This Has Me Stumped (Math Problem)
Started by Radar67, June 09, 2009, 07:33:55 PM
Radar67
I am usually pretty good at math, but this one has me pulling my hair out. Would someone please show me how to solve?
How much heat is required to convert 0.3 kilogram of ice at 0°C to water at the same temperature? (in joules)
That zero has me over a barrel, every time I try to solve it ends with multiplying by zero,  ::) ??? ???
isawlogs
convert it to onces and to farenheit .. you will get rid of the zero .  ;D  Any more help , just hollar .  ;)
   Marcel
Lorax
For a substance undergoing a phase change, just multiply the mass by the latent heat of fusion.   For water the latent heat is 80,000 calories per kilogram, or about 335,000 J per kilogram.  So in your problem, .3 x 335,000 = 100,500 joules. ;)
Radar67
Marcel, I should have thought of that. When I figure it that way, it comes out real close to what Lorax said. Thanks guys. :)
Captain
zopi
dunno, but budweiser has a can that will tell you...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
sharp edge
Isn't it just a 3-1 ratio?
Budweiser- leave in snow bank for 20 min. before phase change. 8) 8)
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
isawlogs
I dont know why one would want to know , but if he did ever want to share I would be pleased to read why .  :P ;)
   Marcel
Fla._Deadheader
Sure is some very intelligent people on here, EH ???
Quoteconvert it to onces and to farenheit .. you will get rid of the zero .  Grin  Any more help , just hollar .
Radar67
I was helping my daughter with her school work, checking her actually, and that was one of 25 problems.  :) The current subject was "heat" as part of her home school math.
isawlogs
Harrold , I did not know wether he wanted the solution to the problem or if the problem was the zero .. I helped him get rid of the zero .
Now I need add Intelligent to my list of names I have been called.  :P
  I am glad that I did not go to that school .  :-\
   Marcel
Fla._Deadheader
Usted es MUUY LOCO, Marcel  ::) ::) ::) ;D ;D
Warbird
Quote from: zopi on June 09, 2009, 09:36:37 PM
LOL  Thanks.  I needed a laugh.
ARKANSAWYER
   IF you have water at 0°C isn't that ice?   ???   Not much on Metric but I thought water froze at 0°C.
ARKANSAWYER
Brucer
Quote from: ARKANSAWYER on June 12, 2009, 07:07:34 PM
Yep, water freezes at 0°C, and ice melts at 0°C.
Remove heat from water, and the temperature goes down. Keep removing heat and it eventually reaches 0°C (but it's still liquid). Continue to remove heat and it begins to freeze -- but the temperature stops dropping. If you continue to remove heat after all the liquid has frozen, then the temperature starts to drop again.
Same pattern when you thaw ice.
Bruce    LT40HDG28 bandsaw
woodmills1
brucer has hit the head on all of his answers on this thread
The whole concept of heat of fusion and heat of vaporization has always fascinated me, as well as many very famous and rich people in history, me neither famous nor rich.
I will attempt a description of what I mean
It takes one calorie of heat to raise the temperature one gram of water by one degree celcius
or
it takes one btu of heat to raise the temperature of one pound of water by one degree fahrenhite
so let us start with a piece of ice at below the freezing temperature
for a one gram block it takes one calorie of heat to make that ice warmer untill the ice hits zero celcius.  At zero it doesn't melt instantly, more heat must be added.  Actually 80 calories must be added to get the ice to break its molecular bonds and melt to water at zero degrees celcius.  this is why ice in coolers works so well.  It takes lots of heat to melt ice
for a one pound block of ice it takes one btu to warm it a degree untill it hits 32 degrees then it takes 80 btu's to melt it to 32 degree water
did you ever feel the heat from the steam when you drain your pasta.  the steam isn't hotter than the boiling water(unless it is under pressure) it has more heat!!! In fact staeam has 540 times as much heat as boiling water.
The underlying concept that will help you understand the above stories is that heat and temperature are not the same things
james watt knew this..steam engine
some one named westinghouse knew this ...........refrigeration  and much more
this concept was very hard to teach to high school students
my favorite demonstration was boiling water in a paper dixie cup using a bunsen burner.  the water could extract the heat so fast that the cup did not burn.  I still run into ex students(some 40 years old now) who turn to their wives or husbands and say....thats Mr Mills the teacher who boiled water in a paper cup
woodmills1
BTW
the calories in my previous post are calories with a little c and food calories (big C)  are a thousand times more heat
isn't science fascinating
Roxie
Well, thank you for clarifying that!  I was beginning to wonder how the calories in ice cream didn't keep it from melting itself.   :)
Say when
So, how many Calories have I expended when I rent a 12oz beer that is at 33°F, and return it at 98° five minutes later?  I got a feeling I've been working a whole lot harder than previously believed. ;D
Gary_C
Well DanG, first you must answer some questions in order to be precise.
How tall are you? Gravity is important you know. And I would need that in both inches and meters.
Do you want the answer in calories with a capital C or small c?
What is the ambient air temperature and were you sweating while consuming that beverage? That should be in celcius and kelvin degrees also.
And the most important question is how many more of those beverages do you have in case someone has to come down there and help you with your answers?   :D :D
Ambient temp,90°F.  Sitting in shade with a fan blowing on me from the right rear quarter.  8 steps to the rental cooler, 14 to the return tree.  Unlimited supply, come on down. ;D 8) 8) 8)
Gary_C
I'll be right there. But I am kind of slow so it might take a while. That 90 degrees F sounds good to me right now. I think it was only in the low 50's this morning.   :D :D :D
Yeah, I was gonna suggest that he bring some of that with him.  I recall having longed for warmth just a few months ago, but I could use a dose of cool right about now. ::)
sharp edge
Phase change is a big thing in globle waming, with polar ice caps. But think the oceans in FL. is ging up from DanG. We will have to get busy up north, so we can keep the water even. :D
SE
