What kind of tool is this?? (yard sale find)
Started by shinnlinger, May 03, 2010, 09:30:44 PM
shinnlinger
I don't know what it is and have asked a few folks.  I figured I could replace a point with a pencil and use it use it as a scribe as it has 2 vials or as a big adjustable bevel gauge or compass as it has a very positive lock on it.  It has a dial indicator for the amount of degrees it is open also.
Any ideas?
Dave
Shinnlinger
laffs
thats a washing machine. im not sure what that yellow thingy is
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
ljmathias
I think the big yellow thing is a tool of some sort- doesn't look to be alive or moving so I guess I wouldn't whack it with a hammer.  ;D
Good luck...
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
whiskers
It's a combination compass, level and washing machine finder.
many irons in the fire.........
Lil Badger Creek
What a cool tool! looks like a large scale version of an angle finder. Great for finish work. Your find has more uses.  -Stephen
Stephen
LeeB
The kind you put in a yard sale becuse you don't know what to do with it and hope somebody will buy it so they can try to figure it out.
maineframer
It is clearly a combination compass-level-with a built in accuracy gauge/timer and or watch.
David
sawdust
Given the color it is obviously a Caterpillar brand Stuck-o-meter. Gives accurate readings of depth of stuck and whether you are stuck level or half a bubble off.
comforting the afflicted and afflicting the comfortable.
Dave Shepard
Sprucegum
 :P read 240 times and still no concise definition of the artifact  :o  :o
I'd make a wise comment but I got to go get something to eat....no thanks, I don't need a
Grit-o-meter
ljmathias
I think Shinnlinger subconsciously figured it out- hence the placement on his (or his wife's?) washing machine: it's a washing machine level and adjustment tool...  now you just have to figure out how to use it   ;D :D ;D
Lj
LeeB
Jim_Rogers
Definition of an Inclinometer:
Inclinometer is an instrument for measuring angles of slope and inclination of an object with respect to its gravity by creating an artificial horizon. It is also known as a tilt sensor, tilt indicator, slope meter, slope gauge, gradient meter, gradiometer, level gauge & level meter. Inclinometer is commonly used in different industries like Aviation, civil engineering, Government, Marine, Military, and Transportation for platform leveling, boom angle indication and slope angle measurement. The tilt angle range is the range of desired linear output measured in degrees. Important specifications to consider when searching for tilt sensors and inclinometers are the tilt angle range and number of axes.
LeeB
Jim_Rogers
LeeB
That makes it sound even better then.  :D
shinnlinger
That is a nice definition Jim, but do you have any idea what the tool is???
Shinnlinger
Dan_Shade
does it have a manufacturer's mark on it?
the color looks like "Stanley"
My "guess" is that it's simply a combo tool/washing machine finder like whiskers said!
lots of dull bands and chains
shinnlinger
I don't believe it has any markings, but it is out in the barn right now because after it found the washing machine and the kitchen table a few times my wife thought it should go find the rest of my tools... and she said it is a clinometer, no IN the house about it....
Shinnlinger
bill m
Check out this web site.
  http://www.washerhelp.co.uk
I think they might be able to help.
Jim_Rogers
Well, I googled inclinometer and then selected images to see if I could find a picture of one that matched. After viewing some 40 pages of images of all kinds of inclinometers I'd have to say it probably isn't one, but I'm not totally sure.
I didn't find anything that exactly matched.
Jim
Holmes
Looks like a dial type protractor/ level. Old like a dial type telephone.  Holmes
Think like a farmer.
shinnlinger
Holmes,
Lets assume you are correct.  Who would have used it and why????
Shinnlinger
Holmes
shinnlinger
I can't believe it is a timber framer's tool as I have never seen such a thing, a co worker of mine with extensive framing experience (worked with Ed Levin for years) has no idea what it is, and out Forestry forum expert, Jim Rogers doesn't know what it is. Besides, it will have pretty limited use in TF applications...  It is no BIG AL......
hhhmmmmmm....
Shinnlinger
