Author Topic: Log Grab  (Read 9817 times)
Offline VT-Woodchuck
Log Grab
« on: February 10, 2010, 06:50:30 PM »
Has anyone used the Log Grab?  I am thinking about two - one at each end of a log, connected by a chain and using the hook on my loader to lift logs.  I know that some of you have used other hooks... just wondering?
Offline bandmiller2
Re: Log Grab
« Reply #1 on: February 10, 2010, 08:55:49 PM »
VT Chucker,by log grab do you mean a single hook on the end of a chain, you hook each end of the log??I've tried something simular it was hard to get the hooks to stay on the log until I could get back on the tractor. I've had better luck with lifting tongs suspended short under the loader bucket usally you can drop them over the log without getting off the tractor. Frank C.
Offline captain_crunch
Re: Log Grab
« Reply #2 on: February 10, 2010, 08:58:51 PM »
If they will stay in log should work but if they jump out that is a lot of on and off if you are by yourself. Best set up I have seen is what a friend of mine did he welded two sets of ears to his bucket so he could pin on a couple fork lift forks so he can move pallets.logs or lumber. And they are quick to put on or remove
Online Magicman
  • A "Traveling Man"
Re: Log Grab
« Reply #3 on: February 10, 2010, 09:19:47 PM »
I tried a grab hook which didn't work for me.  I use "end tongs".
This is moving a 20' SYP log
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline bandmiller2
Re: Log Grab
« Reply #4 on: February 11, 2010, 07:35:57 AM »
Anyone got a picture of a log grab,thought it what Magic shows on his loader. Frank C.
Re: Log Grab
« Reply #5 on: February 11, 2010, 07:40:03 AM »
Thanks MM, that's what I was looking for. Are your tongs a set that was separated and reworked? Looks like they would work better that the Log Grab.
Online Magicman
  • A "Traveling Man"
Re: Log Grab
« Reply #6 on: February 11, 2010, 07:56:31 AM »
I bought that grab hook and it didn't work for me.  My end tong were built from broken tongs.
The top end tong was made from the broken tong pictured on top.  The other from a smaller broken tong.
Offline breederman
  • getting by the best way I know how
Re: Log Grab
« Reply #7 on: February 11, 2010, 09:53:28 AM »
Bandmiller, there is a pdf link to a pic at the bottom of the first post. I remember using them to skid firewood logs behind a tractor when I was a kid.
Together we got this !
Offline jimparamedic
Re: Log Grab
« Reply #8 on: February 11, 2010, 11:03:34 AM »
A pair of forks would be better you could then move logs, lumber, and slabs.Swinging logs can be quite a problem
Offline beenthere
Re: Log Grab
« Reply #9 on: February 11, 2010, 11:38:08 AM »
Here is pic of the log grab mentioned by the OP.
It looks a bit awkward to use (to me) and needs to be driven in with a maul to stay put.
Online Magicman
  • A "Traveling Man"
Re: Log Grab
« Reply #10 on: February 11, 2010, 01:32:28 PM »
That Log Grab looks to be the exact one that I tried...... >:( >:( >:(
After I cut the hook off, I had a nice piece of chain..... ;D
Offline Horselog
    • Sinking Creek Horse Logging
Re: Log Grab
« Reply #11 on: February 11, 2010, 10:03:03 PM »
The blue grab with the short chain is not intended to use in the end of logs for lifting.  The "grabs" in the other picture of the tractor holding a log are the appropriate tool.  I suppose you could call them grabs, but I've always called them swamp hooks.  The blue No.1 Dixie grab is used in the top of a log, about a foot from the end, and is used in woods operations, not on a landing.  It's just an alternative to a chain or choker for hooking your power source to the log.  Not good for all situations, but when you need it they are godsend.  I use them regularly, they require a skip hammer, also known as a grab skip, to be used properly.  Skip hammers aren't made anymore, I make all of mine from sledge hammer or splitting maul heads.
Benjamin Harris
Sinking Creek Horse Logging and Wood Products
Appalachian Mountains of Virginia
horse_logger@me.com
www.sinkingcreekhorselogging.com
Online Magicman
  • A "Traveling Man"
Re: Log Grab
« Reply #12 on: February 11, 2010, 10:20:13 PM »
Horselog,  Welcome to The Forestry Forum, and thanks for the description of the proper usage of the Log Grab.  I bought it to be used as intended (skidding), but found that either a choker chain or regular logging tongs worked better for me.  It would be very dangerous to use it as a substitute for end tongs.
