Mileage Converter
Started by DouginUtah, October 08, 2010, 05:28:38 PM
DouginUtah
Slow day here so I'm putting this up for anyone who wants to be able to quickly convert between US and Canadian values regarding mileage calculations. It requires Windows and .net framework--which is probably on your computer.
Here are some screenshots:
This is what you see first when you run the program.
If you click on "Convert Using US Values" you will see this.
If you click on "Convert Using Canadian Values" you will see this.
This is a sample of what you see when you fill in the three Inputs and click on Calculate.
This download is available at http://www.xmission.com/~sherwin/download1.htm . Scroll down to the bottom.
The program does not make any entries to the registry.
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
