End matching
Started by True North, December 16, 2009, 07:47:05 AM
True North
Anyone know of an economic way to buy or build an end matcher?
red oaks lumber
how much wood do you plan on e-matching? if the amount is small do it with 2 shapers, more volume there is a small one ducet makes new about $40,000  fruilmac makes a bigger one new $130,000
there are some used ones on the market just depends how much you want to spend, far as making one  that depends on how handy you are
my opinion is i won't try to reinvent the wheel by trying to make one you'll still have a lot into with no gauratees it will even work good. i have owned both makes of e-matchers still running the fruilmac does about 1000sq.ft.per hour. the ducet did about 2-300 sq.ft.per hour
True North
It would not be a lot of volume. What would you suggest for the 2 shaper option?
red oaks lumber
i would go with a 3 hp.  either grizzly or powermatic.  grizz sells t&g cutters for shapers
scsmith42
Rather than using a shaper, what about mounting a router to a radial arm saw, or something similar?  Seems to me that supporting a long board for end matching on a shaper might be difficult...
Tom's 3638D Baker band mill
LOGDOG
True North,
   Logosol makes a machine that can do this. It's shown here: http://www.youtube.com/watch?v=UfGDvcDDF1g
   One way you could increase speed is by replacing the manual lockdowns shown in this video with air clamps on a kicker switch. I had a shaper set up that way for end matching. Worked great. The stacked head shown on this logosol allows you to do both a tongue and a groove on alternate pieces. Saves time on switching tooling and rehandling the pieces. Hope it gives you some helpful ideas.
LOGDOG
zopi
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
solidwoods
For economy-  Double spindle shaper.
I got one from IRS auctions for $100.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
True North
I am not familar with a double spindle spindle shaper. How do they work?
True North
They are set up with two spindles that rotate in the opposite directions, so a piece being shaped (usually clamped to a jig block) can be fed on one spindle or the other depending on the direction of the grain rising to the surface.
Pictures of shaping test specimens and some discussion can be found on p 20 of the "Machining and related characteristics of Hardwood by E.M. Davis
http://www.fpl.fs.fed.us/documnts/usda/tb1267.pdf
The tests were to show how different hardwoods could be machined, and the shaper was one of the tests. A double spindle shaper was used (last we knew, it still sits in the wood shop at the Forest Products Laboratory).
solidwoods
Quote from: solidwoods on December 18, 2009, 05:39:42 PM
jim
Its 2 shapers built on 1 table.
They have 2 seperate motors and 2 seperate spindles.
Really no big advantage over 2 seperate shapers but a dbl. shaper can be had cheap from a factory (but 3ph).
Just go to IRSauctions click search and check the shapers block.
jim
Ret. US Army
N. Central TN.
