Comstock Logging
Author Topic: Husqvarna 55 value  (Read 31124 times)
Offline Restoman
Husqvarna 55 value
« on: September 02, 2009, 11:23:49 pm »
Just to prime everyone, this is a Husqvarna 55 I am looking to purchase from a private seller.  I do not know what to offer.  What would you offer and why?
Edit, pictures just aren't going to work on here, 45K?
What they say:
Yes it starts on the first pull. About 2 or 3 months ago we put it in the shop had a new 18 inch bar & chain put on it, a new clutch installed & just had it looked over real good.  The only thing it has been used to cut is tree limbs that would fall in our yard.  It has oonly been used like 2 times since we got all the new stuff done to it.
This is craigslist here and they are most likely fibbing about a good bit of what's said.  The bar and chain is an Oregon setup.  The handguard looks like it got in a fight with another saw.
What years were these made?
Offline Restoman
Re: Husqvarna 55 value
« Reply #1 on: September 02, 2009, 11:46:40 pm »
I'm more than happy to email the pictures directly to anyone willing to review them.
Offline cheyenne
« Reply #2 on: September 03, 2009, 12:16:18 am »
Evidently you don't know to much about saws. So my advise is find a good dealer and ask him to guide you in your purchase. Tell him what your needs are and what your usage will entail. Any good dealer will have a number of used saws on hand. Buying used saws is a fools paradise if you don't know what your doing & have the ability & tools to fix a pig in a poke........Cheyenne
Home of the white buffalo
Offline Restoman
« Reply #3 on: September 03, 2009, 12:50:58 am »
I thank you for your advice, but the dealers here are the big box dealers and a few places that sell Stihl.  The Stihl dealers insist that they do not get used equipment.  I can fix just about anything, a saw is not that hard to work on.
Offline Glenn
« Reply #4 on: September 03, 2009, 05:50:01 am »
why would you say he doesn"t know much about saws ys just because he asked an honest question about a particular model   you didn"t answer his question but just suggested he didn"t know anything    get over yourself
Offline RSteiner
« Reply #5 on: September 03, 2009, 06:10:04 am »
On my older Husky's there is a serial number plate that also has the year the saw was made, they did thid in 1997 anyway.  The serial number should offer some help in determining the age of the saw.
What does the saw look like under the top cover, does the air filter look clean, is there a lot of saw dust around the carb and cooling fins on the cylinder head.  That will give you a clue as to how well the saw was taken care of.  The condition of the outside of the saw with bumps and dings can also tell you if the owner respected the saw or just threw it in the back of the truck.
Years ago when I had a saw at the shop wondering about the condition of the saw the mechanic started the saw with the air filter off.  He would watch the air intake of the saw when he rev'ed it.  There was a mist of air and fuel blowing out of the intake which he told me was caused by blow by meaning the rings or cylinder walls were not in the best of shape.
You can still buy the Rancher which I think is a 55 cc saw.  A friend got one back in Feburary for around $375.00 with an 18" bar.  If the owner can not tell you exactly how old the saw is or is the second owner you may not want the saw or you may not want to offer him too much for it.  The one thing I worry about is what they used for 2-cycle oil and how long they kept the mixed fuel around before using it in the saw.
Randy
Randy
Offline Hilltop366
« Reply #6 on: September 03, 2009, 11:53:34 am »
What Randy said + compression test at full throttle (not sure what results should be for that saw)
and also wondering how many hours it takes to wear out a clutch (my dolmar is 20 years old with about 5-6 cords/year cutting down limbing and blocking and other work the clutch is still working fine) in 6-7 years (in the 80's) of repairing saws I can't remember changing a clutch so I would think the first owners must heve used it a lot more than a few times or it failed for some other reason.
Offline Restoman
« Reply #7 on: September 03, 2009, 01:12:29 pm »
To answer a couple of questions:
The id plate is visible in the pictures, but cannot be read even at full zoom.  The clutch was probably replaced due to rusting.  A saw that would sit useless in these parts of the country for a good amount of time will rust to the point the clutch will not work perfectly.  Cosmetics do not bother me the least.  As long as the body is not cracked and the saw will run when I test it everything should be good.  I've heard these 55's can be a bear to start so I know that.  Is there any reason to steer clear from a 55?  I have a comp tester for my automotive stuff.  I guess I need to see if it will fit my Husq blower and edger.  Is there a technique to compression testing on a saw?   Thanks guys.
Offline jteneyck
    • J Ten Eyck - Woodworker
« Reply #8 on: September 03, 2009, 03:30:29 pm »
I have a 55, and you can see my posts below "Husqy 55 won't start" for some issues I've had with it.  That being said, the 55 is a good saw, starts easily for me, and runs great with pretty good power for its size.  Mine likes to gobble chain oil unless I use pretty thick stuff in it; it doesn't have an adjustable oiler.  You can find the service manual on-line, which will tell you how to run a compression test if you have a compressor, gage, and fittings.
