New [to me] LT40Super D40
Started by jtmccallum, January 08, 2010, 10:45:16 PM
jtmccallum
After years of wishing I finally bought a sawmill.  8)  I'd like to thank members here for there help. :P  It is a one owner '97 LT40 Super D40 manual mill.  I am going through it now, belts, bearings, filters, etc.  Looking at maybe adding hydraulics next winter.  I will keep everyone posted on my progress,  prolly even have question or two. ;)
John M.        '97 WM LT40Super Manual 40HP Lombardini,  XP372,   CASE 1210 W/ Loader
 8) 8) 8)
JT,
Your camera broke ??? ::).
jtmccallum
Looks like I better learn how to post pics. :D
D Hagens
While we wait for the pics to crawl their way here :D I have a question, what does the D40 stand for?
pigman
LeeB
Quote from: jtmccallum on January 08, 2010, 10:45:16 PM
I thought the supers already had hydraulics?
Chuck White
That's kinda what I thought, Lee!
I always thought that the Supers had everything!  smiley_headscratch
Bibbyman
I think it's an option and they built a few "Amish" Supers.
Sawing since '94
I always like to know,what's the plan for the sawmill?
Quote from: jtmccallum on January 08, 2010, 11:07:29 PM
You are on a roll now, breaking new ground, so you might as well go for it all  :D.
zopi
Quote from: thecfarm on January 09, 2010, 09:17:57 AM
to cut lumber...  :D
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
jtmccallum
Quote from: zopi on January 09, 2010, 11:49:21 AM
to cut lumber...  :D
What Zopi said. :D
Apparently this is some sorta Amish/3rd world type of mill.  Previous owner bought it this way.  Found it on Craig's List, 50 miles from home.  Have'nt used it yet and already getting small jobs lined up from neighbors. :)  Told to wait and see if I'm any good at it. :D
with this kind of excitement, you'll be good at it.  :P :)
Just don't get in a hurry, Don't make it too much work and always be fair and positive minded.  You'll do good.  :)
UCUT2
 smiley_clapping Congratulations on  the mill. Running your own mill can be quite a  rewarding experience.Good Luck!
Just wanted to know if you was going to saw your own logs,buy logs,saw for others,just saw a few out buildings and than resell it or?
jtmccallum
Sorry, Zopi led me into that one. ;)  Right now I have a whack of pine and spruce that a co-worker gave to me.  I have some white oak, red oak, soft maple, ash, and cottonwood on my own land.  I am in the process of removing some mature red maples and will take a 2nd. look at them.  Maybe get some spalted or character wood.  A small tool shed of my sisters needs some repair.  2 or 3 hay wagons to build, saw shed, kiln chamber.  Outbuildings, trim, flooring,etc. for house.  Not in any particular order.  I'll run out of energy and time before I run out of logs.  I plan on keeping the mill.  Oh Yeah, I need to build wood duck boxes by spring. ;D    And then theres more red pine from the same co-worker this summer...... Man, what did get myself into.  Good thing sawing is addictive.
Bibbyman
For sure with a manual mill you need to get an array of the great LogRite cant hooks.  At least one long one and I'd recomend a "mill special",  I use the 30" mill special the most.
Sawing since '94
First, Congratulations on the "new" mill.   8)  I love the idea of practicing/learning with your own logs.  I did it.  That allows you to really screw up, and not have a paying customer mad about seeing his logs messed up...... :D
My advice, take the manual, read it, and go through and understand the adjustments.  Don't be hesitant to ask questions on here.  Someone will have the answer.
Again...... :D
Quote from: jtmccallum on January 09, 2010, 09:34:46 PM
Eat the elephant one bite at a time and start with the wood duck boxes  :D :D.  By the Pig Roast, you should have a big whack of lumber sawn  8).
