pressure washer
Started by Cedarman, August 26, 2010, 02:05:29 PM
Cedarman
I have a Briggs and Stratton  Elite 3100psi.  It is now leaking around the gaskets on the pump.  Called BS to get a kit to rebuild.  Was told no can do, must buy a new pump at over $200 .  They gave me a local dealer to call.  He said he has had a 1/2 dozen pumps go bad on that BS PW.  Can't repair as far as he knows.
I don't plan to buy a replacement pump as it will most likely go bad. The dealer indicated poor workmanship.  He also said it takes funny d shaped O rings.
If I was a dictator with ultimate power, there would be a few less engineers around.
I have cleared away most of the blue air.
Anyone have any experience fixing one of these pumps?
I need to get a new one because we use it quite a bit to strip bark off cedar logs.
Anyone recommend a good one.  3000psi or more is needed.
Warbird
I'd start here:
http://www.ppe-pressure-washer-parts.com/briggs-&-stratton-breakdowns-parts
It has annoying audio guy talking but looks to be a great resource to start with.  Good luck.
sawguy21
Repair parts are not available for many of the entry level pw's and yours is one. Parts and labor cost more than a new unit. A good unit will cost some bucks but will pay off if cared for properly, look for a General, Cat, or Blackhawk pump. General repair parts are the most reasonably priced.
mr T
Tractor supply stores have them on sale this week Sounds like a good deal
Coon
Get yourself a Karcher pressure washer they are well worth the money they want for them.  You can even get deisel models....
www.karcher.com if you wanna check them out.
Onthesauk
Cedar,
Might be worth at least making the question of these folks.  Had a friend repair on 20 years by these folks.
Dalco Pressure Washers
3010 Old HWY 99 S. Rd.
Mount Vernon, WA 98273
(800) 877-6273
(360) 428-3850
(360) 428-6916
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
