easiest way to KILL production while milling
Started by spencerhenry, July 24, 2009, 09:29:48 PM
spencerhenry
at first i thought of this topic as a joke, and then i thought "if you know what slows you down then maybe you can stop doing those things"
here are a few that ruin my production
1. running out of fuel (priming the diesel sucks)
2. running out of water (the water is at the house not near the mill)
3. hitting the supports with the blade (rare but a real pith off)
4. pitchy, knotty, crooked, or too small of logs
5. waiting for the off bearer who acts like each board weighs more than him
6. running out of logs
7. forgetting what i am doing (dreaming of hunting not milling)
8. having to move the slab pile, or lumber pile, or sawdust pile
Ron Wenrich
There was talk of putting a hose up to the booth so I wouldn't have to stop for those outhouse breaks.   :D
I would add nails and trash metal to the list.  They kill my production.
Dan_Shade
lots of dull bands and chains
Having to stack the DanG boards  :).  You can saw, saw, saw, but you have to stack, stack, stack :D.
farmboy1tn
good friends that come to visit and ask alot of questions.
LeeB
A cold watermellon on a hot day. Didn't take long did it?
backwoods sawyer
Quote from: spencerhenry on July 24, 2009, 09:29:48 PM
#1 can be solved by fueling up while doing the daily oiling. Either at the start or the end of the day.
#2 I carry a 35 gal jug of water in the truck along with two of the 5 gallon mill jugs, this allows me to keep one jug ready at all times.
#3 see #7
#4 If they are the customers logs there is not a lot you can do about that unless you choose to not mill them. If they are your logs then buy better logs.
#5 Work alone then you can kick it up a notch, or get a bigger helper so you can cut off bigger boards. You can base there pay on percentage rather then by the hour, or give a production bonus based on percentage if your production is higher then a set level for the day.
#6 see #5
#7 stay focused on #3
#8 Review your site lay out, and look for ways to minimize the amount of handling of materials.
#9 Handling over sized logs that require a chainsaw artist to trim the guides out after getting them stuck.
#10 Using the wrong saw for the type of wood that you are milling.
#11 Not having the right tool to make a repair.
#12 an indecisive customer.
Backwoods Custom Milling Inc.
ladylake
 A offbearer who has to inspect every board before getting ot of the way.   Steve
Chuck White
I agree with backwoods sawyer's item # 12.
Nothing slows me down more than the customer not having his mind made up!
What I usually get is a list from the customer that says:  I want xx 2x6x8, xx 2x6x10, xx 1x8x8, etc.
Most times they'll say "when you get the list done, put the rest into random width inch boards!
Sometimes, the customer will mark the end of the log with  2x6, 2x8, etc, knowing he'll get an occasional inch board or 2x4 or some other such board.
Chuck
Celeriac
Currently learning the ins and outs of a Mobile Dimension 128.
"What's that?"
"My sawmill."
"Looks like a VW ran into an antenna tower!"
customsawyer
www.thecustomsawyer.com
StorminN
Quote from: Celeriac on July 25, 2009, 12:14:20 PMA little dirt in the Solex.  Aaargh!
I hear that one! Mine needs a cleaning right now...
-N.
Happiness... is a sharp saw.
sgschwend
Folks stopping by and asking what I am doing with the firewood pile.
Steve Gschwend
sjgschwend@gmail.com
D Martin
Geting so busy with Work, Band, life in general, you forget you even have a mill.
petefrom bearswamp
I have killed production (altho I am not a high production guy at all)  by not paying attention to long shards of pine Spruce or Hemlock wood from the de-barker jamming  the in-feed side blade roller causing it to stop and the blade to wear a spot or two in the back of the blade roller.
this is especially a problem when running the lubemizer system.
I'm sure this could be alleviated by paying better attention.
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Rancher
Everything here and...cutting more and more trying to cut that one bad spot out of a log that you didn't see to start with. Only to end up with expensive firewood.
If you're honest you don't have to trust your memory.
Shamus
Not sharpening frequently enough, slowing down your feed rate so you don't bog down the engine.
("I'll re-sharpen after the log deck is empty.")
Trying to squeeze one last funky board from the bottom of the log.
Rolling a log off the mill because you forgot to raise the backstops...
D&L Doublecut Synchro sawmill, Procut chainsaw mill, John Deere crawler loader,  F350 4x4 flatdeck, 20 ton logsplitter, running Stihls
OneWithWood
Getting into arguments with my primary helpers, me and myself.
It just kills productivity and the discussions tend to go in circles  :D
One With Wood
Mr Mom
watching the cute thing across the road mowing in a two pice swimsuite.
just messes up my day.
Thanks Alot Mr Mom
islandlogger
4gettin to use the metal detector because your in a all blazes hurry to get the order out and hitting them bloody nails some well meaning fella didn't pull outa the tree after he put them there in the middle of the bloody woods where no nail should be, really chaps my butt!!
Cedarman
Reading the forum. :D :D :D  Sometimes makes for a late start.
Bibbyman
Sawing since '94
Sprucegum
Dodgy Loner
Not to be confused with Ants on a Log ;D ;D ;D
Sprucegum
 :D Finally, some ants I can eat  :D
And it only took 23 posts to get to food  ::)
