Comstock Logging
Author Topic: Used motor oil wood stain  (Read 70939 times)
Offline Joe Lallande
  • Belsaw M-14 powered by Oliver Super188D
« on: May 22, 2009, 06:27:58 am »
Is there a way to mix used motor oil with a thinner to produce a cheap wood  stain?  I slab my own wood for free and now have to pay over $50.00 a gallon for wood stain. Thank you, Joe Lallande Alpena, MI.
Offline Dana
    • Green Leaf Farms
Re: Used motor oil wood stain
« Reply #1 on: May 22, 2009, 06:39:28 am »
Diesel fuel would be a cheap and compatible with oil thinner.
Offline woodmills1
  • the truth shall set you free
« Reply #2 on: May 22, 2009, 07:35:32 am »
uncle larrry's walnut stain
5 gal diesel
1/2 gallon boiled linseed oil
1/2 gal non fibered roofing tar
the tar gives the color and the diesel evaporates away
James Mills,Lovely wife,collect old tools,vacuuming fool,36 bdft/hr,oak paper cutter,ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family, LT70,edger, 375 bd ft/hr, we like Bob,free heat,no oil 12 years,big splitter, baked stuffed lobster
Offline Ironwood
    • http://www.branchandburl.com
« Reply #3 on: May 22, 2009, 09:18:52 am »
Used motor oil (gas engine) has a TON of heavy metals and other toxic contaminants from all the fuel burned and such. Perhaps diesel used oil would be better. I used to undercoat my cars w/ used until I was enlightened by a friend.
            Ironwood
Offline Polly
« Reply #4 on: May 22, 2009, 06:40:56 pm »
back in the 40s the school i attended would use motor oil to treat the wood floods they would put it on when school let out in the spring and by fall it would be soaked in , i use it to treat my wood wagon and trailer floors , also used transmission fluid is good to treat wood flooring it to will leave a light black stain  :) :) please dont mention to uncle sam ,he would rather see me pay 20 dollars a gallon at local box store to help the ecomy  :-X :-X :-X :)
Offline Gary_C
  • Sunrise on the Prairie
« Reply #5 on: May 23, 2009, 03:03:35 am »
I have treated the deck boards on my trailer with used motor oil many times. And used hydraulic oil too.
But not really on purpose.  ::)
 :D :D
Offline woodmills1
« Reply #6 on: May 23, 2009, 06:40:08 am »
I have also seen new pine trated with new motor oil, it looked all nice and shiny yellow
Offline Night Raider
« Reply #7 on: May 23, 2009, 08:23:45 am »
I've wondered about treating wood with used motor oil mixed with a bit of gas to help it penetrate, this would be just for rot resistance, (nothing like a deck, just posts, bridge etc...) because I'm having a hard time finding pressure treated trees to mill.  Maybe I'll try a 2X6 and see how it works.
Offline zopi
« Reply #8 on: May 23, 2009, 08:31:18 am »
:D
pressure treated trees....
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline bandmiller2
« Reply #9 on: May 25, 2009, 07:10:58 am »
We always called it Maine stain.Most of the commercial stains are mineral spirits and coloring, can't get the good stuff anymore.It work but better if not close to folks, children and pets.You can even get fancy and add coloring and thin a little with diesel.Frank C.
Offline Tim L
« Reply #10 on: May 25, 2009, 02:15:01 pm »
around here we call it "Detroit black" stain.
Do the best you can and don't look back
Offline Radar67
  • Cuttin Wood Now For My House Later.
    • Stewart Photography
« Reply #11 on: May 25, 2009, 02:30:57 pm »
Since you already mentioned a thinner, just mix non-fibered roofing tar with the thinner to get the desired tint. I used to use this on craft projects and it worked really well. Stat with a small amount of roofing and continue to add until it gets to where you like it.
Offline SPIKER
« Reply #12 on: May 26, 2009, 05:23:20 pm »
just dont add any matches or open flames :)
works well on trailer decks as long as it aint raining/snowing when ya try to walk on it...
Offline splitter
« Reply #13 on: May 29, 2009, 08:12:48 pm »
Sprayed a building of mine once with a motorized back spray mist blower, mixed burnt motor oil and kerosine. It was in the hot summer months the boards soaked it up like a sponge. Looked good and the carpenter bees stayed away. Didn't take very long with a mist blower. I guess a garden spray could be used. Splitter
Offline woodmills1
« Reply #14 on: May 29, 2009, 08:50:36 pm »
I have done uncle larrys mix with a hand pressure garden sprayer
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
« Reply #15 on: June 02, 2009, 10:10:35 pm »
I'll have to try that, woodmills1.  The house is in need of another coat of Uncle Larry's stain.  It was easy when the siding was lying on sawhorses, and I could just roll it on with a paint roller  ;)  Problem is, it's so thin that it wouldn't work too well now that it's vertical.
For those that haven't seen it before....my white pine siding with Uncle Larry's:
Offline arojay
« Reply #16 on: June 03, 2009, 12:52:02 pm »
I think you will find that any waste motor oil is considered carcinogenic.  Contact with exposed skin etc. should be minimized.  I know a guy who used salvaged transformer oil to stain some locally milled pine for a feature wall in his living room, about 25 or 30 years ago.  We used to spray bar it on roads and work yards for dust control.  Who knew?
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #17 on: June 03, 2009, 02:06:25 pm »
The only way to put on any type of stain is with the "garden type sprayer" and a brush to back brush the sprayed on stain. I can do the whole cabin on an hour with someone moving the ladder for me. I use a car wash brush which  is nice and soft, the best type of sprayer so far is one with a brass tip on the end of the wand.
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Offline beenthere
« Reply #18 on: June 03, 2009, 03:56:56 pm »
arojay
I think waste motor oil and what used to be transformer oil are two completely different hazards.
I think the transformer oil had PCB problems.
Offline scgargoyle
« Reply #19 on: June 04, 2009, 03:52:18 pm »
These various home-brewed stains and preservatives- do they help resist termites and rot, or are they just for looks? Here in the Deep South, the termites will walk off with anything short of iron.
I hope my ship comes in before the dock rots!
