homelite super ez having trouble
Started by tractors0, November 08, 2009, 08:01:50 PM
tractors0
i am having trouble with this saw it will start up and runs for a little bit, when you let off the throttle it will die.  It will not start up again until it cools down.  If you have any suggestions, please help.    Thank  you.
sawguy21
Pull the muffler and check the piston and cylinder for scoring. Light scratches on the piston are o.k, deep gouges or galling are bad medicine.
tractors0
thank you very much could it also be the carb cloged cause when u let off the etriger it will die like it is not getting enough gas?
GASoline71
\"...if ya mess with the bull... ya gets the horn.\"
