Made Carriage for Alaskan Mill to run on my Lucas 6-18
Started by Peder McElroy, April 06, 2010, 10:50:47 PM
Peder McElroy
I have been trying to figure out how to make a slabber for my Lucas mill and don't have the funds to buy the factory setup. So I did some thinking and came up with a rolling carriage to hold an Alaskan mill . I hava a 36" one an a 48" mill and they both work on the mill rails and best of all I can just pick it up and place it on the rail with out having to remove the motor setup of the Lucas mill,just move it to the other end. If I can ever figure out how to shrink me Photos I will post some photos. It cost me $24.00 and some angle iron that I had kicking around.  Peder
brdmkr
Peder, I am hoping you figure out how to shink those photos.  I'd like to see what you worked out.
Stephen1
We would love to see your photo's. You do not have to shrink them, follow the directions for adding photo's, it really is so easy to do now, compared to when we had to resize before downloading. Jeff has set up a very easy system now.
Peder McElroy
I loaded Photos in my gallery but can't find them. Peder
js2743
looks like a neat idea, do you think you could use a vertical shaft motor, put a sprocket and clutch on it and fix it to run a chain on same set up as you have made here?
fishpharmer
Peder I like that homemade slabber setup.  Well done.  You may have to ask Jeff or Tom to setup your photo gallery, I did.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Peder McElroy
Yes js I guess you could put about anything on the carriage,but I was keeping it simple. You use the lucas system to raise and lower the saw the same as when cutting with the lucas motor and blade. I think it's all about keeping it simple. I did manage to load some photos there in my gallery. if you can find it. Peder
