Log splitter followed me home
Started by Magicman, February 06, 2010, 08:34:25 PM
It's toward the end of our "wood selling" season, so the guy at the Rent All store was ready to sell a splitter.  It had been rented out for 21 days and I got it for 1/2 of what a new one would have cost me.  We now have 3 families to cut wood for, so we felt that a splitter would be nice.
I'm ready to start getting my wood out for next Winter.  I hauled it over to the Cabin this afternoon and cut some blocks off of a downed Red Oak.  I just had to try it out.  It's a 27 ton Troy Bilt unit with a 6.5 Honda engine.
It followed me home
My first stick to split
I had fun
Onthesauk
Good price!
I've split by hand for 20 plus years but finally this last couple of years had the neighbor come up with his splitter to help me split.  What a difference!  I'm getting old enough that it isn't just my back but also my hands and legs the following morning.
Always had good luck with Troy Built.
If you get caught up I've got a couple of cords of rounds on the ground right now. ;D
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
TimRB
That's a good catch!  With only 21 days use, it's only just now getting broken in.
If you wouldn't mind taking another picture, I would be interested in seeing how they attached the cylinder to the I-beam.  On my splitter, also a Troy-Bilt, the beam runs the whole length of the splitter, including the length of the cylinder, so the cylinder attaches to the I-beam at the very end.  Your splitter's design saves a lot of weight and also the cost of several feet of I-beam.
Also, is it just me, or is the cylinder not parallel with the beam?
Tim
Rocky_Ranger
Sweet!  Wish I could ever find deals like that...........
RETIRED!
woodmills1
Yes troy bilt is a good name, but it's not now what you think.  It is a marketing arm of briggs and stratton.
Here is a small section of the standards and poors description of Briggs and stratton
Briggs & Stratton�s Power Products segment offers various power products, including portable and standby generators, pressure washers, air compressors, snow throwers, and lawn and garden powered equipment. This segment sells its power products under Briggs & Stratton, Brute, Craftsman, Ferris, Giant Vac, John Deere, Murray, Simplicity, Snapper, and Troy-Bilt brands through various channels of retail distribution, such as consumer home centers, warehouse clubs, mass merchants, and independent dealers.
Quote from: TimRB on February 06, 2010, 08:54:27 PM
I would be interested in seeing how they attached the cylinder to the I-beam.......Also, is it just me, or is the cylinder not parallel with the beam?   Tim
There's a large pin that attaches the cylinder to the I beam, but it's a "flexible" connection.  Also, the wedge sorta wraps around the I beam.  As you can tell by the cylinder, there is slack and it can be lifted probably a couple of inches.  I think that it was designed to move on purpose.  It would have been very easy to bolt it on solid.
The engine speed never changed a bit splitting that wood.  That thing has power.
saltydog
i bought the same splitter 1 year ago at menards its a mtd brand it now has at least 250 cords under its belt you should be happy with it its now the wifes splitter im upgrading  i need a third splitter looking to build one to my own needs (fast) !
Proud to be a self employed logger.just me my Treefarmer forwader Ford f600 truck 2186 Jonsereds 385 and 390 husky and several 372s a couple 2171s one 2156  one stihl 066  Hudson bandmill Farquhar 56"cat powered mill.and five kids one wife.
Quote from: saltydog on February 07, 2010, 07:25:10 AM
Wow, you've been keeping it busy.  Mine probably won't split that much.......ever.... splitwood_smiley
stonebroke
Quote from: woodmills1 on February 06, 2010, 09:46:25 PM
I think MTD bought troybilt about ten years ago
Stonebroke
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
pineywoods
I have it's twin, only mine says "Yardman". Close out at Home Depot. Most all of them are built by MTD, which I understand is now owned by Briggs and Stratton. Looks to me like the splitting wedge is probably the weak link, it's cast steel. Probably wouldn't be hard to replace with a forged wedge if it ever breaks. This was it's second season, so far no problems. I use it in the upright position, some of the stuff I split is too large for this tired ole bod to lift.
Twig farmer
Fine homeowner machine.
I had one (MTD 31 ton) and was about to send it to the metal shop for a modification that would put the splitting wedge on the end of the I beam and the pusher plate on the piston....so it would accept a 4-way and be a conventional horizontal..
In all my years I have seen a horizontal / vertical machine used in the vert. position maybe 3 times...not enough reason for me to have kept it stock...a 4 way increases production 3 times over...
But I ended up with a nice little conventional horizontal and sold that MTD.
C5D Twig Farmer, Deutz power, "Mona".
Husky 575.
Husky 372.
F550 4x4 PSD.
Bull Strength and Ignorance.
Live FREE or die.
The MTD and Yardman sold here at Wally and Home D, are 21 ton units with a B & S engine.  This Troy Bilt is 27 tons with a 6.5 Honda engine.  I think that the only difference is the engine.
Don K
Nice catch, Magicman. 8) 8) I would like to find a good one at areduced price.
Don
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
Maine372
sorry to go off topic but.....
what is the ornage and white steel box in that pictures. looks like somthing stihl made or marketed. is it a chainsaw case?
Radar67
Looks very similar to the 12 ton unit I got in the fall for almost 70% off. It does a fine job of splitting. A little Marvel Mystery oil goes a long way with frozen pistons.
Quote from: Maine372 on February 07, 2010, 07:12:29 PM
You mean my handy dandy gas can/tool box?    :)
The bottom holds my  wedges, saw files, bar oil, etc.... :o
Quote from: Radar67 on February 07, 2010, 07:28:01 PM
I remember that you made a nice catch also.... ;D
I have one that looks like that too.Mine is a cub cadet brand,same thing.Saw White had the same thing,for $150 when I bought ours.Mine is pushing 10 year old,has a BS motor on it.When mine was built,steel was cheap so the I beam goes the length of the hyd cyd.I have split some really big,rough pieces with it.
indiaxman1
Good job Magicman...won't ever regret....I split with axe/maul many years, but got MTD....21 ton 5 yrs ago....great to haul out to site...take care of business...had to put tubes in tires due to chronic deflation problem....but otherwise has saved time, and back....
flibob
Like some of the others my old MTD just keeps goin.   I am like you car trailer and 4 wheeler.  But I have a Gator for the dogs.
The ranch is so big and I'm such a little cowboy
Tim
Here it is.  The cylinder is actually attached like an old "Civil War" cannon.  A large lug on each side.  As I previously said, it is not solidly attached.  The cylinder can be lifted an inch or so.  The ram is, of course, bolted to the wedge which is "captured" around the top of the I beam.
I hope that this makes sense.
TimRB,have a Tractor Supply near you?I went there to buy some bar and chain oil on sale,$6 and looked at one like Magicman's,but it was a differant color.
TimRB
Magicman, thanks very much for the additional pic!  It looks like the lugs are simply welded to the sides of the cylinder--is that right?
Thecfarm, I don't have a Tractor Supply outlet near me, but there is a Troy-Bilt dealer (who does happen to be a tractor dealer/farm supply) that I drop in to periodically.  I will keep my eyes peeled for the new splitter.
Tim
DR_Buck
Do you guy's with this model find the cycle time slow?    I have the same model and size as Magicman except probably a year or 2 older.   I don't have that red shield on top of mine.   I find the cycle time to be painfully slow.
