Set-up Blocks
Started by D._Frederick, February 04, 2010, 10:26:58 PM
D._Frederick
While paging through a back issue of WOOD SMITH, I came across a 2 page article about Brass Set-UP Blocks used for adjusting routers, tablesaws  and mortisers. They are 4 inches long and are sized from 1/8 inch to 1/2. The cost is about $15 for the set.
I was wondering if any of you wood workers have a set and use them? I don't like buying something and never use it because it takes to much time.
Don_Papenburg
I always wanted some but thought the price was too high for what you get  plus the fact that I would be spending more time looking for them than getting any use out of them .  If I had several sets they would be very handy to set up the plunge router .
LeeB
Make your own.  They don't have to be brass.
Sprucegum
What Leeb said
I made mine out of maple - they get some use  ::)
I also have a board with different depth notches cut in it. I use it on the table router , and table saw,to set cutter hieght.
pnyberg
I got a set from Lee Valley a few years ago.  1/16, 1/8, 1/4, 1/2, 3/4, and a 1x 2x 3 block, all in a nice little foam-lined plastic box.  I don't recall the price.
I use them more than just about any other tool in my shop.  They never stay in the drawer very long.
--Peter
No longer milling
