Comstock Logging
Author Topic: Calculating board feet in a log.  (Read 4961 times)
Offline Dieselrider
« on: October 31, 2009, 10:14:25 am »
I am cutting some pine out of my wood lot to build a pig pen and a couple other projects. I have walked around using a Tree stick scale to estimate the total number of board feet in the trees so I know how many to cut. The tree stick is calculating the number of 16 foot logs per tree and gives some estimates as to the total bd/ ft per tree.  I have my list of lumber needed and the lengths needed but, how can I tell how many bd ft of lumber is in a certain log say at eight feet long or at twelve feet long so I can know when I have enough 12 footers and enough 8 footers cut? I am not a logger or a forester but, I have cut locusts for poles and pulpwood etc,but this is the first time I have needed to calculate just what is needed for each length. Is there a standard to use. Thanks.
Offline beenthere
Re: Calculating board feet in a log.
« Reply #1 on: October 31, 2009, 10:21:41 am »
You can use the Forum tool box, use the tree volume estimate that needs the diameter at breast height and your log length estimates. :)
http://www.forestryforum.com/calcs/Board%20foot%20calculator.htm
Hope that helps.
Offline Dieselrider
« Reply #2 on: October 31, 2009, 11:39:45 am »
I hereby announce I am a dope! All I had to do was turm the tree stick scale over and there is the exact information I needed. Talk about not seeing the forest for the trees!!! Ok, now I am going to hide my head before any of the real loggers and foresters show up. smiley_whacko
Offline LeeB
« Reply #3 on: October 31, 2009, 01:02:15 pm »
All those real loggers had to find the other side of the stick too. None of them were born knowing how to use it. ;)
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346, 372 and 562XP's. Stihl MS180 and MS361, 1998 and 2006 3/4 Ton and 2005 1 ton Dodge 5.9 Cummins 4x4's, 1989 Dodge D100 w/ 318, and a 1966 Chevy C60 w/ dump bed.
Online Magicman
  • A "Traveling Man"
« Reply #4 on: November 01, 2009, 09:25:11 am »
Nope,  The only dumb question is an un-asked question...... :)
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: November 01, 2009, 11:01:18 am »
Sometimes I wish that it was as easy as looking on the other side of the stick :).
Good luck with the project!
