Gaurdrail tubing for shed posts?
Started by jmmy6767, November 12, 2009, 08:33:25 PM
jmmy6767
Hey everybody ;D,  I got some galvanized tubing from work, and was wondering if any of you had ever heard of anyone using this stuff, for building purposes ?  The tubing was attatched to the backside of some gaurdrail, and the approx. dimensions are 5"x8"  and 25' length.   Could this stuff be used as  posts to an open sided shed?
jimmy
Ironwood
YUP, local steel shop used it to put up an additional building. Got it CHEAP, lucky dogs, wish I could have gotten in that deal. FYI, bolt to the galvanized, even if you grind it "off" it still effects welds AND fumes are bad.
      Ironwood
Ironmower
WM lt35 hd 950 JD
Woodwalker
Something like this?
It's 24' X 34'. 3" X 1\4" tubing, The I beam on the post are 3" X 8" with 12" X 34' "C" purling on 4' centers.
I did design it for our snow load :D and it has survived  two hurricanes.
Just cause your head's pointed, don't mean you are sharp.
jmmy6767
You guys are fast and full of good news 8)
  Yo are right about the fumes >:( , I just spent two days torching the stuff off a bridge We are tearing down >:( >:(    And how did you guys know I wanted to build a sawmill shed?   Of course I don't have a sawmill YET ;D   But when I get one the shed will be there.   I am going to be loading the stuff on a trailer this sat.   I will try to take some pics and figure out how to post em.    You guys have a good night!     jimmy
jimmy
Donald D
If you get sick from welding the galvanized steel, drink milk. It neutralizes the toxic  effect in the blood stream. Know from experience...
stonebroke
drink milk before you do anything with galvanized
Stonebroke
SPIKER
never heard about the drinking milk when working with galv.   huh learned something new today...
isawlogs
Best thing is still having a ventilated helmet ...
   Marcel
Quote from: isawlogs on November 15, 2009, 09:02:14 PM
Right, protect those lungs.  Milk won't do that.  Use a "carbon" mask.
stonebroke
I don't think the damage to the lungs is what kills you, I think it is heavy metal poisoning of the blood.
Stonebroke
Quote from: stonebroke on November 16, 2009, 08:16:07 AM
Stonebroke
It gets in your blood through your lungs when you breathe it in......
stonebroke
Yeah, probably kill you either way.
Stonebroke
Yup, there's no degrees of dead.  Bottom line.....don't breathe that white/green/yellow smoke that comes off of galvanized metal.
tughill
How about just don't attempt to weld, or cut galvanized steel w torch or plasma?  That's my method.
We have used the square galvanized guardrail tubing for years to build pole barns.  Cut it into 6' long pieces, cut 55 gallon drum in half to make two big 'buckets'.  fill 'buckets' with concrete, put guardrail tubing standing up into the center of the concrete, fill tubing w concrete up to about 10" from top.  Let them cure (you can also cast in place), dig holes for pole barn with backhoe about 3' deep, drop your bucket of concrete with tubing sticking up into hole, plumb the tubing, and backfill.  The standard guardrail square tubing will accept a 6"x6" post almost perfect.  Bucket of concrete prevents frost heave and sinking into soft ground, as well as keeps wood out of the ground.
There is now a product that does the same thing, but is quite $$ called a perma column.
"Those who hammer their guns into plows, will plow for those who do not."- Thomas Jefferson
Local Farmer here won 10$ million in the lottery, when asked what he was going to do with his winnings, responded, "Keep on farming until that's all gone too."
jmmy6767
Thanks for all the replies.   I spent two days cutting  the gaurdrail , I did not have a mask or respirator.   I feel like an idiot, but I didnt know it was that serious(blood poisoning etc....)   Fortunatley I don't havre to cut anymore.    Its not even my ususal job.   I am actually a heavy equipment operator, but, there wasn't any other work to do those days so it was either do it or go home.   But anyhow,  I went back and did some searching here and found where the posts had been used like you suggested  (Moonhill)   I was hoping to sink them in concrete and use them as the entire posts themselves.   The shed will be in South eastern Indiana.   So I am going to have to find the snow load for my area.   I had thought about filling them with either bank run (sandy gravel mix  =   free$$$)   or concrete.   Then having  a friend of mine weld  (with a mask)  Brackets ,  8" down from the top to rest 2"x8"s on that would then be held on each side with lag bolts.   Is this a good plan?  Is filling the posts over kill?  I am afraid the might buckle?    By the way,   the tubing is 8"x4" in diameter  21' in length, and approx  3/16  thick.   Thanks,   jimmy ;D
jimmy
