End grain floors
Started by jim king, January 14, 2010, 09:13:09 PM
jim king
Does anyone know how end grain floor tiles are dried ?    I would think that putting them in a kiln would be a disaster.
Ironwood
Dont know, we have TONS of old industrial floors in warehouses and shops here around Pittsburgh that are end grain.
Ironwood
jim king
Do you remember if the tiles laid tight together and seamless or does the floor have grout like ceramic tile.
ohsoloco
I recall seeing an end grain floor being laid on one of those home shows years ago...This Old House or Bob Vila's Home Again.  They started with dry cants (perhaps reusing old timbers) and cross cut them to thickness.  There was a healthy gap in between the tiles, and they were "grouted" with some mixture of sawdust and resin.  Nice looking floor  :)
The first end-grain wood floor I remember seeing was in the Alcoa Aluminum plant in Davenport, IA. 1954
It was Douglas fir, and the blocks were about 4" long. Were told they were very easy on the fork trucks and other wheeled equipment moving around with heavy loads. Apparently absorbed a lot of the shock. Being in this mill, and it being a foundry setting, there was plenty of dirt and dust that worked its way into the joints between the blocks.
A thin tile of end-grain, would be a different problem, and may be troublesome to dry without problem checks.
There would be some tricky sanding to be done if a floor and needed to be flat, and moisture changes that might tend to keep it from staying flat.  :)
Ironwood
The ones I have seen were floating free.
        Ironwood
Mooseherder
This is a question asked on and is from the "This Old House Website"
Q: I've seen floors made of end-cuts of wood. How do you lay this kind of floor? How is it attached to the underlayment, and what's the right grout to use?
A: Tom Silva replies: You don't use a grout. Usually end-grain flooring comes in panels and is applied with a glue. You trowel it on, using probably an 8 by 8 trowel at a 45-degree angle. You put the glue on the floor, tip your trowel up, and it fits little notches in the panels, and then basically it just lays in place. The only ones I've seen have been tongue-and-groove. So you lay the tongue of one panel into the groove of the next, slip the panels together and that's it.
Fla._Deadheader
scsmith42
Harold, that is a pretty interesting link.
Jim, the basement area of the merchandise mart in Chicago is paved with wood block panels laid back in the '20's.  They do not have grout in-between them.  I don't know how deep they are, I presumed around 6" - 8".
Tom's 3638D Baker band mill
laffs
this old house did it with reclaimed timbers sliced about 3/4 thick dont remember what they used for grout. but they laid them then sanded then some sealer. grout im not sure about.
brent
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Fla._Deadheader
Scott, did you go to the History section ???  There is good info on how it was, in the old days .
jim king
I am back to the drying.  I have not tried it yet but I think the problems of kiln drying 1 inch thick end grain slices would make a guy very old very quick.
But maybe when the 4 x 6 peice is not in a round with full tension ans stress from being round it would be easier ?¿?¿  (jungle logic)
Drying a 5 x 7 timber and then slicing it does not seem to be a solution as it would be full of visable cracks and hairline cracks ready to become visable.
Is the solution simple air drying ??
Den Socling
I was standing in a very large and old manufacturing building one time and when I looked down at the floor I was amazed to see that what I had thought was bricks was actually end grain wood. It was cut into rectangles. If there was ever any grout, it was long replaced with dirt. It apparently was very durable since it showed no more wear than adjacent sections of concrete. Thinking back, it could have been put down as "streets" for wheeled machines. So, drying "2 x 4's" may be the way to begin. A 2x4 or 3x5 would see fewer drying stresses than a round, for sure.
fishpharmer
Jim King, interesting post.  First I ever heard of flooring or paving with end grain exposed.
Harold, neat link, I enjoyed the historical information. 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Texas Ranger
Local bank was built a couple of years ago, the flooring is 4x4 end grain mesquite.  When I was asked, they were put down as individual tiles.  The tiles had been cut from 4x4 cants.  Once down they had only standard wood floor finish applied.  Out standing looking floor, and being mesquite, will be here long after the building is something else.
Grout in the old floors was usually left to the accumulation of dirt, grime, dust, grease and wax from everyday living.  The wide pine flooring that was installed in the lodge I brag about, on the Satilla, has this accumulation and it not only raises the surface of the crack to the level of the wood, but is rather attractive as well, as long as you don't tell prissy people how it happened.  :D
jim king
These are not good photos but you will get the idea of end grain in the tropical woods.  Do you think it would make flooring ?¿  The little blocks are about 4 inches long and the pink wood photo is of a limb and the colored part is about 8 inches in dia.
Fla._Deadheader
 This is the only other info I could find.
QuoteEndgrain is easy to make. Start with air dried for five years plus, cross cut, dry in Nyles, redimension, glue down, finish, and grout.
  From a contributor on another Forum. Shows photo.
  Having used Tropical hardwood, I would think it would be great for flooring.
Dodgy Loner
Air-dried for five years plus? Seems a little excessive to me. Once wood reaches equilibrium, it don't get any drier unless the air gets drier.
scsmith42
Quote from: Fla._Deadheader on January 15, 2010, 09:40:48 AM
Harold, I did go to that section - pretty fascinating.  Some of the links were too.
Fla._Deadheader
 Dodgy, I thought that comment was over the top, but, just had to add it to the thread. LOTS of x-perts out there, EH ???  ::) ::) ;D
  I'm SURE Jim likes the way we hi-jacker his thread.  Sorry, Jim.  :( :(
Ole CB
  Here are some pictures of the same questions I had posted in soaking walnut.
  These pics were taken in Chicago, Ill. USA. Jim, It seems like we need the same info.
shinnlinger
When I was a kid, I remember a mall did end grain flooring and I thought it was pretty neat.  A few months later though it bubbled up as the wood expanded.  Now it has expansion joints avery 10ft ft or so.  I suppose you could reserve the joint for the edges of a room and possibly even cover with trim
SOrt of related, my father in law used to work at a lumber yard in germany just after the war, and he was promoted to kiln operator when the previous kiln guy over dried a batch of flooring for a dance hall and when it expanded it blew the walls out.
Shinnlinger
rocksnstumps
I use to work at a plant in Memphis that had a small section where the machine shop was that had an end grain block floor. About 3" squares probably about the same height.  The machinists said is was way easier on your feet than concrete. No grout other than the accumulation of dirt and oil as mentioned earlier. The milling machines were on concrete pads however. If you looked, you could find many with alum rivets squished into them.....the plant made airplane wings for WW II bombers at one time so they had been there almost 50 years when I worked there. Some interesting history but the place was all changed when it was sold right after I moved on.
I've never seen end grain used up here. The only wood flooring that exists in old buildings is most always hard maple, and it's not tung and grooved, just laid edge to edge, usually no wider than 2". Also, some old buildings just had planed spruce flooring, which was painted. I can remember being in old homes when I was a kid, and some of the early flooring before vinyl would be warn through to the original spruce or maple floors. Why someone would want to put that crap on a nice maple floor is beyond comprehension.
