How to keep boards from falling over when edging on WM?
Started by terrifictimbersllc, May 28, 2010, 07:46:33 PM
terrifictimbersllc
When I'm edging on my WM, I wish the boards kept standing up after I put down the clamp, long enough for me to walk around to grab them and keep them vertical while I clear the edgings and proceed to sort out the finished ones or flip them over.  It would be great to have something other than the clamp, or the customer, to hold them up.  Or a way of running the clamp after I walk around to hold them up myself.  No matter how many times I ask the customer/helper to hold the boards up until I walk around,  they always seem to lapse into clearing the edgings first while I wait and wait for them to remember to hold up the boards so I can come around.  I remind once or twice but draw the line at lecturing or shouting instructions( :)).   It would save a lot of time edging if something under my control were to hold up those boards after the clamp is released and lowered.  Any ideas?
terrifictimbersllc
Just realized that a lot of the problem (but not all of it) of boards tipping over comes from the boards which are unedged on both sides, and that I have a choice as to which side to place down. One way and it will tend to tip to the outside (bad) and the other where it will tend to tip towards the supports (good). Maybe choosing the latter would help out.
LOGDOG
I'm guessing you have the two plane clamp? I don't. I have the old fashioned flip down clamp but I've sawed with mills that have the two plane clamp. One thing I do is just back the clamp off maybe a couple/few inches so that I have enough slack to get the boards loose. If they tip, they tip into the clamp at the top and are back stopped at the bottom by the boards towards the rail. Something else I do is edge in batches when using the mill. Edge by size of flitches that are close to the same. It lessens the number of boards in the batch and makes for easier handling. If edging a large group of boards, I'll put those that have one edge already ripped on the inside. They're usually more stable and don't need to be flipped, just have the one edge ripped off as I work down through the dimensions. The boards that have two edges and need to be flipped will be on the outside edge where they can tip over and can be flipped with ease because they're loose from the others.
pineywoods
Yeah, turn all the boards to be edged so they will tend to lean toward the inside. Also, I find it helps to edge while sawing boards from the cant, just stand the flitches up beside the cant. Another trick I use is to toss a 4 ft long piece of 4X4 up against the flitches.
LeeB
Pull the trim off before you jig back and stack from narrowest toward the dogs with the widest board toward the clamps. As the others have said, turn the bark toward the dogs and it helps to have a 3 or 4" cant between the flitches and the dogs.
logwalker
I ran a 2 pull ropes from overhead thru pulleys then back to the head of the saw and down to the lever. So I can run the flap clamp in or out while I hold the boards.
there are many times when you can use the clamp. It is one of the best things I have done to the mill. The picture is the wooden handles tied to the end of the cords.
LOGDOG
Quote from: terrifictimbersllc on May 28, 2010, 07:46:33 PM
  No matter how many times I ask the customer/helper to hold the boards up until I walk around,  they always seem to lapse.........Any ideas?
Yup, just stand there and wait until they stand them back up.   ;D
Since I've only used a two plane clamp, standing and holding flitches generally isn't a problem for me.
woodmills1
of course, :D, once you gets ya DanG self an edger that will no longer be a problem
and the "helpers" be all the way down at the other end :D :D :D
paul case
an edger  or some DanG youngan with a half a chance of remembering. i must have amnesia with a side order of alzhiemers or i just like to see history repeat itself!  :Dpc
pc
terrifictimbersllc
Thanks for all your suggestions.  Yesterday was bark side toward the supports and what a difference.
