Silver Soldering Carbides
Started by Firebass, October 03, 2009, 06:08:39 PM
Firebass
I'm finding that if after I silver solder new carbides on they can be a bit starved of solder.  I found that if I re-coat with flux and re-heat the tip then add a drop of good quality solder to the joint that it flows up around the bass of the carbide and the base giving it added support.  Anyway,  Thought I'd Share.
Firebass
ErikC
  I have found that I need to add a little as well. The pre-tinned tips have enough to get it on there, but it seems thin once applied. Too much could be a problem as well I guess, I clean up the edges with a flat file if there is a little ugly drop somewhere. :-\
scsmith42
I've also had good luck with adding a drop of solder to the notch in the blade, before I solder the carbide on.
Tom's 3638D Baker band mill
