latest project: Shot Glass Cabinet
Started by Dan_Shade, January 30, 2010, 07:42:24 PM
Dan_Shade
simple little project in white oak
I finished it prior to assembly, which was a bit of a hassle, but it worked.  I used Boiled Linseed Oil, Mineral Spirits, and Spar Varnish as the finish.  I put 4 coats on it, the last coat gummed up a little bit, which was very frustrating, I don't know if I didn't rub it out enough, or the wood was too sealed for any more linseed oil...
lots of dull bands and chains
jamesamd
Well done Dan!
My Better half,collects creamer servers. :D
All that is gold does not glitter,not all those that wander are lost.....
Phorester
Very nice, Dan.
Appropriate choice of wood too, since most whiskey is cured in white oak barrels.
Dan_Shade
I didn't even think of that!
I try to get a shot glass or two when I go on a trip, sometimes, I'll get several before I find the one I really want.
I have one at work that I need to bring home, and that will fill up this case.  I didn't think I would fill it up!
Looks great!  When you fill it up, then you will have to make another one  :D.
Don_Papenburg
I hope you washed out the inside of them shot glasses several times before you put them in the cabinet.
Texas Ranger
I have filled up a shot glass a time or two my own self, oh, you meant the cabinet.  Sorry.
Norm
Quote from: Don_Papenburg on January 30, 2010, 11:53:03 PM
That wouldn't be a problem for me Don, I lick them out several times after every use. :D
Don_Papenburg
There ya go !!!!   I guess that is why it is called licker ;D
LeeB
Quote from: Norm on January 31, 2010, 11:05:40 AM
:o I bet that impresses the ladies.  :D
