How do you guys saw BIG logs????
Started by shinnlinger, October 25, 2009, 09:39:38 AM
shinnlinger
Hi,
Yesterday I cut a 34" log on my Turner which really likes things no bigger than mid 20's.  I can squeeze 29" between the uprights, but the guide needs to be removed for anything more than 26"(whick I didn't realize intill I got the stick on the mill).  Yes I got it done, but I don't know If I will do it again.  I used a Lull telehandler as my log roller and it worked well, but I still had to roll the log 7 times and Mr. Lull isn't mine.
I think it might make sense to rip a large log in half and deal with the two halves seperatly, but I dont do enough to warrant a big saw/bar with rip chain.
Do any of you have any other ideas???  Or even if you rip a log, how do you saw the halves?
Shinnlinger
Dan_Shade
if it's an oak or sycamore log, I would split it in half, and then quarter it.
if it's something other than oak, I'd figure out if I wanted to quarter it, or if I would get out the big alaskan to take a slab or two off until it would fit on the mill.
Another trick is to use a "hi-lift" or "handyman" jack to roll logs if you can't grunt it with a cant hook.
Big logs are tough to work up.
Some folks split them with wedges and hydraulic jacks, some folks will bore cut and bust it with gunpowder.
lots of dull bands and chains
backwoods sawyer
How you tackle them big logs has a lot of variables like:
Is part of the log Junk?
What are you wanting to make out of it? Slabs? 1x4’s?
Therefore, you pretty much have to assess each of the over sized logs differently.
I have yet to remove a guide to make a cut. What some of us do is to make a horizontal and vertical cut to clear a path for the guide. Another option is to take as much as you can off several sides, whether you make it octagon, or hexagon dose not matter just as long as the wood is gone, some call this gun barreling and it does require turning the log a lot.
As far as splitting the log in half, it is not a requirement to have a big saw with a big bar with ripping chain, that just makes it easier. You can split a big log with a small saw even if it will not reach half way thru the log, by cutting from both sides and if it is still holding together cut a notch for a bottle jack in the end and jack it apart. There are no hard and fast rules that say you cannot cut the log into thirds if that is what suits you.
My first over sized log was an 8’ Oak that had severe butt swell and branch swell, the smallest part was in the middle of the log and it was 42” and 36” is supposed to be the limit on my mill. I was out in a stockyard on a side hill with no support equipment. I trimmed on that log on the ground. Then rolled it over onto the loading arms and trimmed some more. Then loaded it on the mill and trimmed some more, by then it was looking pretty round. I had to cut notches for the guides on the fist four cuts. I struggled with turning it each time as the chain turner would not come up high enough to get a good bite until I took a few passes with the mill and the log wanted to walk forward of the back dog.  Then I came to a spot where I could not get another cut and it would not turn because it still had one side that was hanging up. So I unloaded it, trimmed some more and put it back on the mill and made lumber. I had about four hours into that log before I got one board out of it. The rest of the log only took about half an hour and I was putting the mill back into travel mode.
Backwoods Custom Milling Inc.
Kansas
We used to split them with a chainsaw, trim them, etc. Its time consuming and doesn't result in much lumber cut per hour. Easiest way is find someone who has a swing mill and hire them to cut them down until you can handle the rest. You might be able to find one that would change out work. You can cut wide boards; a swinger can't, or not easily.
I have a pretty easy way of handling logs that are too big for me.  I use one of the phrases, "I'm sorry" or "No thanks", whichever is most appropriate.
Dave Shepard
On logs that size, 34" to 40", I will saw off as much swelling as I can, if it's a butt log. That really helps. Then I take a slab and boards until I have guide issues, then I will rip out a piece for the guide to travel through. The more I can get off on the first face, the easier it is to turn on a manual mill. I've had a couple that I had to slot for the guide on the second face as well. You can also take small bites, and turn just a little, making an octagon. After you've been all the way around, you should have a fairly cylindrical log. Then you can start making boards. There is sure a lot of turning to be done. I had a couple of big logs to make into wide (24") flooring. We had the Alaskan out for some 34' beams, so we squared to adjacent sides of the log. That way I had a flat on the rails of the mill, and also against the back stop. I've had logs on the manual mill that took 4-5 man hours ( three guys) to get into a squared configuration. I can split most any big log that I deal with into quarters in about an hour (one guy).
Some where I've got a thread called "How to cut 400 feet an hour on a manual mill". The first hour, I think I cut 50 board feet, the second hour, I made about 800 board feet of 18"-24" flooring. The next log was something like 9 hours for 900 feet. :D
treecyclers
Depending on species, I have eyeballed a slice or two off the top and side to get the log to be compatible with my mill throat.
