Portable mill
Started by draggon_9, October 27, 2009, 07:24:09 PM
draggon_9
I'm just learning how start using my portable mill. After I made my first cut I suddenly realized I was going be putting screw holes in my future board to hold down my 2x4 guide board. Is there another way to hold the guide board, or do the holes disappear after the boards dry.  :-\
pasbuild
I can't help you with the anchor question but I can tell you that holes don't disappear.
If it can't be nailed or glued then screw it
zopi
Quote from: draggon_9 on October 27, 2009, 07:24:09 PM
Oh...I think I see..you have a chainsaw mill, yes?  level and strap down the guide board, using tie down straps and wedges or props to level the guide board...it shold be parallel to the heart of the log....when you saw up to a strap, carefully remove the strap and replace it behind the saw...use this setup for the first slab, then simply let the
mill guide bars ride on the smooth top of the log...
I recommend a read of Will Mallof's Chainsaw Lumbermaking....
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
zopi
heh..actually, I recommend a big orange bandsaw mill...
Got Wood?
And lots of junk.
fishpharmer
Draggon_9 Welcome to Forestry Forum.  Glad your here.  We would like to hear more about your mill and what you plan to saw.  There are alot of wise folks here.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
draggon_9
Thanks, Zopi. I thought about that and Thought it was a little more time consuming but what the heck, I'm in no hurry. I had to cut down 2 White Cedars and White Fir cause they we're to close to the house and 1 Cedar was getting rotten. There all about 30". I cut them in 6ft. lengths hoping to make a cedar dresser & maybe a work bench with the Fir. I have to find room in the garage to dry the boards. It'll take about a year I guess.
zopi
yeah...figure a year per inch of thickness...sticker them ouside, under cover...a tarp or whatnot, in a sunny location for three months or so, then move them inside...get them down to 19% or so then on down...don't want to dry em too quick...
Got Wood?
And lots of junk.
draggon, I can't help you with your question, but I can say WELCOME to FF..... :)
draggon_9
Thanks (Magicman). One more quick question anyone; can I put (Black Jack) on the ends of my boards to keep them from cracking?
James P.
welcome draggon 9 to the forum, search all the info on the site for csm chainsaw mills. There is a lot of useful info . I had a CSM when I first wanted to saw lumber. I didn't know all the ins and outs. worked myself to death. Gave it up and since recently joining this forum, I see that CSM are a good mills to have for dedicated and specialty use.
What is black jack ?, I have used water soluble black tire paint, I know its working dries like rubber. I'm not sure it isn't staining the end grain . I have used latex paint on maple. It discolored several inches of the end grain. Only realized it once I sawed the logs. Good luck with your mill.
draggon_9
Black Jack is a moisture resistant roof coating, it's kind of a watery silver tar. I couldn't find it in the forums.
ljmathias
Black Jack should work fine but sounds kind of expensive compared to commercial end seal... but then again, maybe not.  One thing: don't cover the stack of stickered wood so air can't get through- you'll have the most gorgeous crop of fungus and rot you can imagine!  Just put something on top and keep the ends of the boards out of direct sun- should dry fine as long as it doesn't repeatedly get wet...  "Air dried" means just what it says, so air has to move over and around the wood for it to take up any moisture.
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
zopi
y'know..I painted the ends of some cypress with latex paint about two years ago..cut one of the logs today...no checking and the logs are in great shape....
Got Wood?
And lots of junk.
draggon_9
I've already got a gallon left over from roofing, just a good way to use it up. I'm going to stack it in the garage to dry. There's not very many sunny days up here during the winter, plus about 2 to 3 ft. of snow all winter makes it hard to get to things. I don't want to constantly be digging out the wood pile.
backwoods sawyer
Are your board long enough to have plenty of trim (12"-24")?
That black jack will stain the wood quite a ways up the board when applied to the end of the log. Think of the wood fibers as long grains of rice all laying is the same direction from one end of the log to the other. The black jack will not soak into the fibers but will soak in around the fibers and the stain will travel several inches in. A water-based wax is the best thing to use for sealing up logs, and it is not all that spendy.  You can cut corners but sooner or later it will come back to bite you. However if you do not mind trimming off good wood then consider the black jack, paint, bees wax, varnish, or any one of the other home remedies that you may have laying around out in the shop.
Backwoods Custom Milling Inc.
Anchorseal is wonderful stuff for end coating, and well worth the money.  It is about the best thing that you can apply since it is specifically formulated for end-coating logs/lumber.
LeeB
Nail some cleats on the ends of your guide board and attach them to the end of the log. You'l still have holes but they won't be in the face and if you measure carefully you can put the screws on a cut line.
draggon_9
I started wondering about that so I just used paint instead. Thanks (LeeB) I figured out my guide board problem by just putting a screw on each end I only sacrifice about 2" of board and it comes out pretty straight seeing I'm only cutting 5' boards. By the way, I'm running out of stickers, could I use some MDF I have laying around?
LeeB
MDF is not a great choice. It will get wet and swell up.
draggon_9
What if I'm drying in the garage with a fan?
rickywashere
that would prolly be ok as long as its keep in the dry
