skidder weight?????
Started by aksawyer, April 18, 2010, 03:01:35 PM
aksawyer
Going to look at a JD440 this next week.Was wondering if anyone could tell me the weight of it .It is a 1969 model.Tkanxpks    aksawyer
chucker
7 ton without chains ... add 500 per set (2) for each axel... if the tires are loaded with fluid then theres an extra 30 t0 50 gallons per for that also  but not to exceed 17000 or 8.5 tons. but this is just a guess???
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
Brian_Rhoad
According to my owners manual my 440 weighs 12,000 lbs. Liquid adds 610-784 lbs per tire depending on how much calcium is added. Each tire holds 61 gallons.
IMOWOOD
I have a 440C and with chains on all 4 its about 14000
Bobus2003
My 440 With Chains and Loaded tires, Fuel Fuel tank, tips the scale at Just Shy of 16,000lbs.. Heavy but not too bad.. still able to haul it around on a 20K GN and a F350 or F450 Ford Truck
CX3
Chuckers right on with what mine weighs.  Move it around easily with a good gooseneck and one ton
John 3:16
You Better Believe It!