Some things I'd look for before buying a used one:
* Do a compression test, if you can.  Otherwise, do a drop test - see comments in my entry on how to do it.  If you suspect a problem, pull off the muffler and look at the piston.  I'm told that 55's like to run hot, which results in the outlet side of the piston getting scored.  You can see this easily once you pull off the muffler.  You'll see rough, verical lines on the side of the piston, and maybe a rough or ragged edge at the crown.  If it looks smooth and shiny then it's OK.
* Check how smoothly the chain runs on the bar when you pull it around manually.  If it seems like it's hitting "high" spots, and they appear to be about the same distance apart, then the crank shaft might be bent.
* Is the air filter covered with oil?  If it is then there's probably blow back from a worn piston.
How much is a used one worth?  Anything more than half of a comparable new one seems high to me, unless it looks nearly new and everything checks out perfectly.  Good luck.
Offline stonebroke
« Reply #9 on: September 03, 2009, 03:55:45 pm »
I bought one two years ago with a new piston and cyl. for 225$ A rebuilt saw in other words. I like it. Also had a new bar and chain.
Stonebroke
Offline Restoman
« Reply #10 on: September 03, 2009, 03:59:26 pm »
cool guys, I read the 55 won't start thread too.  I asked the seller to shoot me a price, so we will see what they want.  50-120 depending on what's going on with the saw.  I'd prefer one that doesn't need work so.. we shall see.  Thanks for the bit about pulling the muffler off.
Offline Restoman
« Reply #11 on: September 03, 2009, 06:16:52 pm »
ahahahahhahahhahaahh  $250   :D That's rich.    I told'em 120 is my highest and that's after passing my inspection.
Offline mud
« Reply #12 on: September 03, 2009, 08:59:39 pm »
I payed less than that for my 044!
272
044
359
350
2045
and a few splitting mauls
Offline Restoman
« Reply #13 on: September 03, 2009, 11:48:13 pm »
She was king enough to respond to my ad so I thanked her anyway, she knows where to find me.
Offline ladylake
« Reply #14 on: September 04, 2009, 06:19:38 am »
$150  to $175 if in good shape.     Steve
Offline teddy
« Reply #15 on: September 06, 2009, 10:42:34 am »
If you are, or are not familiar with saws! A husky 55 is a nice saw! For having mine for over 7 years! It has cut a lot of firewood!!!!!
I am not a husky or Stihl die-hard. Just a person that needs a saw to do the job! Some say that the pistons score easy, just use good gas and good mix.
Like Steve said, 150-175 is a good price if it is in good shape!
Me personally, I have been burned by my local saw shops. I just had to learn how to tear then down!(just like learning how to use them to cut!!!!!) Plus parts are still easy to find. Check Baileys online.
Matt
Offline GASoline71
  • 'cuz chicks dig scars...
« Reply #16 on: September 06, 2009, 02:25:01 pm »
I didn't get that from Cheyenne's post... He was merely stating that it seemed the OP was not to keen on saws.  I kinda assumed the same thing from the original post.  I think you kinda jumped the gun a little thinkin' he was slammin' the guy.
Gary
\"...if ya mess with the bull... ya gets the horn.\"
Offline Restoman
« Reply #17 on: September 06, 2009, 08:38:14 pm »
So today I had no choice but to go pick up a saw that didn't run.  A guy responded to my CL ad offering a Poulan Woodshark 14" saw that ran once and never again.  I denied him, but last night before the LSU game started I heard a loud crack, swosh, and slam. 7-8" dia limb decided it didn't like being in my pecan tree anymore.  A little seafoam and priming the little sucker fired up and went to work.  After an hour with this saw I got out the axe and made more progress.  This was a huge reminder as to why I want a Semi-Pro saw.  $25 wasn't bad, but it's most likely going back up on CL.
Offline Rocky_J
« Reply #18 on: September 06, 2009, 09:08:26 pm »
An hour cutting up an 8" limb? Sorry, but that tells me that the problem is a dull chain (untrained operator). It's really difficult to tell people this and I still haven't figured out how to do it without offending most, but it is almost unheard of for ANY person to be able to operate a chainsaw safely and productively without either training and/or at least a year's experience. I don't think I've ever met anybody with less than 5 years experience that knew how to use a file. You could buy the most expensive chainsaw on the market and would still be unable to cut much with it after an hour of use until you get some training.
An 8" limb is about a 5 minute job to cut up. Unless your chain is dull. An untrained operator can dull a chain in one cut.
The Husky 55 is a good medium size saw for medium duty use. I got one this summer from a landscaper that burned it up in 5 tanks of fuel, dropped a new piston and cylinder on it and gave it to a buddy. His crew is using it for a ground saw in his tree business and it's working fine for them.
Offline teddy
« Reply #19 on: September 06, 2009, 09:13:34 pm »
Be nice!
every one is at a different pace!
But I recommend a Stihl training video, chaps, HEAVY leather gloves and a helmet with face shield!
I was there once, KINDA still am!!!!!!
Matt
