dumb stuff
Started by Kedwards, August 29, 2010, 04:22:04 PM
Kedwards
Yesterday while sawing I was changing out the blade and had to replace the blade on the woodmizer. I did my normal "throw the blade in the direction away from you to not get injured unraveling" picked it up and at that point have to turn the blade inside out to make it travel properly on the woodmizer. In front of the customer and of course not wearing my chaps to protect my shins rotated the blade and it hopped over my shoe and hit me in the shin puncturing a small vein..It squirted blood 2 feet on to the customer shoes and on the ground. I stop the bleeding and all is fine but this definitely set my mind to safety over staying cool. It freaked out the customer too which should help in the mystique department how dangerous sawing can be.
Anyway.. My bone head move from being careless
His thoughts tumbled in his head, making and breaking alliances like socks in a dryer without cling free
kelLOGg
The Forestry Forum is a good, safe and supportive place to confess our mistakes. It's admirable that you chose to do so. I know mistakes (I lost the tip of a finger in a sprocket/chain :-[) have been my best teacher. There is info on the FF as to how to coil/uncoil and reverse bands - use the search function. I'm not very smooth at it yet but good enough for me.
Bob
fishpharmer
Kedwards, I doubt there is a person with a bandsaw that hasn't had some sort of "band" injury. I've had a few minor scrapes, no spurting blood yet.  It could happen real quick.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Dave Shepard
I have a cut that runs the length of each finger on my right hand right now from a band incident.
maple flats
You guys with band mills would be wise to wear kevlar gloves to handle them. Us swingbladers don't have the issue with a blade with a mind of it's own.
Kedwards
Quote from: maple flats on August 29, 2010, 07:30:54 PM
I run a swinger as well.
Dan_Shade
anything sharp (and somethings that aren't supposed to be) can cut flesh.
I fold and unfold my .045 gloves without gloves.  It keeps me on my toes :-)
Be safe out there.
Dan
lots of dull bands and chains
We've all been band bit,just embarasing in front of visitors.I think your safer pulling the hair on a tasamanian devel's $ss than uncoiling coiled bands.Yea I know theirs a way to do it.Frank C.
Dave Shepard
My favorite technique is the "toss it on the lawn as far away as you can".  :D I've never done it, I've only been a witness.
terrifictimbersllc
When in shorts and not wearing gloves, grab the blade tightly in the gullets, with the teeth facing you, then flip it.  Also close your eyes tight.  Not that I would recommend doing this however.
sandhills
Gotta say first I've never been around a band mill, but just reading what you guys are sayin I'm feelin a whole lot more comfy snugglin up beside that 52 incher on my circle mill :D :D :D :D
Banjo picker
IMO that throwing the bands is for the birds....mine are over 17' long and I have never thrown one and don't plan on it...no need to.....it is wise to wear gloves esp. with a newly sharpened band.  If I can handle it without gloves, I might need to send it around another time on the sharpener....Tim
Kedwards
Quote from: Banjo picker on August 29, 2010, 09:22:02 PM
I have done this probably 500 times without an injury. The only injury is from my stupidity in wearing shorts and having to reverse the way the band blade came packaged from the manufacturer.
Care to share how you un-package your 17' band blades? I posted as a cautionary tale to use safety equipment and don't get lax. I  would never have these things unwind near me or my throat.
Kedwards
Quote from: terrifictimbersllc on August 29, 2010, 08:59:04 PM
Were you hiding in the weeds saturday?   :D
Cedarman
When inverting a blade, start with the teeth toward you so that when the bottom flips up over your shoe the flat side hits your leg and leaves a mark, but not a hole.
I have uncoiled so many blades that it seems second nature.  I have never used gloves and can't remember getting cut.  Like riding a bicycle, after a while you just do it without thinking how you do it.
woodmills1
I did the 045 blades no gloves shorts no shoes
the ones for the 70 at 1.5 inch .055"  gloves long pants eyeware
Dan_Shade
I only wear gloves when temperature dictates it.
I put my fingers into the gullets and hold onto the blad with my thumbs.  I have a video on youtube on how to fold and unfold blades.  It isn't hard after you learn how to do it.  I recommend learning while using a long lawnmower belt or something like that.
http://www.youtube.com/watch?v=btOSZNjWMyk
(never mind my 10 and 1 (should be 10 and 2) being backwards, I didn't want to record it again!
p.s.
Uncoordinated people, please disregard my video and comments.  I've gotten quite a bit of email scolding me for not wearing gloves, not wearing safety glasses, and apparently some folks find it offensive that I'm not a sissy :).   These things are potentially dangerous, but pretty tame if you know what you're doing.
This was with a .045 band.  I've been told the .055 blades are much more difficult to bend.
Kedwards
Thanks..
This is helpful..
Be safe.. wear the right equipment and do it right.
Banjo picker
Quote from: Kedwards on August 29, 2010, 09:40:55 PM
That video of Dan will have to suffice for now as I don't even do pic. little less video...I will say that it is easier to learn on the .041 or .042 bands than the .050 or bigger bands that are out there now...esp the coiling part....Thanks Dan....Tim
Dan_Shade
You can also "start the bend" by pressing the "top" of the band against something instead of snapping it.  I often use a tire or a log to break a band over, rather than snap it.  If I have an unruly customer, I snap it, and make a comment about having anatomy that is tougher than a sharp knife  :)
tazz
Another way to coil the blade is by holding the blade in front of you with one side touching the ground. Put your foot on the part touching the ground and with your hand grasping the top side, twist your wrist 360 degrees.
http://www.youtube.com/watch?v=Ulfhm0wiKbk
Okrafarmer
I'll probably wear gloves until I learn to do it, then I will try to do without, since gloves are a pain in the hand, and imo, I am usually safer without gloves than with in most circumstances. There are a few exceptions, and I have taken to wearing one glove while changing chain saw chains, especially on Husqvarna's and climbing saws.
Now selling Logrite tools!
Dan_Shade
does anybody know how to fold the small 1/4" bands into the 6 rings?
