End Grain on the Lathe
Started by Patty, September 05, 2009, 05:08:02 PM
Patty
Today I finally got back on my lathe.   8)   It was alot of fun. I found a chunk of wood that someone sent to me a few years ago, and I regret I do not remember who. Anyway, the chunk has end grain that is giving me fits. I do not know how to proceed. You can see by the photos below, the trouble I am having. If anyone has helpful hints, I would really appreciate them.
Women are Angels.
And when someone breaks our wings....
We simply continue to fly ........
on a broomstick.....
We are flexible like that.
Burlkraft
First off that's a Jet Lathe   Where's that purdy Yellow Power-Matic?
That wood looks kinda punky. Is it?
I have trouble like that myself....I think it was firewood by the time I got done.
Sharp, sharp tools and small cuts and then sanding may be the only answer
On the udder hand what do I know?  ::)  ::)  ::)
Why not just 1 pain free day?
Radar67
Patty, Steve sent me some wood just like that. I think it was burl yellow birch. The end grain was giving me fits too. I got it roughed down, then dipped it in polyurethane. The first coat soaked in really quick, so I dipped it again after it dried. I had it close to the finished size when I dipped it, so to finish it, I used 36 grit sand paper. I got it down fairly smooth, but there are still a few "pock" marks that will just have to be. I have smoothed the edges of them with sandpaper best I can. I will continue to add coats of poly until I get the finish built up like I want.
Is it basswood Patty? Light and soft? That'll be a hard turn. I have not experimented with soft woods while turning end grain on spindle mounts. Soft woods yes, but not with the grain direction you are. My end grain is usually on the mounted ends of face plate turnings or columns on spindle mounts. It might, I said might, be accomplished with a skew chisel but go slow and don't take big bites. It's got to be real sharp, hone your tool with compound on a felt wheel. It's not going to get done by a tool that has a wide bevel > 20 ° on the cutting edge. I think there is a rounded skew chisel by Henry Taylor that is easiest to handle. Here is a video of a skew chisel being used. I've not viewed it here on dial-up.
http://www.youtube.com/watch?v=4F-EnlcBY1M
Quote from: Radar67 on September 05, 2009, 08:27:14 PM
Probably those large pores, not as large as oak, but they are uniform across the early and late wood so harder to smooth up. You can see the pores easily by naked eye. Yellow birch is even a little finicky to get sanded smooth to. Darn butternut does the same, same deal with the pores, only it's softer so it's worst. :D
pasbuild
That bowl blank is a Yellow Birch burl from a standing dead tree with its top gone, the blanks are soft and need to be sanded down to the final finish. Here is a table made from the same burl.
If it can't be nailed or glued then screw it
Patty
Thanks so much! I came to the conclusion too, that sanding was going to be the answer. However I may try the scew chisel Donk suggested. I will let you all know how it turns out.
Women are Angels.
Patty
I got busy with the sand paper today.
Women are Angels.
Radar67
I see you got some thinning on some of the edges too.
Burlkraft
That looks pretty good Patty  8)  8)  8)
Dodgy Loner
Skew chisels are really not meant for bowl turning. I rarely use them, and when I do, it's for spindles only. Bowl turnings call for a deep-fluted bowl gouge. You must make shearing cut, rather than scraping cuts, to get a good surface on end grain. I would highly recommend that you purchase a basic woodturning book or video. It will cut years off of your learning curve. Also, the wood looks very punky. Life's too short to spend it sanding difficult wood! Although the bowl did turn out nice :)
Patty
Yes Radar the edges are uneven for sure. The bowl started out  askew, as it was cut unevenly to begin with. So the wobble was huge, and added to my difficulty. The only way I knew to correct the wobble was to whittle down the edges until the wobble went away....and ultimately led to the uneven edges.  ::)
Dodgy you are right in that this is not the ideal chunk of wood. But it was a gift to me, and I felt I owed it, to try to make something from the gift. No the scew is not the ideal tool for this , but it worked better than the gouge, since it didn't catch in the end grain. I am an equal opportunity tool user! Yes I could do with lessons, of course I realize my ineptitude. But I have so much fun trying, that I really am oblivious to my less than stellar results.  My hobbies are strictly for pleasure not financial reward.
Women are Angels.
A skew chisel is not really a scraper, it's very sharp edged. Now a square end scraper, is just that. Some people make them from old files. I've smoothed bowl surfaces with skew chisels a few times. It's delicate work though. ;) ;D
Spindle turning, as I've used the term here, refers to mounting both ends, as apposed to a face plate mount.
Dodgy Loner
Quote from: Patty on September 08, 2009, 10:00:35 AM
If your gouge is catching worse than a skew chisel, you're either using a spindle gouge instead of a bowl gouge, or you're using a bowl gouge incorrectly ;). Skew chisels are known for their ability to catch when you least expect it. A bowl gouge, properly used, will usually only catch when you're trying to take a cut too deep or too far from the tool rest. I recommend Richard Raffan's book Turning Wood as an excellent resource to get you started.
Patty
OK, so I didn't use what you are thinking of as a scew, I used a Skewchigouge. I was just too lazy to go look up the spelling.  ::)     It is an awesome tool that Charlie turned me onto, and for this bowl, it worked very well. The sandpaper then finished it nicely.
I do have the book you suggested, I just don't feel like reading it. (the pictures are pretty cool, though!  ;D) Lessons are not available to me, and it is doubtful I would go anyway, even if they were. This turning for me is a pleasure, not a mission. I will learn new technique and maybe someday even get better, if not, that's ok too.
Someday, when you get a bit older, you might understand my nonchalant attitude, Dodger. This is just a hobby for me, no more, and no less.
Women are Angels.
Reddog
It looks nice Patty.
Keep enjoying your hobby. :)
Patty
Women are Angels.
Roxie
I think that bowl looks beautiful!  I know how much work and love goes into your projects and there is no price tag on the sentimental value.
Say when
smith2bj
you did a very nice job on that bowl.  keep up the good work.
Dodgy Loner
Quote from: Patty on September 08, 2009, 06:59:55 PM
I take my hobbies more seriously than most folks ;D. It's a hereditary thing, far as I can tell :D
pasbuild
Patty your an inspiration  smiley_sun tonight I dusted off the lathe through a rotten piece of Maple on it and spun a bowl, it isn't perfect has some soft spots got a little thin in a few spots but it was great therapy
I gave it away after the pics were taken, that makes two happy people.
Lud
I give away a lot of bowls........everybody wins..........
Don K
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
Be great gifts around Thanksgiving or Christmas with a bowl of fruit, nuts and jams for a family.
Norm
