Big Oak -
Started by MTrim, August 26, 2009, 04:27:54 PM
MTrim
I have a customer that has a 9 foot oak log that is about 40" in diameter.  In order to saw it on my band mill I would have to quarter it with a chain saw.  It's more than I really want to tackle.  Anyone in the Columbus, Ohio area have a circle mill?
Anyone have an estimate on the time it would take to quarter a 40" oak log?
Bibbyman
Welcome to the Forum!
What kind of mill do you have?
Sawing since '94
MTrim
Woodmizer LT-15 diesel.  I've been reading the board off and on for the last five years - just finally joined.   Not only can I not handle the size - my max is 28" - but I can't lift the log either.  Estimated weight is 4600 lbs.  If I quarter it with a chainsaw, I will be well on the way to quarter sawing the boards.  Seems like a better job for a circle mill.
Bibbyman
A lot of circle mills won't want to bite into a log that size unless they have a top saw.
Maybe a swinger?
There have been more than a few oversized logs sawn on the LT40 mills.  I've done it myself but it's more trouble than it's worth - to me anyway.  I can saw 10 "normal" size logs in the time I wrestle with a big one.
Even 1/4 would be a mouth full for the LT15.
I've never quartered a log with a chain saw.  Someone here on the forum surely has.
Sawing since '94
Dodgy Loner
I had a 10' oak log a few years back that was 38" in diameter at the butt. I had a sawyer with an LT40 do it, and Bibby is right, it is not very efficient to saw a log that big on a WM. Fortunately, he charges by the hour, so it made no difference how long it took to saw. He was willing to do it and I was willing to pay. Someone with good equipment (we used a backhoe to turn the log on the mill) and an LT40 or and LT70-sized bandmill would be able to do the job. The log would surely require a little trimming with the chainsaw, but nothing as serious as quartering it.
On the other hand, if the guy is willing to pay you what it's worth to you to quarter the log and mill it yourself, why not? I would charge an hourly rate, because there's no telling how long it will take until you actually do it.
Welcome MTrim.
Yup, If it was my deal, I'd just quote an hourly rate and then it's in the customer's hand.  I just quoted hourly rate on a 58" red oak.  Thankfully, he declined.  It was finally taken to the landfill.  No tell what kind of metal was in that tree.  There was a "blue" spot on the stump, so it definately had something.
I've cut 38 & 40 inchers on my LT40, but they were no fun.  I charged hourly rate.
Dan_Shade
I would quartersaw logs that large
lots of dull bands and chains
Dave Shepard
I've run a few really big white pines across a manual LT40. I was after wide boards, so quartering wasn't really ideal. There is a breaking point to big logs. I sawed one 16' pine that yielded about 800 feet. That took two hours. A 16' that yielded 950 took me nine! hours! A lot of chainsaw work to get that done. I q-sawed a big sycamore last spring, about 46" big end, and I split it with a chainsaw. Any big log that I was going to q-saw, I'd split from now on, big time saver. Any big pines, I'd roughly square up with an Alaskan mill, also a huge time saver.
It took me an hour total to quarter this log. That included layout, cutting, flipping, sharpening (hit a rock underneath). This was the big sycamore.
kelLOGg
I was in the same predicament early this year with a 43 inch water oak 6.5 ft long. Tried to get someone else to do it for me because I was rather intimidated by this one. The last tree guy I called encouraged me to do it myself - it "ain't that hard" he said. Having exhausted all options I took his advice and bought a ripping chain, struck a chalk line, fired up my little 20 inch Husky, rolled the log so I could start cutting where it was just under 40 inches diameter and had at it. I stood on top and cut as deep as I could then rolled it over and cut again. (I did not have to quarter it because I could get the halves on my mill). It took me 2.5 hours. I was so please you couldn't rub the grin off my face with a brick. Wish I had done it a year earlier. And by the way, I could not tell the difference in the way a ripping chain cut and a crosscut chain. Both were effective.
So "have at it" and good luck.
Bob
ErikC
  With the swing mill, I haven't quartered logs for milling, but I have done it a lot cutting cedar posts out in the woods. I use a regular chain, plenty sharp, get my biggest saw, and climb aboard and go for it. An 8' log takes maybe 5-10 minutes with the bar buried all the way, then I split it apart with a maul or prybar. Not very hard, and halves the log in no time. For milling I guess if you could it would be better to cut all the way through by rolling the log, but either way you are getting more than you would have. :)
mcfcfan
Welcome MTrim,
I have a rep in Lima OH, about 2 hours away i beleive.
He owns a Peterson WPF he can handle that no problems, check out our sponcer link under contacts, reps and you will find Daves contact details, feel free to give him a call or email.
Just let him know i put you on to him
good luck
Lee (Peterson nz)
Life isn't about how to survive the storm,
but how to dance in the rain."
