Belts
Started by garyfg, January 12, 2010, 10:53:16 AM
garyfg
My Oliver mill has the urethane belts . I was thinking of changing them to regular V belts. The wheels are 19 in and look like the ones Linn's sell. What belt would I use? I can get gates B56 or B57 belts at O'Rileys. Don't know witch I need.
I can't speak for your mill, but WM doesn't recommend "automotive" B57's for it's mills.  Their B57's are specially made and have no irregularities on the tops.  Makes for smoother and vibration free running.
Hi-Country Orange
I think the belts from WM also have some kevlar in them to
get them to hold up to the extreme pressure ? :P
rs1626
any body know the part# and price at woodmizer?
Papa1stuff
About 13.00 plus shipping B57
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
woodmills1
good quality B belts are flat, find out if your local jobber has belts supplied by gates or others reputable, they work.
As Mills1 says regular belts work fine I prefer the ones with a slight crown profile don't recall the brand.Have any of you tried the belts with the slight notches on the back[not in the vee]??Frank C.
robnrob2
NAPA B-56 blet has the crown ya want, that is the belt I use in my 19" wheels,, it is 59" long, and you have to work it and screw driver it on, but its a tight fitting belt and will seal to your wheels, no saw dust etc, no slap,
sdunston
Quote from: garyfg on January 12, 2010, 10:53:16 AM
Is it true that urethane belts stay cleaner?
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
I had a vibration problem and took them off.  Don't know why I tried them anyway.  WM B57's for me.
We tried the urethane belts it is extremly important to use alot of lube when stretching them over the "V" pulley,if not one side will stretch thinner and cause vibration.we found no advantage over regular belts.Frank C.
york
there is only one advantage of using urethane belt over,belt from say napa -would be your love to spend money..
Albert
garyfg
Quote from: sdunston on January 13, 2010, 09:00:11 PM
Sam
I don,t know.Have never used the B belts . May try and pick some up at town today.
My suggestion would be; If it ain't broke....don't fix it.
If you are using "B" belts and are OK.....use um.
If you are using urethane belts and they are OK....use um.
Spending $$$ just to try something new is not a reason to change.  I'm speaking from experience.  I did it....>:( ;D
(I've included a link to an older thread)
https://forestryforum.com/board/index.php/topic,38782.0.html
mburrow
sdunston
Quote from: Magicman on January 14, 2010, 09:35:36 AM
Think I will stick with the belts from WM
sam
ladylake
 I run B56 Goodyear, a lot of other brands don't stand as high and let the band hit the wheel sooner.  Steve
robnrob2
Hey Ladylake ?? Is that goodyear B-56 a belt you gotta work at,, to fit the band wheel, like the NAPA B-56
garyfg
Put some gates 56 belts on today. Look good for now but I thoughy that before. Blade seems to stay centered better
