Wood carriages
Started by bandmiller2, January 22, 2010, 10:40:51 AM
Glad to see so many interested in bringing back the old handset circular mills.Nothing wrong with wood, not as good as steel but still very usable.Most I've seen have a solid axle with babbit bearings morticed onto the beams.One wheel is a guide wheel and the outher is a flat wheel,if they are boath solid to the axle its real hard for them to boath turn the same distance per revolution their always seem to be a little slippage that leads to wear on the wheel or track.The best fix is to replace the babbit blocks with pillow block bearings and allow the flat wheel to turn independent on its axle.I put bronze bushings in the flat wheel and a grease fitting.The only turning is the correction between the wheels on the same axle.End play is very important the guide wheel locked to the axle clamped with boath pillow blocks gives you this, the flat wheel can float slightly on the axle.Good form to put a piece of steel flat stock between the pillow block and the bottom of the wood beam.Please don't consider me an authority on this stuff its just what I've descovered.Any comments that will help mill restorers welcome. Frank C.
Too cold outside for this old guy to work hence time on the puter.When wooden carriages were popular the best wood was that dandy hard southern pine.You want a wood that is as stable as possible.You use what you can get, well seasoned timbers recut to true them work well.I used recut doug fir for the ways of my mill with a couple of coats of wood preserver and old black creasoat at the jionts and anywhere wood meets wood or metal.Frank C.
sawthemlogs
I like the way you think frank. when i rebuilt my handset i did use steel on the husk but on the carriage because of the weird configuration of the bearings it was easier to use wood chisel out the pockets for the bearings.your right on with the carriage wheels. i used 4 inch h beams for the carriage to ride on .Even though it was level both directions ...When i insalled carriage on  track bunks didnt come out level ..after doing some checking the flat wheels were slightly smaller than the grooved ones.as you said  they dont turn consistent with opposite side ..guess  reason for free wheel.i just added flat bar to h  beam to bring bunks up level.works great...i like to listen from the people with experience..take care
R.D.
Good fix RD,circular mills would be in a bad way without shims,I always save small pieces of steel.Frank C.
Frickman
I was around and sawed on wood mills until 1997 when I put in my current all-steel mill. The wood mills were good in their day and very economical but aren't really the best choice for a production mill. It really makes me smile though to go to an antique tractor show and see an old all wood handset mill sawing.
The wood mills are alot more demanding on maintanence than the steel mills. Wood splits, decays (even when under roof) and moves with the seasons. Also, anywhere you have wood joining steel tends to wear or compress over time, especially the frame rails where the headblocks set and where the wheel trucks mount. The old style solid axles were never my favorite either for the reasons mentioned. If you aren't sawing full-time on a mill and are willing to keep an eye on wear and alignment issues a wood handset mill is a great way to make lumber, especially if it is what you already have.  If you're sawing commercially a steel mill may be a better way to go just because of durability and alignment issues. Either way a handset circle mill is a fun way to cut wood.
sigidi
Has anyone got pics of these things?
Would love to see...
Dakota
Don't know if this is exactly what you are looking for, but here is a short clip of my Dad(87yrs.) operating a mill he rebuilt after finding it in a ditch in Wyoming.
http://www.youtube.com/watch?v=KTEnFu0FmG8
Dave Rinker
Dakota, that is a real treasure.  I liked the mill too.
Thanks for sharing.  My Dad would have been 100 next month.  I wish that I had a video of him.
A common problem with older circular mills is worn wheels and the guide rail they ride on.The rail is always worn most right near the saw.Many of the old mills use cast iron sections of rail, almost always cracked,and hard to find.If you luck out you can move them around giving you lightly worn rail near the saw.My mill uses mine car rail,had to remachine the guide wheels and matching the worn rail gave me fits.I wouldn't want to buy 40' of that mine rail new.Inverted heavy duty angle iron and "V" castor wheels wile not heavy enough for a modern heavy mill will give yoeman duty on a handset mill.I have even seen a mill that has operated for years that just used straight castors bolted to the bottom of a wood carriage.All the wheels on the same rail should be the same diameter,or at least shimmed to cary their share of the load.Weight lifter weights can be machined to replace wornout flat wheels,one of mine says Golds gym.You want no sideplay on your guide wheels.Frank C.
