Mills gone
Started by DextorDee, August 27, 2010, 02:40:26 PM
DextorDee
The last of my oak I cut guess its time to stack. My back don't like this. I miss my youth :'(
Yep 78 Dodge powerwagon :D
No mill just sawdust thats a lonesome looking site. :'(
Ken
KI4BMW
North East Georgia
I always wear a back support belt when sawing.  Whether I'm handling lumber or not.  I'm 67 also.   ;)
paul case
my back dont like all that handling lumber either and i am only 35. i cheat and use the fel as much as i can. i have gotten pretty good at it.
i feel for you guys that dont have one . they really save on the back .  pc
pc
Stephen1
Quote from: Magicman on August 27, 2010, 05:15:09 PM
is that the wide fat belt that you see a weight lifter wear?
Quote from: Stephen1 on August 27, 2010, 06:04:23 PMis that the wide fat belt that you see a weight lifter wear?
Yes kinda.  It came from the weightlifting department.  Mine is 3½" wide.  I always wear it when sawing and when I am working on something below waist height.
This is a well used belt
I also wear one when I'm on the tractor.
Never mess with a black belt sawyer.Frank C.
Meadows Miller
Gday
:D :D :D :D :D Thats a bloody good one i got a good laugh outa it Frank  ;)  ;D
and what Paul said x2 I had to hand load afew 4000bft loads last year by hand while the chamberlain was out of action it aint no fun  ;)
Regards Chris
4TH Generation Timbergetter
You guys move too much at once, I only try to move 400 bf at a time. :D ;)
Most of mine goes up overhead in the barn. :/
I haven't moved any for 10 years now, gotta use up current inventory. ;)
Older fellas have to use their heads insted of their backs,I never let slabs or boards hit the ground everything gets put on a truck/trailer or heavy duty saw horses, no bending down to pick up heavy loads.Work smart Frank C.
If you don't work with your head, you won't work tomorrow.   :D
DextorDee
I need one of those belts, if you hear a strange noise its my back screaming :'( :'(
Maybe Tractor Supply or Home Depot?
Ken
KI4BMW
North East Georgia
sandhills
I'm 37 and share your missery.  Pretty sure my back is the weakest part of my body anymore!  Grew up throwin little round bales of hay all day everyday all summer, kinda woulda thought that woulda helped, guess not.  I do have a belt that's quite a bit wider than MM's, really like it but only use it after I really screwed everything up, maybe should try it beforehand :D :D
So, you stash'n and hording the oak Dextor, or sell'n?  ;D
DextorDee
Guess I'll stash and horde the oak. Maybe someday get around to using it. Seems like since I retired I do less and less. I still want to do things, my get up and get started just sorta disapeared. Back trouble has been one of the worse things that has happen to me. The back problem layed me up for so long the rest of my body went to flab.
Its easy to get outa shape hard road back trying to get back in shape. :'(
Its good to get on the forum and read about some you guys as old as I am and older still going strong. 8)
Protect your Back!
Ken
Ken
KI4BMW
North East Georgia
Okrafarmer
I regret to say, Ken, that although I've looked at your mill quite a bit we've been so flat-out busy cutting trees down and such that we haven't set it up and run it yet. We are sure looking forward to it, though. I'll try to get some pictures up when we do. We'll put it to good use, I assure you!
Now selling Logrite tools!
