Hit a back support
Started by John_Haylow, August 03, 2009, 08:32:25 AM
John_Haylow
I just finished 3 days of cutting for my brother in-law. It was all Hemlock that was cut 2 years ago and one very large Spruce. I managed to hit one of my back supports and destroyed one of my new 7* blades. In doing so the blade got wedged behind the guide roller and sheared off a sliver of the blade about 8" long and made its way through the discharge shoot. I had to cut the blade out  with a hacksaw to remove it. I now know why they say to stay clear of that area when the mill is running.
I was surprised at the quality of the lumber, considering the age of the logs. The 7* blades worked very well in the Spruce and Hemlock but not so good in metal  :-[
2004 Wood-Mizer LT40HDG28
Meadows Miller
Gday
Apart from hitting the back stops  it sounds like you had a good runn Mate  ;) ;D 8) 8) i dont like sawing dry logs myself but you cant avoid it sometimes  ;)
ive only hit the back stops a couple of times once on a Wm lt40 and once on my little jonsered 6000+  i had from when i was 15yo but it wasnt too hard just enough to leave a small mark  ;) i wouldnt want to hit one going full tilt tho but i have had afew bands break on me over the years like you said I wouldnt wanna be standing inline with the band when that happens  :o  :o ??? ::)
Reguards Chris
4TH Generation Timbergetter
ARKANSAWYER
  Welcome to the Club!      8)  8)  You are in good company.  It is the piths when you do it with a new blade.
ARKANSAWYER
farmboy1tn
well that one is behind you,tramp metal is next   >:(
DR Buck
Ah!   A new member.   ;)  Welcome.    Makes and awful noise.    smiley_furious  Doesn't it?
farmboy1tn
well i hit the back stops second week  after i started, but got my first tramp metal this past weekend,40 penny nail in a big cedar a friend wanted cut. time for a metal dector. but i still haven't ruined a new blade yet. but only time will tell
Bands are cheap,could have been a 52" headsaw that you had just put new bits and shanks in.John we all have done it at least once,most won't admit it.Frank C.
LeeB
Quote from: bandmiller2 on August 04, 2009, 05:58:39 AM
At least three times a year or more.
zopi
yeah..yer not alone, by any means....I've only hit one piece of metal so far...cut a 16d nail in two and didn't notice it until I was stacking...didn't even ding the blade...lucky.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
petefrom bearswamp
Yep,
did it two days ago while daydreaming.
thank the lord I was sawing alone so nobody saw me.
this makes the third time I have done this. Not proud of it just fact.
Old timers disease I guess
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Chuck White
Hey Pete, I've noticed quite a few spots on my mill where the back-stops have some pretty good size gouges in them where someone (must be the first owner) made boo boo's!  ;)  :o
Also a debarker bite on the clamp and a chainsaw bite on the large pipe in the lifting arms! :-X
I hit one of the manual back-stops once, all it did was just take the top inch or so of paint off.  Good thing is was on a steep slant!  8)
Chuck
backwoods sawyer
I hit one of the manual dogs with the back of the saw the other day. The dog was down and as the head came back home it caught a chunk of bark that caught the dog and stood it up. The back of the saw hit the dog and the saw jumped off the wheel. A quick check of the saw did not find any damage. I marked on the saw what had happened and will take a closer look at it when I sharpen it.  No harm, no foul.
Backwoods Custom Milling Inc.
Brucer
I haven't sawn my mill yet ... this year ;).
For the record, from first hand experience ...
  You can saw pretty deep into a backstop.
  You can saw off the corner of the bolt that holds the backstop rollers in place.
  You can't saw the backstop rollers themselves -- they just turn and get polished.
  You can't even make a mark on the vertical clamp cylinder.
So now you know all this, you don't have to try if for yourself :D.
Bruce    LT40HDG28 bandsaw
I sawed into mine once, got so fissed I welded a nub on the back guide that will hit first and either stop the band carriage or push the log stop down enough for the band to clear.Frank C.
Yup, hit the log support a couple of times, and the log clamp twice.  I think that it's part of the "learning" curve.
I sawed a 24" cedar Monday.  I questioned the customer about where it came from and that it probably had nails, etc. and reminded him that it was 20 bucks if I hit one.  Third cut....nail #1.  Turned it and about 4" down....nail #2.  Turned it and again deep into the tree.....nail #3.  After $60, he decided that it was time to "jump butt"  the tree and salvage the top 8' of the log.
Any tree that came from an old "house place", will probably have metal.
WH_Conley
I sawed one for a customer the other day that he would up buying 3 blades also.
Bill
GregW
I hit a back support last week ... first time in 7 yrs. It was 4:30 pm on a hot day, I got distracted by the cold beer in the fridge calling my name!
woodmills1
cant wait till kathy hits one so the 70 is hers
petefrom bearswamp
Hi chuck white,
Been away a while,
Yeah those dings are from me.
Its amazing how far in the blade will go in the back supports. Screeches too!
I had forgotten the chain saw mark in the lifting arm bar.
Never hit anything with the de barker that I can remember tho.
Regards Pete
Kubota 900 RTV
Dan_Shade
it will also do a number on the claw turner  :-)
lots of dull bands and chains
boman1
There are two kinds of sawyers............those that have hit the backstops, and those that will hit the backstops !
Meadows Miller
:D :D :D :D thats spot on mate  ;) :D :D ;D
backwoods sawyer
Quote from: boman1 on August 18, 2009, 11:41:16 PM
When I worked in the big mill that is what they said about the carriage. I made it 17 years with out hitting the carriage with a set of double cut twins in the early years and a set of quads after the upgrade.  8) I have snaked two saws out of a 4" cut, :o I have busted two saws at the same time when a block ripped out of the carriage :o, I have unseated a block chipper and watched it dance around on the floor as it came to a stop, ;D  I have caught the end of back stand and sent it flying like a helicopter across three edger's, no_no but I never hit the carriage with a single saw. ;D (As I knock on wood)
The truth hurts sometimes.... :D :D
nas
I thought the saying was "95% of sawyers will say they have hit a backstop, the other 5% are liars" ;D
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