MY workhorse saw is a Stihl 460 with a 20" bar, and that's usually plenty to get the job done. No need for monster saws...
We even cut a 72" walnut (what a monster that was) and quartered it to get it on the mill.
I wake up in the morning, and hear the trees calling for me...come make us into lumber!
Ironwood
Got access to dynamite?  ::)
  I would just free hand rip it. Throw a 2x4 on the top as a guide (helps me anyway). Then if she just aint quite there I spear it with the forks and let the weight pull the remaining apart.
Ironwood
tyb525
With my mill, anything bigger than about 26" is a big log :D I find it more stressful cutting oversize logs.
Quote from: tyb525 on October 25, 2009, 02:13:11 PM
On you, or the mill? :D
tyb525
Myself, my limited equipment, and my mill :D
Like Tyb, I get stressed even thinking about cutting a 42" diameter log on my LT15 :).
customsawyer
When you do alot of it you start to like it and the small ones become less of a pleasure. ;D
www.thecustomsawyer.com
caver
I could have used some of these suggestions a few weeks ago.
;D
My loader (20hp Kioti) won't lift what was calculated as a 1500lb log. I had to push it up the ramps a little at a time.
Then I had to trim some junk off and learn some of the stuff posted in this thread the hard way.
Trying to turn it involved my neighbor coming by and offering to help. I haven't seen him since that day  :D
I did drop a case of beer at his doorstep the following week I was at my farm.
Baker HD18
moonhill
I like big logs.  They are a struggle but worth the effort.
Tim
If your trying to put beans in the pot know the size you can handle and avoid any larger.If your a glutton for punishment and enjoy a challenge have at the huge ones,you can always trim a little at a time and end up with a pile.Frank C.
davemartin88
For those of you that use chain saws to cut down a large log, do you use ripping chain when you try to split a log in half or some other type of modified chain?
coastlogger
Ive ripped a lot and never owned a ripping chain. I believe the time saved in cutting with a ripping is fairly minimal. Just file a bit more right angle to bar and take lots off rakers seems to work.To quarter,I put a 4x4 on top of log, climb up and follow the 4x4 with the saw about an inch away from it. When done, go to each end of log and follow cut down. This gives a reference point for cutting once youve rolled log over. Roll log 180, repeat procedure. Be *DanG careful log does not come in half while youre up there!Restrain with a strap, machine, blocking etc.
clgr
backwoods sawyer
Quote from: coastlogger on October 26, 2009, 07:38:11 PM
I use the same chain filed the same way as for cross cutting and I still pull out long stings that tend to plug up the discharge of the saw. A chalk line will not work as well as a board laid out as a reference because you will have to stop and wipe the log off to find it, but it will work in a pinch.
The point that coast logger makes about not being on top of the log when it comes apart is a very good one. Some logs will slowly open up and others will pop apart very fast. Making the final cuts from the end will keep you out of harms way but stay alert.
shinnlinger
HI,
NOw to the second half of my question, How do you guys saw the halves?  Do you lay the semi flat sawed edge on the deck (which would still probably be too wide) or do you set it against the stops, take a pass to square the edge/remove material, flip, repeat, then lay it down on the deck, take a pass to give an opening cut, flip and then saw as "normal"
What did I just type????
Shinnlinger
coastlogger
I usually do them with chainsaw seeing as how Im all geared up with it from splitting  the log.The loading and securing of a half log on the saw bed is often more trouble than its worth I.S.T.M.Depends on how big they are.Smaller halfs are easier to load/secure etc.
clgr
Mad Professor
Anybody using a logosol mill , inverted, for big stuff?
I've got the mill and a 45" white ash (160 growth rings) waiting.
backwoods sawyer
Stand the halves up. You can take a shallow cut or a deep cut or several shallow cuts from there.
ohsoloco
If it's a huge log I have to quarter it to saw on my Norwood (like the 44" diameter sycamore I cut a few years ago).  Otherwise, I just use my chainsaw to rip some of the sides off, and if necessary I'll notch out for the guides and skim some off the top.  The blade on my mill only goes up to about 24", and then there's about 8" of room in there between the blade and the bottom of the "engine frame".  So if it's really too big, then if I were to saw one half, I'd end up taking a big chunk off on the first pass anyway, and probably have to trim some off before I started the cut  :-\
After skimming and notching I cut off as much as I can on the first face to try and lighten up the log (yeah right).  Wouldn't want to mess with trying to load and clamp half a log.
customsawyer
I stand the half up and then take to cutting on it but I do have the advantage of backhoe with a thumb on it so it makes it alot easier to get a hold of.