Meadows Miller
Gday
Welcome to the Forum MTrim  ;D ;D 8) 8)
Ive done it in the past more times than id like to remember but it wasn't to hard but still took fair amount of time even with a 3120 with a long bar ( maby an hour n a bit to neatly quater a 48" da by 12'-16' footer) then id rig up the csm and cut flitches and  throw them on the tabletop mill to saw boards  ;) those where the days  :) ::) Not  ;) :D :D :D Im glad ive got the Lucas now for the bigguns ;D 8) 8)
The bigest thing ive seen Dad bust up into 10" 3 sided cants freehand  was a Redgum 8' on the big end and 6' on the small end that was about 14' long took him a day to do the lot  ;) that was about 4 years ago  ;) ;D
Regards Chris
4TH Generation Timbergetter
As stated those big-uns are not economical to mess with ,of course that dosen't  stop us from trying.First thing cut all the nubs off and butt flair have a perfect  cylinder as possible.Then use what they call gun barreling cut as wide a slab as you can,rotate the log and do the same.Pretty soon you have an uneven octigon shaped log you can handle,mayby.If you have to turn by hand the super sized logs are not worth the miles they take out of your back.Frank C.
metalspinner
Is it a really nice log worth putting all the effort into?  Or is it just big?  Also, what is your biggest chainsaw?  Those two considerations would help me decide the worthiness of my effort.
QuoteI have a rep in Lima OH, about 2 hours away i beleive.
Even with the two hour drive, this mill can finish the job by lunchtime. ;)
backwoods sawyer
Quote from: bandmiller2 on August 27, 2009, 06:43:08 AM
First of all is the log worth milling? If it is a real nice log then have at it.
How you tackle it, depends on what the customer wants out of the log. If he or she is wanting wide boards or slabs then quartering it may be out. In that case round it up the best that you can with the chains saw. another option to gun barreling it is to take a hefty slab off of two sides 90* to each other. If you take a 10" slab or so off you can always put it back on the mill later to mill it out. By taking the slabs off you now have a flat spot for the log to sit on the mill, and one to sit against the dogs. This also puts the crown of the log off center allowing the saw to take a deeper cut with out the guides hitting.  I would plan on it taking all day to mill a log this size even with a couple of well fed helpers to assist with moving a log that size, and bring all your tools, coma-longs, chains, truck, bars, Pee-vees, jacks, shovel, ect.
The real advantage to quartering the log is that you lightened the log up so that it is easier to handle, a 32" bar is plenty for quartering a log that size, make a pass the length of the log and then go back and make sure that there are no high spots in the cut. Make a notch at the top of the cut at the end of the log and insert a bottle jack and pop it apart, Oak likes to hang on so you may have to finish the jacking with a handyman jack. Lay out some 6x6 beams for the halves to roll out on so that you can keep the bar of the saw out of the dirt when you make the quartering cuts. It helps to have a line to follow when splitting a log like this.
Backwoods Custom Milling Inc.
rickywashere
could you not split the log stand up the half and take a slab off the top and turn it over and take a slab off the bottom with the chainsaw and then be able to mill it .
ricky
Are you suggesting he "split the log" or "not split the log" ?
You say "not split" but how do you get the "half" ??
There was a guy on the FF once that stood the log on end, and ran the chainsaw down the middle. I think he included a short video of doing that. But I don't think that is what you are suggesting when you say "stand up the half".
 ???  Sounds like he's suggesting spliting the log and then taking the top and botton off, thus making a "D" with a flat bottom and top.  (I don't know how to draw on here.)  Maybe he'll come back and 'splain it.
Radar67
Quote from: rickywashere on August 27, 2009, 07:08:07 PM
I think he is asking, "Why not split the log into halves, then stand the half up so it is only 20 inches wide, then take some off the top and bottom of the half so it will fit on the mill." Just like Magicman suggests.
rickywashere
yep thats what i'm saying that way it will say a lot of time and after couple of cut you can turn the chain sawn edge up and re square if needed
backwoods sawyer
I have done that with logs up to 48" Just split it in half square off one edge so that it has a 6"-8" flat side so that it will "stand up" on its side. Then raise the head all the way to the top and come back down an inch make a few cuts and then flit it over. The only real problem with this method is the log dose not want to stand up on its edge with out a lot of help. Even the hydraulics on my mill was unable to get the log to stand up, not because they were not strong enough, but because they were not designed to stand a log up like that and a front-end loader was needed to assist in positioning the log halves. And it seems that he mentioned that he did not have any equipment for handling the log.
Works for me.  That way you only have to make one large cut and two much smaller.  Thankfully, as yet, I have not had to split a log..... :D
customsawyer
You could bring it to me I do lots of them but the haul bill might be a bit steep. ;D
www.thecustomsawyer.com
