Onan parts?
Started by slanted6, November 27, 2009, 09:15:20 PM
slanted6
Anyone know where to find Onan parts?  Engine is P224G-I/11295G on WoodMizer LT40.
James P.
I don't know personally but you could check to see if there is a small engine repair shop that is the old school type that keeps a lot of used garden tractor parts around.
Slanted6, welcome to the forum.
You might try manufacturers who have used Onan in the past too, like Woodmizer. They might still have some parts around, or know where you could get them.
MartyParsons
What part or parts do you need? I have a engine here the the owner did not check the oil.  :'( We also have access to parts from WM and we have many other sources. Should be able to fix you up. ?
Marty
DanG,is Onan out of business??going to be alot of unhappy campers,litterly they used alot of Onans on their generators.May take a little time but i'am sure aftermarket will step up to the plate.Look into Stens and NAPA they have alot of aftermarket parts.Frank C.
bill m
Onan is owned by Cummins Diesel now. Find your nearest dealer and they should be able to help.
slanted6
Cummins/Onan dealer had them.  Dad picked up the needed parts today, reassembled and has mill up and sawing.  Thanks for all the replies.
