1984 John deere 640 ?????
Started by leavitt logging, October 17, 2009, 10:25:19 AM
leavitt logging
I have recently purchased a straight 640. While looking for a skidder I tried out many 640d's what are the major mechanical differances between a 84 640 and a 85 640d and up? The other question I have is the hydraulic disconnect is missing,the lever is there the linkage is not. The machine has new motor and tranny. There was 2400 hours on both when I purchased the machine.Why would some one not connect linkage? Due to cold weather in Northern Vermont it would be nice to be able to disconnect the Hydraulics before starting. How big of ajob is it to connect linkage?
Black_Bear
Kevin, your brother in law can help you out with this question. I know he's just chomping at the bit to tinker on a skidder.  :D
Connecting the hydraulic linkage shouldn't be much more than having the correct linkage, connecting pin(s) and cotter pin(s); it is a fairly simple concept.
fishpharmer
LL welcome to the forestry forum.  Don't much about skidders.  But if its a Deere its got to be good ;)
Sounds like sloppy work, not connecting the linkage.....but there are all sorts of reasons for that sorta thing, maybe the dog ate it? :D
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
