Bits
Started by brendonv, May 28, 2009, 09:11:32 AM
brendonv
Can anyone point me in the direction for purchasing boring bits for my gas drill?
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Jim_Rogers
What speed does this drill turn?
brendonv
Stihl BT45.
About 650 RPM in Low, 1900 RPM in High, 500 ish Reverse.
www.VorioTree.com
Jim_Rogers
My partner and I sell boring machine bits for antique boring machines.
I feel that these bits won't work in a drill that turns that fast, that's why I asked how fast does it turn.
Antique boring machine bits are designed to turn very slowing and pull the bit into the wood. Using them in a power drill, regardless how it is powered, is not the best solution. You'll need to find bits that are made to turn at these speeds.
I don't have a source for bits like this, and can only suggest doing an Internet search of bit suppliers.
Sorry, I couldn't be of more help.
Jim Rogers
Rooster
Milwaukee Tools make screw feed boring bits that also come with extensions...And I recently saw three fluted screw fees bits at Lowes...but have only used Miwaukee.
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Dave Shepard
I've used a boring machine bit in a hole hawg, you have to stop way before you think, as they keep on turnin' for a while. :D I would imagine that the gas drill is similar.
ARKANSAWYER
  I use the Millwaukee bits and you should have no problem with them.   They come with two tips, one is for soft woods and the other is shorter and for hardwoods.  I have them up to 2 inches and they work good.  Also they can be sharpened some and I got mine at HomeDepot.
ARKANSAWYER
brendonv
Thanks,  I'll have to check HD.
www.VorioTree.com
moonhill
Quote from: ARKANSAWYER on May 28, 2009, 07:36:59 PM
2" bits from Home Depot?  I have not seen bits that size in the stores.  1-1/2" yes but no 2" can you provide more information on the 2" variety?
Tim
PC-Urban-Sawyer
Quote from: moonhill on May 28, 2009, 08:09:31 PM
Tim
Tim,
A quick search turns up this item: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100053616
Hope this helps.
Herb
Jim_Rogers
I used the check availability at my local store option and this bit is available at my local store.....
Jim Rogers
StorminN
I have a couple of those Milwaukee bits, and they work well, but they seem a little RPM sensitive... they work well with a Hole Hawg, not as well with a faster drill... not sure how many RPM a Hole Hawg is compared to your gas drill.
Last time I was in Vancouver BC, I picked up a couple of the Lee Valley auger bits, they've worked well for me so far, and the shorter ones are economical... Lee Valley augers link
-Norm.
Happiness... is a sharp saw.
moonhill
I am having issues with my server and they can't find the page.  I will check back later after they have resolved the issue.
Tim
moonhill
Herb,  that link doesn't work for me, I can only find 1-1/2" bits as found on the Lee Valley link.  2" bits such as those would be very impressive, and I would Pay dearly for one.
Tim
PC-Urban-Sawyer
Quote from: moonhill link=topic=37741.msg54461'8#msg544618 date=1243646899
Tim
Tim,
Not sure why you can't get the page that shows the 2" bit. It lists for $33.47 and page says it is stocked locally in most stores.
Further info:
Internet/Catalog # 100053616
Store SKU# 788333
I found it by using the search on Home Depot's home page, searched for Milwaukee bit and results showed nine items, including this size.
Herb
