rot same as rust?
Started by northernss454, August 23, 2009, 10:17:54 PM
northernss454
Hi all ,I have a question,If you have a bit of rot inside tree from an old tree wound will it continue to spread or just stay the same after the wood is dry.So is it like rust that when it starts there no stopping it,or will it just dry up and stay the same???? Thanks.
northern454
Likely no good answer, as it may stay compartmentalized and not spread, or it may continue to grow (and grow slow or grow fast).  ::) ::) ::) Depends on a variety of things, none of which are real easy to identify or control.
Others may define it better, as that isn't a very promising answer.
What is the history of the tree, what kind of tree, where is it growing, and what size is it? A pic would be great.
northernss454
White spruce,15" in diameter,I used it for my log cabin,the tree was a bit damaged,so I used it over a window,when I cut out window i noticed the rot.Its a lot of work to remove now,as it has logs scribed over it.I will post pics tommorow.
Dodgy Loner
No need to remove the log, as long as it is structurally sound. The decay will stop once the log is dry.
northernss454
