Well, I hope that I didn't make a mistake...
Started by scsmith42, September 07, 2009, 06:04:21 PM
scsmith42
by buying a used Stihl 066 Magnum sight unseen off of e-bay...
The seller had 100% positive feedback, and stated that the saw worked as well today as it did new.  We'll see in a few days.
Around $450.00 delivered to my door - can't complain about that if it works as advertised.
50% more power than my 044, so that should help with trimming the ends on the big logs.
Scott
Tom's 3638D Baker band mill
Al_Smith
You probabley did good . I don't have too many complaints about what I've gotten from e-bay .However since they adapted the pay pal only method of payment I have not purchased a thing .
I've actualy gotten better deals though members of web forums than I did through e-bay any way .
As for the 066,not a bad price if it is in good running order,nice saw ,plenty of power for sure .
fishpharmer
SC, So your the guy that outbid me :D ;) ;)
Kidding really.
If its anything like the 066 I borrowed you will love it.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
teddy
Hey Scott,
I got the first one!
Missed on the second! Good for you!!!
I have never seen 066 go for that, and to top it, 3 for under $500 in a hour span!!!!!!!!!!!
Matt
Ernie
Sounds like a good deal as long as he is the guy that actually owns it.
KGNC
Scott:
I took a chance and did the same a little over a year ago and was well pleased. I got a 066 Magnum for $530 with shipping. To be sure the saw is well used but doesn't seem to have been abused.  I put in a new plug and sprocket and started sawing.
No more than I use the saw I expect it will last many years. If I was depending on the saw to feed the kids I might consider a newer unit, but for firewood and the small amount of timber I cut it's fine.
Al_Smith
 :D Well it's a little bit of over kill for a firewooder but at least you won't run out of power,that's for sure . It should last you for many many years,maybe forever .
scsmith42
The saw arrived today, and all appears well.  Lot's of compression, and pretty much normal wear and tear.  I only ran it for a few minutes, but it was smooth and had consistent power.  I could not bog it down with the 20" bar.
ladylake
With a good sharp chain and the rakers low enough you cab bog any saw. I couldn't bog my 45cc Echo once when the chain was real dull.   Steve
Al_Smith
Lot of truth in that .I once stalled one of the most powerfull 066's I've ever seen by leaning on it too hard .
I imagine the boyz in eastern NY state are still mumbling about that saw and clumsy old Al stalled it in a cut .10 by 10 cottonwood cant as a matter of fact . :D
ladylake
 Right Al, but they sure cut fast with a sharp chain, low rakers and just the right touch. The only time I don't like low rakers is when felling a tree where I tend to use the dogs. I keep a saw with higher rakers for that.   Steve
scsmith42
Guys - you're right - I should have mentioned that the chain was somewhat dull.