captain_crunch
How about a wooden Donkey to bring logs to your wooden mill
Brian
woodpeckerlips
I just rebuilt a 00 frick (wooden) it's itimidating at first. But really not that bad. I rebuilt everything but the carrage. I was running it last weekend and ran a big red oak off the off bearing end and crashed the carrage. Broke the beam closest to the operater just over a axle.  Put the carrage back on the track plated it and sawed out me 2 beams  (pine)to replace on the carrage. I let them dry for a while. Plane them. And plan on putting the new beam in the front a little latter. I'll just take it easy for a while. (I think I'll extend my track out on the off bearing end 10 feet to keep this from ever happening again too).  While I'm at it, I'm gonna put a stop in at the other end. I ran across a steel oo frick at a great price not long ago and almost bought it.  I've had a lot of fun rebuiding my wooden mill. Seams to cut really straight. (Spent a lot of care in alignment/and lead.) Just not able to call it quits on it. Maybe in a couple of years.
WP lips,I was wondering how you made out with your mill.Most use some sort of spring to stop a runaway carriage.The carriage hitting the stop jars the mill pretty good.What i did was to dig a deep hole for a section of treated utility pole with a leaf spring verticle.It is not attached to the mill so no transfered shock.If I run the carriage into it,fires it right back,some use coil springs,old tires est. Frank C.
Frickman
Woodpecker,
I sawed on a few mills where you could run the carriage off the end of the track, it wasn't hard to do. When I installed my current steel mill I built stops at each end that are patterned off the stops you see on railroad tracks. We put old car coil springs behind a plate and everything. It sure is nice knowing that I can't run the carriage off the tracks now.
Dave Shepard
Thanks for sharing that video Dakota. I like the carriage drive, variable speed and direction just by moving it across the plate, very neat. Looks like an old M, seems to have enough power. :)
Dave ,thanks for bringing that up You couldn't get a much simpler feedworks.That disc drive principal is alive and well residing in most snowblowers and some yard tractors.DanG now I have to build something to use it.Frank C.
Dakota
Dave Shepard,
Dad wore out an M in the first 20 years of powering the mill.  He replaced it with a rebuilt Super M.  That really made a difference.
Dakota
Dave Rinker
woodpeckerlips
BM2/ frickman,   thanks for the input.   I'm running a flat belt off a 3-71 detroit. I put poles in on each side and nailed up some slabs to keep the belt from getting the offbearer. Belt comes out to the end of the track. It's just a 2 bearing mandrel. Therefor not leaving much room for the offbearer.  I'm intertaining the V-belt conversion to give me more room. I'd like to figure out how to put a 10" tire on the power unit and slide it right up to the big flat belt pulley. But it would spin the wrong direction.left hand mill. I was considering hooking up a drive shaft. Then the speed would be to same as RPM's. Now I'm pondering a transfer case, but don't know what speed I'd end up with or how well it would hold up. Thought abought a rearend(4.10) hooked up with a drive shaft and turning the axle with the power unit. Power unit would be turned 90 degrees and way out the way.   What other contraptions have you guys seen on fricks other than V-belt and elect, that give more room?
ibbob
Cut the flat belt and get the motor up by the husk.
Bob
WP,what if you put the detroit on the backside of the mill and ran a shaft under the mill.Install V belts on your side of the mill to get the speed right and use a truck drive shaft and U joints to spin the shaft.That would also make it easier if you run the mill alone no long commute around the engine.You say your mill is left hand you'll have to figure your rotations.You could also mount a V pulley with a short shaft below your arbor and run a low driveline from the engine.Then build a low bridge over that shaft for crossing over and giving the offbearer some living room.Frank C.
woodpeckerlips
If I was to cut the flat belt would give me a little more room. Then the shaft from the power unit would be spinning at the back of your knees in a spot the offbearer would be working most.   The back of the mill is down hill and not ideal to put the power unit. If it was flater I'd like the idea of it being behind the mill and out the way.   V-belt conversion up close as I can is the way I'm heading I think.  Thanks for the ideas though.
jimparamedic
Heres my power unit chevy250 spiders welded in rear end one side runs mill other runs planer cut up saw ect ect
Now there is a rose among thorns in that picture. She's cute.
Guarding the cooler, is she?  ;D
captain_crunch
Did you see the clip where the guy set motor at 90 degs of mill and used two tires running against each other to change rotation ?? I will see if I can remember where I seen it
jimparamedic
Shes my helper loves the sawdust pile and the worms and bugs she finds but when the mill is running shes with her nanna
Coon
Here's another old wooden mill from up in these parts.....
Kinda hard to see the mill with all the snow.
Brad.
