hy-stat fluid???
Started by shinnlinger, July 07, 2010, 10:14:17 PM
shinnlinger
Hi,
I recently did this.
http://www.youtube.com/watch?v=wnWWVLSkbIM&feature=autofb
and I also use it to pull my sheep tractor around with it.  It was a 15 horse Airens lawnmower at one time.  What fluid goes in the hystat unit?  Hydraulic?
How hard am on the unit doing what I am doing????
Thanks.
Dave
Shinnlinger
paul case
hydraulic should work some use atf whatever you put in should help just make sure that its not so airie as whats in there . that will help wth the front comming up like that. pc
pc
