Welding on a tire rim
Started by T Red, March 02, 2010, 04:04:53 PM
T Red
I'm sure we all know not to.  This is an interesting video as to what happens.  I had no idea.
The delay on heavy equipment tires is surprising.  Worth a watch.
http://www.youtube.com/watch?v=jBUVzgCHHuA&feature=player_embedded#
Tim
T Red
For those of you with dial up here's what happens.
They only welded on the rim for a few seconds.  A chemical reaction takes place in the actual walls of the tire after heat is applied called pyrolysis.  For a period of about 2 minutes the inside of the tire heated up, 500+ degrees F, and the pressure  increased just as dramatically.    This reaction continues and degrades the walls of the tire.  Eventually it explodes due to the pressure and weaken walls.
On heavy equipment tires it has taken 20+ hours after the initial heating for the explosion to occur.
Tim
Qweaver
Watch a car race and notice that the brake discs glow red hot. Red heat = about 1200 deg F.  I've run several races that went to after sunset and I could see my brakes glowing red.  I wonder why we don't get the same thing happening?  I sure would not weld on a mounted tire rim after watching that.
Hmmm?  Seems to be in the same category as heating a can of beans with the lid still in place.  ;D ;D
D Hagens
Quote from: beenthere on March 02, 2010, 06:27:51 PM
So I take I wasn't the only one that did this as a kid. :D
Slabs
Quote from: D Hagens on March 02, 2010, 07:31:14 PM
Yep.  Them hot beans can also be classified as shrapnel.
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
zopi
Saw a dude heat beenie weenies in the rod oven once..when he opened the can all those angry little legumes jumped out and whooped him....little bean shaped burns all over his face....:D
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Coon
Last fall we had a guy in the field next to us go under an overhead powerline with a tractor and grain cart.  He was heading over to the combine to top off his load of grain and all of a sudden BOOM al of the tires on both the tractor and grain cart blew along with grain flying in every direction.  It was investigated and found the powerline arc'd the grain cart due to being too close to the line.  The operator ended up in the hospital due to shocking of  nervous system.  He was observed and is ok.  The power company was sued for all damages as it was also found that the powerline did not meet the minimum height requirements.
Brad.
footer
You want to hear a good one. I worked about 16 years in industrial maintenance with a lot of heavy equipment, and more recently, 3 years as a tractor technician for a trucking company where I got a "michelin north america, truck tire technician" certification, and with over 20 years of working directly with heavy equipment and truck tires, this is the first time i have heard of this.
I think thats what happens to airliners when they have to brake hard in an emergency. Over heats the brakes, they stop OK, then the tyres blow out from the heat.
CLL
Seen a guy in Vietnam heat a can of ham and lima beans with a little piece of c-4, everyone around him got to taste the beans.  :o
Too much work-not enough pay.
dovetails
Well that explains why 6 of the 8 tires on the truck crane I was running went POW when the boom brushed the overhead power line! Didn't feel a thing,would not have known what happened if another worker hadn't noticed the power line swaying.
Good thing the outriggers were down,or it would have been on it's side.
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Stan snider
Footer, I'm the same as you. I had no idea this could happen and am far from a novice repairman. I have been aware of the power line contact blowing tires but figured it was arcing to ground.  That was a very good post T RED and could have saved someones life.   Stan
easymoney
i got a chuckle from some of the comments. will try to rember this if i am ever tempted to weld on a rim with the tire mounted. i can not think of why anyone would do it any way especially if the tire was inflated.
The times I've seen it done was when a mechanic welded a short length of pipe around the valve stem to protect it from off-road hazards.   It was tack welded and I guess the guy just got lucky.
Warbird
Which brings up the question that immediately popped into my mind the first time I saw this:  Has this always been the case with tires or is it just newer tires, due to new chemicals/process associated with making tires these days?
dovetails
Quote from: Warbird on March 06, 2010, 02:29:47 AM
In my case it happened about 23 years ago,and the tires were probably about 10 years old at the time, so I would say not just new tires. I have welded up some cracked rims in the past,but never with a tire on them as I welded both inside and outside of the rim to be sure it was solid. Also have welded big washers tocover valve stem holes on tractor rims where they rusted out,again, both sides of the hole,so no tire on the rim at the time.
T Red
Quote from: Stan snider on March 05, 2010, 10:17:17 PM
I'm right there with you.  I've worked with, around, and on equipment for the majority of my life and never heard about this.  That's why I posted, so get the word out.
Now that it has been mentioned I remember seeing someone weld the pipe around the valve stem at least once with the tire on.  The Lord looks after us many times and we don't even know it.
Tim
I welded stuff around all of my valve stems.But I had the tire off. I was afraid that I would melt or weaken the tire in that area.
Tim/South
I have also wielded covers to protect the valve stems.
I wonder if breaking the tire down but leaving it on the rim would be enough?
I have simply pulled the service truck up to the tractor, wielded and driven away.
chevytaHOE5674
I too have welded around the valve stem and other places on a rim. I pull the valve core out and leave it out until the tire and wheel has fully cooled.
The video is accompanied by a lecture.  One of the examples given in the lecture is about one person killed and a helper injured when the dismounted tire exploded.  It had the valve core removed and was pulled back from the rim but still hanging in the rim.  The heat expanded the air so fast that the tire reseated itself and the core-less valve couldn't vacate the air fast enough.  it exploded.
rbarshaw
Here's a good argument for tires inflated with nitrogen, no oxygen, no fire. In hind site it's obvious, heat and compressed air and flamable material in a confined space equals an explosion. I welded on the rims for my first mill with 50# in them and welded for 24" around a plate to mount a shaft to, made several passes, suprised i'm still alive.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
according to that article, nitrogen wouldn't help.  The heat starts a chemical reaction in the material of the tire.  The tire generates its own heat.  Nothing is burning, on the other hand, it is heating without burning.
The explosion is caused by the containment of any gas in the tire, as I understand it.
edwardj_
hmmmm....   not sure i am happy that i watched this.  I work in a motorcycle shop that also deals with argos.  I have had a few instances where i have had to use a torch or die grinder/cut off wheel on the lug nuts.  I guess I will have to pay more attention next time and only use a grinder and stop and cool it fairly often.  Its surprising how many things we do in life only to find out how lucky we were well after we got away with it...
As for the cans of beans...   if you insist on heating them up without opening the top of the can there is a "safe" (notice i put quotes to point out some danger still...) way to do it.  I have done it many times and have never hurt myself or others with any flying debris.  Put a dent in the can...  smack it hard on the side and then throw it in the fire, on top of the boiler, exhaust or whatever.  when the dent pops pull it off and open it.  if ya wait too much longer there is a mess everywhere.
