what do you think of dolmar the company and there products
Started by 567paloggger, January 28, 2010, 10:18:04 PM
567paloggger
I just want your views on dolmar durability and company i just bought my first dolmar 5100s today i took it home and cut with it for a hour or so i really liked this saw my buddy swears by them but i never owned a dolmar so i splurged for another saw you dont see the big logging companys or the pro loggers using them the guy who i bought mine from was saying alot of logging companys were switching over to dolmar from the other saw companys i wanted to know what you guys think of the saws
sawguy21
Dolmar started in the 1920's, around the same time as Stihl, and built an excellent reputation. The name disappeared when Makita bought the line from Sachs and is being re introduced. Still a great product but parts supply can be an issue.
I have a 7900 that I'm really happy with. That and the 5100s are the two stand out saws they make. The others are perfectly OK, but no better or worse than the average good brand name saws.
Dolmar has been making chainsaws for a long time, and although they are now owned by Makita, Makita are in the business of making good power tools si I would suggest they didn't buy Dolmar to run it into the ground, or sell off cheap junk under the brand name. So they aren't like the new Poulans and Mcullochs
Here in NZ there seems to be a Dolmar dealer on every 2nd street corner. Even the independant Stihl dealers sell them, local power tool shop (Makita dealer), bicycle and lawnmower shop etc.
ehp
I cut in the bush running 7900's for a while and can honestly say they are pretty strong and can handle a pounding , I like the saw alot .
islandlogger
I was in the market to buy a new mid range saw, a forrester friend of mine has been trying to get me into Dolmar for a long time so I borrowed his 5100s and put it through the paces and I gotta tell you, I was surprised! Lot's of bang for the buck in a saw that size, it's comp to the Stihl 390...
islandlogger
peppone
I have many Dolmar saws: ps5000, ps7900, ps9000 (my favourite one) and a lot of old dolmar (ca, cc and others). wondering machines. probably better than Husqvarna and at the same level with Sthil.
Don't forget that dolmar invented the chainsaw powered by gasoline in 1927.
you're invited to visit my forum all about chainsaws:
http://lamotosega.forumattivo.com/forum.htm
saluti
peppone
joe_indi
Cant say much about Dolmar the company.
The oldest chainsaw company.Based in Germany.
Bought over by Makita Japan.
Makita has also taken over the small engines plants of Subaru Robin, whose engines are very dependable, in my opinion, even more dependable  than Honda.
The Robin 4 stroke brushcutter engine surprisingly looks very similar to the Stihl engines, except for its oil sump.
I dont know who has been 'cheating'.
The Dolmar-Makita merger could be the beginning of good things to come.
I had a  chance recently to try out three of their saws the 6400, 7300 and the 7900.
Performance was very impressive.
After more than 2 months of trials, the only replacement needed was a choke lever that went missing in the field.
I would not be able to say the same of a Stihl or Husky.
Years ago a 372XP that was on trials lost its Starter housing screws in a week, its short circuit wire a couple of days later.And the ignition module lost a screw in a fortnight.
A Stihl MS381 and 360 that were on trials lost their exhaust screws in a few days' time.One of the cylinder screws of the 381 came off in a week.The 360 blew its cylinder gasket in 2 weeks' time.
Compared to that the Dolmar/Makita machines seemed more confidence inspiring with their absence of the bad habit of shedding parts like a performer in a strip joint. :D :D :D
Where they are weak is that they dont have the same cutting system of a Stihl(Bar & saw chain) which give Stihl thatedge over the rest.
Other than that, very good and dependable machines.
Joe
ladylake
Good saws, as with any new saw make sure it's not running lean on the high adjuster.   Steve
ehp
one thing I can tell you to do is make sure you push the decompressure button in on starting the saw , if you donot you will tear the hub out on the rewind after a while but if you use the button you have no trouble , this is on the 7900 as it has more compression that just about any other saw
peppone
my PS9000 iss without compreessor but it's easy to start. ::)
saluti
peppone
567paloggger
i like my new 5100s i was thinking on buying a second one
567paloggger
bump anyone else have there opinion about these saws will they hold up like the stihls and huskys do
ladylake
I had a 7900 apart that was set to lean, it's build every bit a good as pro Husky and Stihl saws.     Steve
BARPINCHER
Quote from: 567paloggger on January 28, 2010, 10:18:04 PM
I know several pro loggers that have run them for years.  All say just as good or better that Stihl or Husky.  Depending on where you are they can be tough to get parts for.  Supposedley if you have a dealer for Briggs and Stratton they can get any Dolmar parts as Dolmar and Briggs use the same parts distribution network.  The other bonus is the Dolmars are a good bit cheaper to buy.  I have ran a 5100 and a 7900 that were a season or two old of one of these loggers and both were easy starting, smooth running , powerful saws.
