but good read.
John S
I also remember 2x4's as  1 5/8" by 3 5/8' back in the 70's.  I think it changed to
1 1/2" by  3 1/2" sometime in the 80"s.
2018 LT40HDG38 Wide