Offline timberfaller390
Re: Log Grab
« Reply #13 on: February 11, 2010, 11:41:26 PM »
Horse, What are you calling a skip hammer?
Appalachian Hardwoods Lumber and Logging Co.
Peavine Valley Farms
Three Notch Forge Farrier Service
Stihl MS390
John Deere 5103
58 IHC A-162 log truck
70 Ford F600 log truck
75 Ford F750 equipment hauler
IHC 500 dozer
John Deere 440 ICD dozer
Offline bandmiller2
Re: Log Grab
« Reply #14 on: February 12, 2010, 07:25:31 AM »
VT Chucker,swinging loads on a bucket are less than ideal,I've tried most everything,some sort of forks are by far the best.You can buy those pricey clamp on forks or better get two pieces of truck leaf spring bolted on each end of your bucket,they can be removed easily when you want the bucket for bulk.Check past posts theirs volumes written.Frank C.
Re: Log Grab
« Reply #15 on: February 12, 2010, 03:20:27 PM »
M_M's hooks may grab good enough to be safe but in old days  they loaded trucks and rail cars with what was called end hooks and a spreader bar. Till they started useing tongs to load with end hooks created Lots of widows >:( >:( So we were taught they belong hanging on wall. We use to have either a set of tongs or a Swamp hook for rolling tight logs out of their beds as to get chocker around them. But a set of 40 in tongs were not much fun to drag around in brush. Them big tongs make better fire place andirons than tools ;D ;D ;D
Offline Horselog
Re: Log Grab
« Reply #16 on: February 12, 2010, 08:28:49 PM »
A skip hammer has a standard sledge hammer head on one side, and a cone on the other side.  I just use a cutting torch and grinder to make them from a sledge hammer.  The cone acts as a wedge and pops the grab out of the log.  It is annoying at best and impossible at worst to use grabs without a skip hammer, I know several people who got rid of them because they didn't know to use a skip hammer.  It takes a little practice to learn to use them, you direct the cone between the grab and the log and it will pop out in 1-4 hits, depending.
Benjamin Harris
horse_logger@me.com
Re: Log Grab
« Reply #17 on: February 13, 2010, 08:53:21 AM »
I would think  truck tire hammer that has a sledge on one side and a very heavy blunt hoe on the other side would be effective.
Stihl MS390
John Deere 5103
IHC 500 dozer
Re: Log Grab
« Reply #18 on: February 13, 2010, 09:27:43 AM »
Here I am a day late and a dollar short, but I just had to tell you fellows that a skid hook (tongs) will do it all if you have a front end loader on your tractor.
I welded a chainhook on the top of my bucket, dead center
A short piece of chain (about a foot or so long) holds the skid hook on the bucket.  It dangles into the bucket.
I roll the bucket forward and hook the skid hook close to the center of the log. (it doesn't have to be exact)
Then I keep the bucket close to the log as I roll the bucket under the log.
The skid hook will tighten and pull the log up onto the outside edges of the bucket where it is supported by the two edges. (just don't let it roll over the back of the bucket) It will hang there just fine.
To drop the log, I roll the bucket forward and the log hangs from the skid hook and the chain.  The chain makes one point of attachment and allows the log to be turned to fit exactly where you want it to be.
then a swift kick and the skid hooks (tongs) come out.
If you weld a chain hook on the back of your hoe bucket, up there around the pins, You can move logs as if you had a crane.  That's mighty handy for unloading trailers.
That skid hook and a short length of chain is a wonderful tool, especially if you have a backhoe.
Offline Horselog
Re: Log Grab
« Reply #19 on: February 13, 2010, 10:07:01 AM »
That would be a good way to get yourself really *pithed off.   :)  I would not recommend it at all, I have tried using all kinds of things, and unless you have the right tool it's an exercise in futility.  It's things like this that make people not like grabs, not the actual grabs themselves being bad.
Just my take on it....
Benjamin Harris
horse_logger@me.com