Serving hunters and the hunted with science based; non-traditional resouce management methods
chipsfly09
I have a 7900 and a 5100 I like them-- My 5100 was acting a bit lean (max rich with limiter on carb screw) after the third tank-- I did some trimming on the limiter cap and gave it a bit more fuel and it is doing fine-- Did have to put a switch on my 7900-- dealer had a box of em so i bought 2.
MOwoodchopper
STIHL 084
STIHL 026 X2
STIHL 015
HUSQVARNA 372XP
DOLKITA 7900
DOLMAR 6800
DOLMAR 5105
John Mc
I've never had the pleasure of running a Dolmar. Based on the reputation, and what I'd heard here, I almost bought one new last fall, but the only dealer anywhere near me only sells a very limited selection (wouldn't even order me what I wanted). He also has a policy of only servicing what he actually sold (he keeps track of the serial numbers). I'm only comfortable with minor maintenance on my own, so I really appreciat good local support.
Same dealer says he's had problems with the 5100s, so won't sell them anymore. (My bet is, he was probably letting them go out of the shop too lean and they developed problems.)
567paloggger
well my friend who sells husky and dolmar he is a ex logger until opeing his shop on the side of his house he swears by dolmar and likes them more than husky thats all he uses for wood cutting now but the thing is when he retires there is no one who sells or services dolmar around
Rocky_J
motard
Quote from: 567paloggger on February 01, 2010, 12:59:18 AM
Remember, Makita bought out Dolmar years ago, parts for the older ones are hard to find (Makita does not support them)
These 4 are anywhere from 25 to 40+ years old.
They will start on the 2nd or 3rd pull, even when the temp is 0 F.
All have great compression, I think it is often forgotten how nice and innovative Sachs Dolmar was.
des170stihl
First,, The dealer that told you Pros are switching to dolmar is full of B.S. Thats not going to happen in this decade. But I guess what else would you expect him to say. When it was Sachs Dolmar it was a excellent company with excellent products. Dolmar dealers are far and few between so parts and service might be hard to get. And you never know what Makita will do. They are a major electric power tool co. They could dump the Dolmar line to save their power tool Co. The Dolmars I,ve run seem to be pretty good saws but far from being the best there is out in the logging world.
STIHL MS170* STIHL MS260 Pro* STIHL MS 230* ECHO CS 341* Husky 339 XP * Wallenstein 20 Ton Splitter* Massey Ferguson 1528 w/Grapple ( Skidder Wanna Be ).
sawguy21
Dolmar is distributed in NA by the same companies that handle Briggs but the dealers are not necessarily the same. Each has to be signed up by Dolmar to receive product.
Makita killed the brand, they only wanted it to supplement their core business and give the dealers a broader product range. They have recently spun it off into it's own entity, as E-lux did with Husky, and the name is slowly being re built. With the global down turn and soft lumber markets they could not have picked a worse time.
RSteiner
I have a couple of years on my 5100S and like the saw, it even survived a fall into a pond in about 3 feet of water (not running).  I had two Sachs Dolmars back in the 1980s that performed well.
I have a couple of Husky's that are going on 12 years old and decided to give the newer Dolmar's a try I'm not dissapointed.
Randy
Randy
567paloggger
i personally love this little dolmar i dont think ill get another one until the company is more established i also use stihl and husky i cut for a living
logloper
I have one 7900,about 3 yrs old; Ran it in the woods for awhile, nice balance but had trouble . When falling large timber,clutch cover can not keep up with chip output and clogs.
Also, use decompression button or pull rope pulley breaks. About a month ago,crank broke in half. Waiting to hear back from saw shop. Also have a 5100. Ran good till 2 weeks ago.Scored piston. Dealer says "What oil are you running?" I run synthetic Woodsman Pro from Baileys in all my saws (11 crew saws) no trouble except with the Dolmars.IMO Husky and Stihl are still the saw of choice for the professional logger
