# 1 saw bench. build
Started by weisyboy, October 10, 2010, 07:34:10 AM
weisyboy
the spacers is so i can get the forks between them, never thaught but it probly dose make them last longer, 12 months an they are rotten.
god bless america god save the queen god defend new zealand and thank christ for Australia
www.weisssawmilling.com.au
http://www.youtube.com/user/weisyboy?feature=mhee
http://www.facebook.com/profile.php?id=100000696669814&sk=photos
weisyboy
looking better every day.
even cut some square boards today.
customsawyer
www.thecustomsawyer.com
Hilltop366
Square boards !!  Now your just showin off  :D
All kidding aside  smiley_thumbsup
buildthisfixthat
hey weisy waiting for a second wind to power the carriage have you sawed any more lumber with the bench saw?
shop built bandsaw mill
weisyboy
put the high speed pto on the tractor, the bloudy thing spinns backwards.
will get down there again today and do some more,
i have been offered a motor from a bedford truck to power it, so might go that way yet.
weisyboy
Sure helps to see what you have in mind, to see the video.
I can say it sure beats using a pit saw to break down a log.
Not much to protect your eyes when facing that saw blade, nor to keep your arm out of the blade. Other than that, you will soon develop some stronger leg muscles to push that carriage uphill easier.
But I suspect this is just the beginning of your mods to make it better.  ;D
Wish you well, and whole.
sgschwend
Weisyboy, does that mean you will have the time to make a slabbing video?
I will be setting up the Lucas Slabber in about 2 weeks.
That would be great!
Steve Gschwend
sjgschwend@gmail.com
paul case
good video weisy,
that kind of work will make an old man out of ya. the manual feed and log turning seems like it takes some time but even with hydraulic turning capabilities and elec forward and reverse on many bandmills it still takes an everage of 5 to 7 minutes to saw out a 7x9 10' tie with 2 boards on each side. your set up will get better the longer you use it and with some modification it will get easier on you.
good thread and good work.  pc
pc
weisyboy
i wont be pushen it for long,
i fixed the binding yesterday, am hoping to get the feed cable on today, and will get 2 pulleys threw the week, to hook up the power feed. 8)
will also change the dogs and that after that, i dint wanna spend to mutch time on the trolly till i new it was gunna work properly. :D
paul case
thats how i work too, conquer 1 thing at a time.
the trouble you have pushing in the cut has had me thinking on my drive home.is that from saw chips on the track or is there another hang up?  if it is chips it may make a difference in the cut. a simple wiper of some kind would be an easy fix for that. the old circle mill that i had ran a 2x4 in a stake pocket on the trolley that drug on the track to keep that stuff knocked off. pc
pc
weisyboy
the binding was caused by the cradle pitching towards the blade with the force of the blade cutting,
i put 2x 6x2s on the back side and it went threw no trouble,
i put the bottom gaurd on cos it was covering the rails in chips, nice that you are thinking about my probelms. ;D
paul case
sometimes too much thinking and not enough solving though.  pc
pc
weisyboy
im guilty of not enough thinking and to mutch doing, turns out you have to do a lot of things twice.
Very nice Weasy,what do you use to sharpen those carbide bits.Do hope you told the railroad your using a section of their rails.Glad your putting on a power feed that pushing gets old fast.Frank C.
weisyboy
sharpened with a diamond stone in an angle grinder or the mini grinder from the lucas.
we'v got heaps of that railway line, 50 20' lengths or more, used to make cattle grids outa it.
8)
buildthisfixthat
great clip of the saw ,about the cable feed i know you will be using a drum ,  i am using a drive pulley on a gear box that the cable loops around .however the pulley slips on the cable ? any ideas how to prevent the cable from slip on the pulley
tyb525
buildthisfixthat,
Have you tried putting more wraps of cable around the pully?
weisyboy
more wraps on the drum or rough it up with sompthing to give it more grip, also more or less tention will help, gota find the right amount.
buildthisfixthat
weisy that railway iron in the us is worth about five large  5,000± my cable drive is a single belt pulley i was going to add some welds on the pulley but dont want to chew the cable its tight but still slips alot what do you think about  rubber wheel instead ?
Build&fix,are you talking about a flat pulley for your cable? Too heavy a cable on too small a pulley will tend to slip.Say if you had 3/8 cable on a 10 or 12" drum three or four wraps slippage shouldn't be a problem.I also like to have a heavy spring on one end to keep the cable tensioned. Frank C.
weisyboy
your cable may be to tight,
you drum may be to small.
a rubber tyre on your drum will help but wont last long.
what is the size of your drum?
buildthisfixthat
frank thanks for youre help you are correct it is what i have is a 3" v belt pulley with 1/2 cable i tried a flat 3"x 4"wide and the problem with that was after a few turns the cable was walking on top of itself and binding i tried 1 wrap and 2 wraps ,so i put the v belt pulley back ,i have some 3"semi hard rubber wheels with steel centers like used on a truck scale i can weld a large washer on make like a pulley ,think that would work?im restricted to a small pulley and it be some doing to downsize the cable
weisyboy
i say give it a try, it wont cost mutch and may solve your problem.
