New to sawing...Have some questions
Started by adam, May 29, 2009, 10:49:27 AM
adam
Hey guys, just bought a cook's MP-32 20' manual mill. I mainly bought the mill for personal use, but I am going to sell and mill for customers as well. I had a couple of questions:
1) Are there any manual blade sharpeners out there that are any good($500-$750  dollar range)
2) what do people coat on the ends of wood to prevent checking
3) Any good ideas of what to do with the junk pine log cut offs
4) Any general tips or ideas are welcome
Thanks everybody look forward to hearing from you.
woodmills1
I have a woodmizer sharpener and would say you would do well to find one used.  make sure to get the updated clamp if it doesn't have one.
perfect use for pine cutoffs is an outdoor wood furnace
do you have a way to handle logs for loading the mill, and what are you going to do with the slabs?
LeeB
Welcome to two serious addictions. The forum and sawdust. There is a wealth of information here in the forum with answers to all the questions you asked and a lot more you never thought of. Look back at the past posts and use the search function. Set aside a good bit of time though. It's kinda like Lays potato chips. You can't do just one.
kelLOGg
Where are you located, Adam? I like to know where other Cooks owners are. There is a wealth of info here on the FF and never enuf time to digest it all. Welcome to the habit.
Bob
Just below show replies to my post is Forum extras,click on to that and than Knowledge base.Lots of help there.The Tool Box is handy too.Good luck with you sawing projects.Have you been around sawmills before?I have a manual mill too.Like I say,If I don't do it,it don't get done.You will need a cant dog or a peavey.They are slow,but just depends on your wants.It's a hard way to make money,but sawing for yourself is fine.
MotorSeven
I can only answer one of those for you...Anchorseal....http://www.uccoatings.com/Home/Products/ANCHORSEAL
It is wax based and designed for the purpose of sealing logs. Some use cheap latex paint, but I think the oveall consensus is that Anchorseal does it better.
I will be reading the "pine flitch" recommendations also...........
RD
WoodMizer LT15 27' bed
Adam, something I've done with those cutoffs is to saw them into large blocks, like 4x6 or 8x8 and such.  They're real handy to have around the place, and I use them all the time.  I've also given a bunch of them away to some of my farmer customers and the tree service guys that sometimes bring me logs.  It's a good cheap way to create a little goodwill. ;)
adam
Quote from: woodmills1 on May 29, 2009, 11:08:51 AM
Hey Woodmills, thanks for the info. I have a Cub Cadet 36 Hp tractor with forks that I use to load the logs with. I'm going to sell the slabs as siding.
adam
Quote from: LeeB on May 29, 2009, 04:51:25 PM
Hey LeeB, thanks for the welcome. As soon as I sawed my first log......I knew I was addicted.
adam
Quote from: kelLOGg on May 29, 2009, 06:02:10 PM
Bob
Thanks for the welcome. I live in N.Y. state
adam
Quote from: thecfarm on May 30, 2009, 08:08:43 AM
Before buying the Cook's mill I had only seen a mill up close and personal once at a demo. It's a lot of fun, and I really enjoy learning new things. Thanks for the info
adam
Quote from: MotorSeven on May 30, 2009, 08:27:52 AM
RD
Thnaks for the link
adam
Quote from: DanG on May 30, 2009, 08:32:17 AM
Good idea, thanks.
Adam,mills create alot of waste,best solution is to heat with it,pine slab isn't bad especially mixed with heavier stuff.Starting off find a company to sharpen and set your bands,if it is truely your calling later look into sharpening equip.you realize you still also need a setter.As stated find used if you can.A creditable job sharpening can be done with a modified bench grinder,wheel shaped to the gullet.Suffolk equip.[timberwolf bands]has or use to have instructions for modifing a bench grinder.Frank C.
DR_Buck
QuoteI'm going to sell the slabs as siding.
:D :D
Not trying to discourage you, but you'd be more profitable by buying a wood furnace and heating with them.   Slab siding is a nitch market and not a big one.  Also the majority of the slabs you end up with won't be of siding quality.
fat olde elf
I agree with Kellog.....I like to know where other Cook's owners are....There are lots of sawyers in New York state.  Hope you have as much fun with your MP-32 as Kellog and I do.
Where are you in New York state ?  I will probably be there in August visiting my brother in Buffalo.   That will be after the PIG ROAST.  Keep the faith......
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
