Popple-Poplar-Aspen question
Started by bkellyvtme, March 08, 2010, 01:41:41 PM
bkellyvtme
Are these used for fuel such as woodchips, pellets, (not firewood I'm just about certain). Is it considered a softwood or hardwood? Any other uses for it?
rcanderson1968
As far as it being used for pellets - I've heard reports that some pellet mills in Maine do not use aspen as a feedstock.  I've also heard reports that pellet mills in Northern WI are using a heavy dose of aspen as a feedstock.  So I guess it depends on a particular pellet plant's "recipe".
"...It's a good rifle - and killed the bear that killed me.  Anyway I'm Dead.  Yours Truly, Hatchet Jack"
If it were up to me, and it ain't :D , I would use species that are inherently low in moisture content when green. Like white cedar, jack pine, white spruce, tamarack and white ash for starts. ;D
Quote from: bkellyvtme on March 08, 2010, 01:41:41 PM
Yes they are used for fuel and yes, they are hardwoods.
99 % used as pulpwood the other 1% for dried kindling to light your hardwood if you can't get good cedar or yellow birch bark. :D Well I guess some is sandwiched in between hardwood veneer in your plywood and go into aspenite and OSB, that kind of stuff. :X No wonder the hurricanes take out so many modern houses. By now I've said too much.
Jamie_C
About the only market for Aspen around here is for the local pellet mill ... they supply pellets to a town in Sweden or Finland.
Right now the marketing board wood yard is about stuffed with aspen pulpwood, already scaled and sold. Just waiting to be hauled. A while back I never saw a stick up there. I assume it came in just before closures and the yard is beside two truck routes, one route 5 miles from Maine. I think this goes to Maine to Domtar in Woodland. I know they had a contract to scale and buck a year ago. I don't think they are getting rich off the processing, but keeps the cash flowing. :D
Maine372
headed to maine it might go to LP for OSB too.
Possibly, but I think it's Domtar. There is also Huber nearby. I believe Domtar pays trucking on the contract.
