Small diesels for small mills
Started by boatman, October 28, 2009, 09:35:27 AM
boatman
Does any one here have experience with the small diesels offered on some of the new manual mills?  I prefer diesels to gas, how do they compare hp to hp.  Is a 10hp diesel as powerful as a 15 gas?
fishpharmer
Boatman, I don't have that experience.  Yet, there has been alot of discussion about the diesels.  Might want to search.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
T Red
I don't have any experience with the smaller diesels either.  The hp ratings should be equivalent.  Depending on the design the diesel may(should) have more torque.  I love diesels but when you get that small the diesels just cost too much compared to the gas.
Tim
sdunston
I replaced the engine on my wood spliter a few years ago with a yenmar copy and am very happy with it lots of power and uses a lot less fuel then the 10hp gas motor
http://www.carrollstream.net/
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
fishpharmer
Jasperfield
I keep waitin' for Woodmizer to offer their small air-cooled diesel for us here in the U.S.
Small aircooled diesels are very economical to operate,but are expensive ,heavy ,noisy,smelly,and tend to be hard starting when its cold.I'am not talking about the larger water cooled electic start diesels.Frank C.
moonhill
You listed all the things I love about diesels.  I have only one gas engine and that is on the edger, it coughs and sputters and uses a lot of fuel, it seems every time I turn around it needs more.  I really like diesels they have their issues as well but they run nice as long as you keep your filters clean.
Tim
york
Frank,you are right-i have a Ruggerini diesel on my TH-think 23 hp-some day it will be for sale,going to get the biggest Honda,i can get.......Bert
Albert
amberwood
I have two copies of the Yanmar 10hp single, one in a 5kva genset and the other was in a small bandmill that I originally built. Gobs of torque and amazingly low fuel consumption. I can run the genset for a full day and not empty a 5l fuel tank. Downside, hugely noisy and massive vibration.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
Years ago I built a log splitter with a Hatz diesel,by the time I got it running in the winter i was too pooped to split wood,swapped it off to a guy for a steam engine,that always started.Frank C.
tyb525
The vibration will be a big issue with a small mill. Unless you can get a twin diesel, that would run somewhat smoother.
boatman
I sure do like this forum.  Thanks for all the replies, this site is a great research tool.
ladylake
You would have trouble getting my 28 hp Isuzu diesel that replaced the original 27 hp Kohler away from me. It cuts way faster and uses 1/2 the fuel.  At idle it shakes some and is a little noisy, at cutting speed its smooth and not to much louder than the Kohler.   Steve
firecord
Surplus Center has an awsome deal on a 13.4 hp yanmar.  rated for 3600 rpm continous duty.  less than $800
https://www.surpluscenter.com/item.asp?UID=2009103020071284&item=28-1684&catname=engines
I have almost the same engine on a riding mower seems smoth enough.
ladylake
Speaking of riding mowers, the would be a good source for a good cheap diesel with all the accessory's    Steve
T Red
Quote from: ladylake on October 31, 2009, 04:56:50 AM
I'm in the planning stages of a bandmill and I'm using a commercial Toro front mower for the engine (Mitsubishi diesel), hydraulic pump, and hydrostatic unit.  I used the mower for years but the pinion housing broke and it is no longer worth fixing.  I'm trying to figure out how to use the hydrostat for power feed.
Tim
Quote from: firecord on October 30, 2009, 09:15:30 PMrated for 3600 rpm continous duty.
The RPM rating should be a key issue, and Welcome to FF..... 8)
ladylake
Quote from: T Red on October 31, 2009, 08:30:40 AM
  My B20 TK  uses 2 NO 40 roller chains in a loop with a hydraulic motor that drives the chains which pull the head back and forth.    Steve
