AC hydraulic unit for LT40 hydrualics
Started by Kelvin, March 02, 2010, 06:48:12 PM
Kelvin
Howdy all,
I know some of you have added a hydraulic pack to speed up your hydraulics and i saw a local ad for 1 1/2hp hydraulic pack w/ tank, looks complete.  My micro switches gave up the ghost years ago so i have a switch i flip whenever i want to run my hydraulics, so switching over to AC wouldn't be that different.  Was wondering if this sounds big enough?  1 1/2HP?  It would be nice to have the speed and not worry about the dumb power strip on the mill and having to move the mill head back to the strip,  and having to clean the strip, and monkey with the grounds... etc.  The guy wants $75 for the unit, and says its in good shape.  What do you think?  To small?
kelvin
pineywoods
Mine is ac powered, depends how big a pump.1hp and 3gpm pump is marginal. I built a 2hp unit for a friend, that's better, but still not enough. I think Bibby's is even more hp. I think a 3hp motor and a log splitter pump (2 stage) would work nicely.
Bibbyman
Our unit is 7.5 hp with 6gpm pump at 2000 psi.  LOTS of speed.  Often far more than you need.  I end up feathering the valves a lot of times and still sometimes things get slamed around.
We put an hydraulic turner on our old manual LT40 as well as one tie board - the old blade style.  I think the pump we used had a 2hp 220v single phase motor and a pump of about 1.5 gpm.  It worked.   I don't know if I talked about the conversion here on the forum or not.  It would be "way back" in the early years.
Sawing since '94
